Old 12-26-2014, 10:23 AM   #21
Denver, CO
garbonz's Avatar
Originally Posted by caper View Post
If chains are required you also will need chains on the TT tires. You will need the check the rules for each state that you are going to be driving through.
2017 Fuse 23T
Old 12-26-2014, 10:33 AM   #22
Denver, CO
garbonz's Avatar
Does anyone know the actual REASON the sway control needs to be disconnect. It doesn't make any sense to me, and I am an Automotive Engineer. I am not disputing it, just trying to understand it.
I know that weight distributing hitches makes a jacknife more possible as it reduces the weigh on the rear wheels, but I can't imagine what the sway control can do to make it morehazaedous.
Hmmmmm.
2017 Fuse 23T
Old 12-26-2014, 10:47 AM   #23
caper's Avatar
Hmmmmm.
With sway bars set tight the trailer might not turn properly on slippery roads. The trailer might slid sideways instead of turning. the reason for sway bars is to prevent the trailer from turning(sway).
As per chains on the trailer, when driving through the mountains on the west coast, if chains are needed they must be installed on the TV plus the trailer.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 12-26-2014, 04:46 PM   #24
Denver, CO
garbonz's Avatar
must not be tru for Colorado as the trucks don't chain up the rear trailer tires here.
2017 Fuse 23T
Old 12-26-2014, 08:29 PM   #25
Originally Posted by techntrek View Post
It doesn't matter what model sway bar you own, read the directions, they all say to disengage them in slippery conditions.
From the Reese instructions:
When towing during slippery conditions such as wet, icy, or snow-covered roads or on loose gravel, turn on/off handle counterclockwise until all tension is removed from unit. Failure to do so could prevent tow vehicle and trailer from turning properly.
http://hitchpro.com/application/supp...ons/N26660.pdf
Equal-i-izer never states in their installation, or operators manual to disengage the sway bars. What it states is "Over adjustment is a very dangerous situation where loss of control and
jack-knifing is possible, especially in wet or slick road conditions." In talking with our dealership who installed the Equal-i-izer, they do not recommend disengaging! Jack-knifing is very different "from turning properly", and jack-knifing is the one condition that must be prevented on any kind of surface condition.
gfarmcafe is offline   Reply With Quote
Old 12-26-2014, 08:34 PM   #26
HONDAMAN174's Avatar
I would (am myself) going to look into a set of cable chains. SCC makes them in a z pattern so a portion of cable is always touching the road surface. It is the most recommended design with the advent if vehicles with anti lock. "In theory" should be good for trailers too. Right?
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 12-26-2014, 09:23 PM   #27
DDC
DDC's Avatar
Take your time and use some of that rare commodity 'common sense". I don't find snow that bad but ice or freezing rain is not worth trying.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 12-26-2014, 09:41 PM   #28
jtstromsburg's Avatar
Yes ice is bad... See my last post for more info
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 12-26-2014, 10:08 PM   #29
Check this post that's on-going right now:
Sabre for sale. Extremely cheap!
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 12-27-2014, 12:20 AM   #30
New to Forest River
Roving Ron's Avatar
I am comfortable with driving in the snow on level ground or up hill. It's the downhill with 7800 lbs behind me that worries me.
Grey Nomads, Ron and Sue
Grey Nomads:l Ron & Sue
Roving Ron is offline   Reply With Quote
snow, towing
