Old 08-22-2015, 11:41 PM   #1
Smile Towing Hitch Vey Low
Bought myself a very nice Range Rover Sport 2009 model a few weeks ago but had no towing hitch fitted so bought a new gen Land Rover removable one from UK(around $700), which just locks in when pushed into its slot now when measured from ground to top of ball on hitch its only 15" (400mm) where as my Mitsubishi 4wd and Ford Transit Van sit at 20"(520mm) which is perfect when towing my Coachmen Apex QBS22. looks like I will have to sell the new hitch and get the removable or fixed receiver with the 2" slot for the different hitch that would rise the hitch ball to 20", Has any members had this problem with there Range Rover Sport that's is if anyone has got one of these and fixed the hitch height issue, Cheers
savi18 is offline   Reply With Quote
Old 08-22-2015, 11:50 PM   #2
coupevillefish's Avatar
You may be able to find a taller ball. When we were factory fitted on our prior TT, they had a variety of balls to adjust to different vehicle heights. We ended up with a hitch that came up about 4" above normal instead of the ball.
coupevillefish is offline   Reply With Quote
Old 08-22-2015, 11:59 PM   #3
Who Dares, Wins
doc73's Avatar
I do not have a Range Rover but as said above they make longer shanks to rise or lower the ball height. Mine needed to be reversed (lowered) to allow me to tow the TT when we changed to a larger vehicle. $700 for a hitch... OUCH!!
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 08-23-2015, 12:07 AM   #4
The ball cannot be moved its a gooseneck hitch with permanent attached ball see Land Rover Tow Towing Hitch Ball Hook Range Sport LR3 LR4 KNB500070 Thule | eBay this is the one I have, as you can see it sits low, Cheers
Old 08-23-2015, 01:31 AM   #5
bikendan's Avatar
How's that supposed to work with a WDH?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 08-23-2015, 01:46 AM   #6
You cannot fit a WDH to Land Rover Range Rover Sport, Its mentions this in the owners manual,
Old 08-23-2015, 01:50 AM   #7
Dad of 2 teenagers...
My Benz receiver also sits at 15" off the ground but I use a ProPride 3P (similar to the Hensley hitch system), dropping the connection to the trailer by 5".
In your situation, I would definitely go with the original 2" lock receiver if the max supported tongue weight is adequate. Or else have a new Curtis hitch (or any other brand) installed that will give you the 800#tongue and Class3 strength. As mentioned by others, you need to setup WD and anti-sway. (I know that I would, even if you are equipped with air suspensions and that the SUV has a tow-mode with sway contol)
Bob the frog from Montreal
2009 Flagstaff 227 pup (Sold in 2014)
2015 Wildwood 261BHXL
2010 Mercedes-Benz ML350 Bluetec
ProPride 3P Hitch
BobBaron is offline   Reply With Quote
Old 08-23-2015, 02:21 AM   #8
Looks like I will have to shop with Atlantic British in Sun Valley CA, they have the 2" receiver and tow hitch and a video on how to fit them, has tongue weight of 500Lbs, but still no option to fit WDH, in saying that I have towed my TT with my Mitsubishi Pajero/Montero for a few thousand miles here in NZ and never has a single sway on the TT, also the Prodigy 3 brake controller fitted inside the vehicle has a lever to move to brake the TT only if you do get a sway,
Old 08-23-2015, 08:49 AM   #9
Dodge Guy's Avatar
That's with the factory hitch. When you install an aftermarket 2" hitch then you can use a WD hitch.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 08-23-2015, 04:04 PM   #10
bikendan's Avatar
Would never tow any full height TT, with a vehicle that doesn't allow to use a WDH.
hitch, towing
