06-30-2018, 11:50 AM
#161
You need a Weight Distributing Hitch. Air bags will not fix the lack of a proper hitch.
B and B
06-30-2018, 12:07 PM
#162
Just as confused as you
I agree with B and B, I don't see a WDH in those pictures.
Richard & Jill
06-30-2018, 12:11 PM
#163
check this on air bags fifthwheelst.com looks like you need a weight distribution hitch
06-30-2018, 12:33 PM
#164
WDH
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
06-30-2018, 12:56 PM
#165
Looks good to me?! Happy camping.
06-30-2018, 01:03 PM
#166
I agree WDH will correct the same.
06-30-2018, 03:36 PM
#167
Another vote for a WDH with integrated sway control.
Sent from my SM-T377T using Forest River Forums mobile app
06-30-2018, 03:45 PM
#168
Loaded up you'll be at about 4000 with just the trailer. Probably well over 500 lbs of tongue weight. I'd go with a WDH, but try it without the sway bar first, as you might not need it. My trailer is of similar size and weight and I find the sway bar makes no difference at all. I'm also running air bags on my Silverado 1500 and Goodyear Endurance tires on the trailer, both of which help to make it more stable.
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2022 Highland Ridge Open Air Lite Range 17BH
06-30-2018, 05:56 PM
#169
Now a "Top Member"
It looks good, but definitely get a weight distribution hitch. Even if you only get the basic setup, it will help with sway control to some degree. I used just a WDH with my F-250 and 26' TT, and only really needed a separate sway control one time (high cross-winds going down I-10 here in Texas). Your rig looks great. Now finish it up with the WDH.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
06-30-2018, 06:53 PM
#170
Thanks! I do have a sway bar, I might have photographed the hitch before it was on.
07-01-2018, 11:20 AM
#171
I think it looks good. How does it tow as is without the WDH?
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
07-01-2018, 01:35 PM
#172
You need a weight distribution hitch way more than you need a sway bar. You can most likely get by without a sway bar.
07-05-2018, 06:07 AM
#173
2018 Salem 27DBK/2010 Dodge Ram 1500 Laramie
Days past:1996 Coachman Capri-Ruby Ed. 27DS
2004 Ram Quad 1500
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3 '19-12 '20-14 '21-12
07-05-2018, 06:08 AM
#174
WDH vs Air Bags.
2004 Ram Quad 1500
1986 Jayco1016PUP
07-05-2018, 06:32 AM
#175
Forget airbags....go with a WDH.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
07-05-2018, 06:44 AM
#176
If the weight you are carrying was in the truck bed, the air bags would be the right thing to have but since the load is behind the rear axle, what you need is a weight distribution hitch.
The biggest problem you are trying to solve is how to get the weight back to the FRONT axle so you don't have a light steering wheel and therefore a very unstable situation.
If w/o distribution hitch your front is within 1/8in of the unloaded hight in the front axle, you should be ok BUT I never see that happen with 1/2 ton trucks.
2018 F150 XLT V8 HDPP
2018 Rockwood 2909WS
" Life is simpler when you plow around the stump..."
07-05-2018, 06:47 AM
#177
X2, air bags are nice for some things, but, they will not do what you want in this case. Good luck
Retired Auto body teacher
2021 Arctic Wolf 3550 Suite
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
07-05-2018, 06:49 AM
#178
If you go with "WD with SC and Air Bags this discussion would be over Except for the "Looks Good" crowd !
