Forest River Forums
Sunline User Photos
Old 08-06-2011, 04:57 PM   #1
Bilcin's Avatar
Towing in Overdrive
I searched the forum and didn't see an answer to this question. If there is a thread with the answer I apologize. I took a round trip of 1000 and used the OD lockout option. I was amazed at my poor MPGs of 8.6 MPG. At 65 MPH I am doing about 2850 RPMs. On a flat section of highway I put the truck in OD and the RPMs dropped and during the 12 miles stretch it went from OD to 3rd gear only once. I was traveling at 65 MPH and towing a Wildwood 26TBSS with my 2005 Ford F150 5.4 liter V8 3.73 gears. How many times is switching gears from OD to 3rd gear too much? I kept an eye on the engine temp gauge and it remained in the same position as when I am not towing.
Bilcin
Bill & Cindy McKenna
Philadelphia PA
2011 Wildwood 26TBSS
2005 Ford F150 5.4 Triton V8 4x4 XLT
Bilcin is offline   Reply With Quote
Old 08-06-2011, 05:03 PM   #2
I guess my question is this, why block out the overdrive? Use it, that's what it's there for!
Jack
2006 Flagstaff 831RLSS Travel Trailer
2007 Chevy 2500HD 'Classic' with the Duramax engine.
Converting a 1956 GMC PD4501 Scenicruiser, ex Greyhound into a motor home.
jackhartjr is offline   Reply With Quote
Old 08-06-2011, 05:13 PM   #3
Does the Ford have a towing package with a larger tranny cooler? If not, I'd consider putting one one for OD towing, as well as, a tranny temp guage.
My 1/2 ton truck has the towing package and it came with the larger cooler and temp guage. I don't mind towing across country in OD. And 8.5mpg is better than 7.5mpg.
Most trucks I've seen get between 7 and 12mpg towing larger rigs.
JR
JoeR is offline   Reply With Quote
Old 08-06-2011, 05:25 PM   #4
Bilcin's Avatar
Yes, my truck has the tow package, trans radiator sits in front of the bigger engine radiator. The reason I am asking is if the transmission isn't "searching" for 3rd gear or OD is it ok to use OD or towing in OD heating up the trans to the point of damage being done?
Philadelphia PA
Old 08-06-2011, 06:52 PM   #5
daverain's Avatar
Bilcin,
It's my understanding from Ford that the trans will not be damaged with some od to 3rd. shifts. The trans in your truck is most likely either a 4r100 or 4r 70 or 75, either case it's computer controlled and will stay out of lockup (od) if the converter gets too hot. My excursion, equipped with a trans temp gauge will lock out of od if the temp gets too hot, but that's only in the mountains, on I95 its in od almost all the time. Just my 2 sense.
Dave and Rainy
daverain is offline   Reply With Quote
Old 08-06-2011, 07:42 PM   #6
Bilcin's Avatar
Originally Posted by daverain View Post
Bilcin,
Dave and Rainy
Dave,
Thanks, I was kind of thinking the same thing. I read that excessive gear shifting between OD and 3rd gear would overheat and damage the trans. So it makes sence that limited shifting will not do any harm. What are your thoughts about lower RPMs with the same torque on the trans? Does this affect the trans temp?
Philadelphia PA
Old 08-06-2011, 07:43 PM   #7
jimh's Avatar
you probably have something in ur owners manual abt it. on my diesel, the recommendation is to leave it in overdrive; the computer will make the choice.
i have taken it out of overdrive on steep grades to help with the braking.
jimh is offline   Reply With Quote
Old 08-06-2011, 07:49 PM   #8
Moderator
acadianbob's Avatar
I have exactly the same truck and tow in overdrive whenever possible. When not hilly or a headwind.
http://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
2012 F150 FX4 Ecoboost, 2008 Surveyor 235RKS
2003 Yamaha FJR1300, Reese Dual Cam WD
1969 John Deere 1020, 1940 Ford 9N
Jonsered 535, Can of WD-40, Hostess Cupcakes
acadianbob is online now   Reply With Quote
Old 08-06-2011, 07:56 PM   #9
I added a TransGo shift kit to my Avalanche. The 3-4 shift is sloppy and the kit firms/quickens it up as well as other shifts. Also did the larger Corvette servos. I leave it in overdrive..
2011 Shamrock 21SS
2003 Chevrolet Avalanche Z-71 4:10s
2007 TBSS AWD
Hybrid21SS is offline   Reply With Quote
Old 08-06-2011, 08:20 PM   #10
Overdrive .... Unless it starts hunting for a gear. When I see a steep hill, before it has a chance to start hunting, I kick it out of overdrive.
I also have a ScanGaugeII which shows my transmission fluid temperature. if I see the temperature rising, I start to go slower and not push the truck to keep my regular speed *55-60 mph), I disengage the overdrive until whatever is causing the TF temperature to rise disappears.
2006 Ford F-150 XLT/XTR 4.6l, CrewCab. short bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
» Online Users: 601
135 members and 466 guests
0721SSROO, 1l243, 4bnabird, 4kmprs, acadianbob, acowie, Army-dude, autorot8, B47, backpacker3, BarrieMark, bean, bigbearZ71, BigJohn2, blaisrv, BlakeB, bob213, bojack, brookside, buccello, campfun, CanadianMaple, capucine, Cards1989, Cascade Bob, cat1956, Celicabob, Cincy6, ColoradoGreg, cyclepuck, Dave_Monica, davidjb, ddemme, deerslayer, depo, DGrissom, dirtman7, djorgensen3, donn, drb1256, dunnnc, dwcjb, Ed D, elind, Filthy Beast, Fire Instructor, FreedomTracker, GarthJ, GaryRudolph, GMS, gredmer, grhodes50, HamptonRoadsRVing, Happy Campers 79, herdrn, hoffkm, itech, Janet H, JedinWI, Jeep4Two, Jimmygee, Jo54, jrlehr, justinph, keep camping, kevinC, kixonrt66, ktkoch, KyDan, Laura, lemoj1, LFugate, lmcleister, Loopyhamil, Mad4sax, mdamm, Medic44, mraynie, mrores, mrscot, mtnguy, NanaKaren, okdrifter, Old car, Old Jeeper, oldiescc, onthelake, Pa-cj5, Papa Roo, pappcam, Paul H. Eustace, Poppy Bill, PrairieBoy, punkaccountant, rawlus, ResQMoore, Rest and Relax, RGH, RickV, RJHuser, rjshiflet, rockin'ray, ronhanson, rotorhead1250, Rupert Rick, sandpiper, Scriggs1, SDENN4281, shane1234, Sockman, Steve7575, Taranwanderer, Team Wilhelm, thumper, Timex, Titleguy, Tjah, tking1866, tncruiser, tojo70, toleworks, totallystirring, treadwelll, troyt, T_LMurphy, UPGRADER, venturetaz, Vette4trcr, VinceU, vlite2011, wa9b, wagon52, Waterfowlwarrior, WJC, yworrydog
Most users ever online was 996, Yesterday at 11:04 AM.
Close [X]
