Old 12-23-2014, 04:31 PM   #11
Thumbs up Sway Bars
Originally Posted by techntrek View Post
Sway bars must be disengaged on slippery roads. WDHs with sway control usually are ok.
Techntrek, just curious, but why would you disengage the sway bars? I would think allowing the trailer to sway would cause it to "fishtail" easier. Keeping the trailer going as straight as possible on snow with slower speeds, less aggressive braking/steering, and common sense driving is the best advise anyone can give you. Good luck.
gfarmcafe is offline   Reply With Quote
Old 12-23-2014, 04:53 PM   #12
caper's Avatar
They recommend disengaging friction sway when the roads are slippery. This also includes rain.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 12-23-2014, 08:54 PM   #13
Maron
Send a message via Yahoo to Maron
Okay, I'm with gfarmcafe. Can anyone go into more detail as to why we should disengage sway bars in wet or snowy conditions...please!
Maron is offline   Reply With Quote
Old 12-23-2014, 09:13 PM   #14
mark0224's Avatar
This article from etrailer gives some explanation on why to disengage your sway control.
Using Sway Control in Slippery Conditions, Wet, Icy or Snow Covered and Gravel Roads | etrailer.com
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 12-23-2014, 10:09 PM   #15
Maron
Thanks Mark but that article seems specific to the Curt # 17200, whatever that is. I don't have that unit but I'd do have great sway bars & they work great.
Does anyone else have input on the use of sway bars in wet, snowy or gravel conditions?
Old 12-24-2014, 05:07 AM   #16
cpaulsen's Avatar
The law for Oregon and California is..chains on the tow vehicle and chains on the trailer.
cpaulsen is offline   Reply With Quote
Old 12-24-2014, 06:35 AM   #17
It doesn't matter what model sway bar you own, read the directions, they all say to disengage them in slippery conditions.
From the Reese instructions:
When towing during slippery conditions such as wet, icy, or snow-covered roads or on loose gravel, turn on/off handle counterclockwise until all tension is removed from unit. Failure to do so could prevent tow vehicle and trailer from turning properly.
http://hitchpro.com/application/supp...ons/N26660.pdf
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 12-26-2014, 09:40 AM   #18
I towed through the Blue Mountains last winter (Oregon, I-84)
The road was solid snow pack. 25 mph in 4wd was the fastest I was comfortable driving.
BobandArlene is offline   Reply With Quote
Old 12-26-2014, 09:43 AM   #19
Define what the difference is between a "sway bar" and a "sway control"
I'm familiar with the friction style sway control device commonly used with a weight distribution hitch.
Old 12-26-2014, 10:23 AM   #20
Denver, CO
garbonz's Avatar
2017 Fuse 23T
snow, towing
