Old 04-21-2013, 01:53 PM   #1
jevanb's Avatar
towing heavy weights
air bags @ 80psi check, heavy duty hitch check, tires at max psi check, ready to tow lots of weight
Name:	little trailer.jpg
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 04-21-2013, 02:42 PM   #2
golfmedik's Avatar
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 04-21-2013, 02:56 PM   #3
asquared's Avatar
wait did you do a brake check? double check your payload can accommodate that trailer tongue weight.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 04-21-2013, 11:19 PM   #4
N3HCP's Avatar
Sure your not over your GVWR???
2013 F-350 Diesel Dually, 6.7L with 3.73 rear with 50 gallon Transfer Flow aux fuel tank, ScanGauge II, Tire Minder on all 10 tires, 2M ham radio, and the ever popular CB.
2014 Surveyor SVF-293RLTS
2014 Clipper 16FB
N3HCP is offline   Reply With Quote
Old 04-22-2013, 10:45 AM   #5
Helmsey's Avatar
Should have just loaded it into the bed of the truck
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 04-22-2013, 11:07 AM   #6
Camper Less Camping
Cajun Po-Boy's Avatar
DMAX's can do a lot but think you met your match here with that load! LOL
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 04-22-2013, 12:34 PM   #7
lowbubba's Avatar
I don't think he can. He has the same problem I have. It's full of air
Lowbubba
What could go wrong?
lowbubba is online now   Reply With Quote
Old 04-22-2013, 04:03 PM   #8
jevanb's Avatar
and a heavy hitch I do not want to remove at this time..lol
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 04-23-2013, 08:29 AM   #9
Helmsey's Avatar
The one good thing about that heavy hitch (other than pulling may camper) is when someone wants me to help them move, I have a good excuse if I don't feel like helping I've found that most people will ask someone else rather than help you lift it out of your bed
2015 Chevy 3500HD
