Old 07-16-2012, 03:24 PM   #71
ScanGauge, et al, really give you insights on how well your configuration is doing. You still need to calibrate it, but it will give you good, immediate feedback.
Mine has proven useful many times over.
Foard County News & Sassy Schoolmarm
with Lady & Chloe, 2013 39 days, 2014 59 days
2017 GD Imagine 2800BH
'07 GMC Sierra 2500HD Diesel 4x4
Why I got into RVing & More Fun
ng2951 is offline   Reply With Quote
Old 07-16-2012, 03:32 PM   #72
acadianbob's Avatar
X2.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 07-16-2012, 04:14 PM   #73
BigTJohn's Avatar
Ram 1500, 5.7 Hemi, 3.55:1 towing a Grey Wolf 26RL. Not towing at 74 mph or <, I get 20 - 21.5 (calculated, not EVIC) and towing, using cruise control, 58 mph, right lane if on I- Anything, 8.5 - 10, loaded weight TT is 6500#. I get to be the "traffic" everybody is worried about, but I keep a close eye on the rear views and move over - if safe - to center lane at merge points for on ramps. A 26 gl fuel tank gets me to 200 mi for fuel stops and a stretch. Dog gets out so is not too grumpy, DW also.()
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 07-16-2012, 05:13 PM   #74
MtnGuy's Avatar
x3. I have strived to be easy on the gas since the 1974 oil embargo, but found the ScanGauge has even improved my conservative ways.
Old 07-16-2012, 05:24 PM   #75
We have a Garmin Nuvi 2460LMT with the ecoRoute™ HD which does about the same as ScanGauge.
Old 07-16-2012, 06:40 PM   #76
Coops1's Avatar
Edge Insight CTS is what I use, does what the ScanGauge does and more.
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 07-16-2012, 07:23 PM   #77
MtnGuy's Avatar
The Garmin reads the vehicle computer, giving you current, tank, today, and previous day mpg's ??? The ScanGuage will also give you gallons used, gallons to empty, miles to empty, miles since the last fillup, plus it shows transmission temperature, coolant temperature, several ranges of maximum rpm's, and a bunch of other neat stuff.
Old 07-16-2012, 07:34 PM   #78
The Garmin reads the vehicle computer:
RPM meter
Choice of gauges: Fuel Flow, Intake Air Temperature, etc. Coolant/Temperature-Oil/Pressure data, Throttle position, Combustion mixture, Engine component operation and status, Battery and charging system information, Climate control information – Heat and A/C etc.
Real time fuel, sweet spot monitoring,
Overall score
Speed score
Braking score
Acceleration score
Graphical chart showing drive history
Real-time MPG reading
Total fuel used
Average fuel economy
Cost of fuel used
Carbon footprint value
Graphical view of your trip
Monitors 4300 ODBII fault codes
Press fault code to get more data
Reset and re-scan ability
And, I don't have to have another device on the dash or windshield other than my TST TMS
The truck itself has the rest.
Old 07-16-2012, 08:06 PM   #79
MtnGuy's Avatar
I looked it up.....neat.
Old 07-16-2012, 08:42 PM   #80
M109Rrider's Avatar
I have the Kiwi OBDII plug in. It transmits all the vehicle's ECM data via Bluetooth to my phone. On the phone it uses the Torque app to include GPS overlays to figure vehicles performance on different parts of the trip. It does all the mileage stuff plus can monitor, graph and record every parameter the ECM monitors. Can also make a dashboard and monitor all the stuff real time.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
