Old 02-05-2016, 11:42 AM   #1
Towing Opinions Needed
Please let me know your opinions on the following set up
2015 Chevy 2500HD 4x4, 4dr., LTZ, 6.0 gas
GVWRC - 9500 lbs.
GCWR - 20500 lbs.
Factory tag for max payload - 2790 lbs
CAT Weighed Numbers On Truck with me and full tank of fuel -
Front Axle - 4020
Rear Axle - 3140
GVW - 7160
Trailer Options -
Cougar 336BHS
Dry Weight - 10595
Hitch Weight - 1895
Payload - 1695
Primetime Crusader 337QBH
Dry Weight - 10601
Hitch Weight - 1631
Payload - 1430
I am planning on purchasing the B&W companion RVK3500 or RVK3400 slider if needed as I have the 6.5' bed. I pull a gooseneck at this time but have never had any issues with the trucks abilities. I have also noticed several people on this forum with similar TV and heavy pin weights. What has been your experience with that combo?
GADuv is offline   Reply With Quote
Old 02-05-2016, 06:06 PM   #2
CWSWine's Avatar
I added 250 lbs since you said you didn't have hitch and this is what I come up with.
You have 2,590 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded trailer weight of 10,360 - 12,950 lbs.
WARNING that is loaded ready to camping weights not the weights posted on the websites or on the 5er. Best to add 1000 to 1500 lbs ( more depending on your how much you plan to bring camping) to the Dry Weight/Shipping Weight and use those numbers. You still need to say within you towing limits also.
Link to the numbers --- Towing Calculator after getting weighed - Towing Planner
2017 Solitude 310GK-R Pick Up Oct 24th.
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
Sold - 2014 Cougar SGS
Sold - 2013 Jay Flight TT
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is online now   Reply With Quote
Old 02-05-2016, 06:16 PM   #3
nomad297's Avatar
I believe you're cutting it pretty close, but if you load carefully, you may be ok.
Old 02-05-2016, 06:34 PM   #4
I am probably going to go with the Andersen hitch to save some weight since I already have the B&W turnover ball. I believe the aluminum model is 40 lbs total.
