Old 05-30-2012, 05:33 PM   #21
Missing Link
cyclepuck's Avatar
Thank you all for making me feel better. Pulling a puma 30kdb weighing in a little over 8k loaded with a 2012 silverado 5.3 w/ 3.42 gears. I get 17-18 unloaded on highway. 15-15.5 around town. Our last trip with tt was mainly back roads so quit a few stop signs and I averaged 9.1 there but had a decent head wind on way back so it was in the low 8's. So I guess I'm not doing bad considering I'm around 90% of my gcwr and gvwr.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 05-30-2012, 05:48 PM   #22
My camper is a Rockwood 8312SS and I pull it with a 2006 GMC Sierra Crew Cab 4x4. My truck has the LQ4 6.0 Vortec, 4L80e 4 speed trans, and 4.10 rear. I usually pull in 3rd gear around 65mph at approx 3000 rpm. I get a steady 8mpg on typical flat to slight hills terrain. That is measured between manually fill ups not by the DIC on the dash. The truck alone only manages about 11-13 unloaded. These numbers should be pretty typical for this truck and most gas powered trucks are going to get 7-9 if pulling a decent load.
Shaun is offline   Reply With Quote
Old 05-30-2012, 06:07 PM   #23
RPAspey's Avatar
truck: 5.7l, 2007 tundra double cab long bed 4x4, camper: 29'-8000# flipped axle Cherokee with high ceilings. (I figure about 12.5' to the top of ac) = lots of wind resistance. I'll get 8-10mpg on highway at no more than 65mph. any faster and the mpg drops fast. if I keep it to 55-60, I'll get 1mpg more. I keep casual notes of trips just for kicks.
oh, tow package too. I do use the tow mode and 5th gear, rarely in drive, as it seems to shift more decisively and doesn't hunt. never tried normal mode.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 05-30-2012, 06:49 PM   #24
TV: Ford F150 Crew Cab 5.4L with tow package
TT: Surveyor 264, loaded est. @ 6000lbs
Bed filled with some gear
Tow average is roughly 25l/100km (9.4MPG). Rolling @ the speed limit, and generally do not exceed 60MPH.
The current price for gas here near Vancouver is $1.46/l ($5.37/gallon), that equates to $0.365 CAD / km ($0.57 USD / mile)
Next trip we're heading south into Washington where gas is a bit cheaper
SCOC is offline   Reply With Quote
Old 05-30-2012, 07:12 PM   #25
RonLynnJr's Avatar
My TV is a 04 Ram with 5.9L Cummins w/auto tranns, and 31' Salem fifth wheel and on my last trip I averaged 13.3 mpg's. Unloaded I average 17.7 around town and in the low 20's on the highway. I got these numbers after installing a mandrel bent exhaust, better air intake, adjusted the valves and installing a predator tuner.
Ron, Tami, Annette, and Ron III
United States Coast Guard Active Duty
2011 Salem 28BHSS / 2004 Dodge 2500 Cummins
2012 reserved/camped (17/4)
RonLynnJr is offline   Reply With Quote
Old 05-30-2012, 07:28 PM   #26
Well, I'll make y'all feel better. Just got back from a trip to Va. Beach- 642 miles round trip. Yanking an XLR fiver behind my F350 the lie o meter on the dash said 8.5 on the way down and 8.3 on the way home. Diesel fuel was $3.97 a gallon when I filled up at home, $3.79 in Delaware and Virginia. I was watching the RPM's and said it was mostly turning 1750 at 65 MPH. Can't wait for the fuel bill when we head to Myrtle Beach- 1300 miles round trip. YILES!!!
MightyMike is offline   Reply With Quote
Old 05-30-2012, 07:38 PM   #27
amxpress's Avatar
I towed my 22' Jayco TT that weighed 5200# with my 07 RAM 2500 Cummins and got 10-11 mpg.
I now tow my 36' Columbus fifth wheel with the same truck and get 12-13 mpg.
I think aerodynamics has more to do with it than weight.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 05-30-2012, 08:00 PM   #28
daverain's Avatar
Red face
O.K WE ALL HAVE BRAGGING RIGHTS..... but our HONEST m.p.g. is 8.7 to 9.8,
@ 65 mph Rt. 95 an old 2002 Ford Excursion v 10 towing a 2011 sabre 31rlds,
9000k plus. Can't complain!
Dave and Rainy
daverain is offline   Reply With Quote
Old 05-30-2012, 08:29 PM   #29
Dave and Rainy
Thats not to bad. I got about 7.5 with my Excursion V10 last weekend pulling my FLt831BHHs.
wrenchrob is offline   Reply With Quote
Old 05-30-2012, 08:45 PM   #30
Brigitte
boubou's Avatar
So far,towing 6000l lbs in northern ontario hills: 9.5 mph with 5.7 dodge ram hemi 2010
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
