Old 04-15-2016, 08:34 AM   #11
Too Tall's Avatar
Originally Posted by goduc View Post
You shouldn't need sway control on a properly designed and loaded trailer. From my observations too many TT's are being built with the axles too far forward. Look for TTs with the axles as far rearward as possible. MFGs are trying to get into the 1/2 ton towable craze and that means low tongue weights. The easiest way to do that is to move the balance point forward. That just makes the TT less stable.
Keep the TT tires aired to the max PSI and load it so you have a 12-15% tongue weight and you shouldn't need sway control.
I wonder how many TT owners have ever towed their TTs without sway control. My guess is hardly any. So when they say I don't have any sway because I'm using brand X sway control, they really don't know if they don't have sway control because of the hitch or because the TT is loaded and designed properly.
This will be controversial but, IMO if you need sway control, you probably don't have enough truck.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 04-15-2016, 08:54 AM   #12
B and B's Avatar
I have used brakes to stop sway but mashing the accelerator if able (no one in front or a curves etc.) will straighten you out as well.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-15-2016, 09:57 AM   #13
That's sorta true. But the trailer can still sway with a bigger truck. It just won't affect the truck as much. If the sway becomes out of control then the truck size won't matter.
I towed the same TT (31', 7300lbs) with a 1/2 ton and a 3/4 ton. With the 1/2 ton I needed every trick to have a stable tow. With the 3/4 ton all I used was a standard EAZ-Lift WD. No sway control added. Trailer still had the push pull in winds or when passing semis side by side. But the truck was rock solid.
Side winds would move the 1/2 truck and TT around some, not so with the 3/4 ton.
Makes me wonder how the new lighter aluminum bodied F150s will do when hitched up to a 7000lb 30'+ TT. Everyone knows that the heavier the tow vehicle the more stable the tow.
goduc is offline   Reply With Quote
Old 04-15-2016, 04:41 PM   #14
Too Tall's Avatar
Yea, agree. Weight is our friend.
USMC 68 -70
Old 04-15-2016, 05:10 PM   #15
Total Loss's Avatar
They solved that issue by adding the 700 lbs or so they saved right into the tow rating.
So lighter truck= more tow now for Ford.
Life is good.
Now we will see 32ft trailers being towed by 1/2 tons.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 04-15-2016, 06:54 PM   #16
Too Tall's Avatar
Life is good.
Not taking anything away from the all aluminum body, but that's not solving the problem, it's making it worse.
USMC 68 -70
Old 04-15-2016, 07:45 PM   #17
2007 WildCat 32QBBS
05CrewDually's Avatar
Yeah if you're driving a Ford, but what about the GM people?
The manual slide on the brake controller helps. Truck tractors have a lever off the right of the steering column that does the same thing.
05CrewDually is offline   Reply With Quote
towing
