Old 07-07-2015, 10:11 PM   #1
Lon
Lon's Avatar
Towing Oscillation
I'm towing a Minilite 2304 with a Chevy Silverado and a 350 cid engine off a standard bumper pull which is obviously not adequate. I pull my horse trailer with two horses and no problems but not my Minilite. When on the interstate the Minilite seems like a gigantic spring pushing and pulling the truck down the road. Also the camper is slightly down angle dragging the chain so that I have to tape up the chain like an athletic supporter :-) On a rainy day the weight on the bumper takes enough off the front wheels that the truck frequently hydroplanes. My question is would a load equalizing hitch fix this problem and if so what hitch do you recommend? Or should I just buy a bigger truck? Thanks
Lon is offline   Reply With Quote
Old 07-07-2015, 10:15 PM   #2
Done with this
Put a good weight dist hitch on it! No more wheelies.....
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 07-07-2015, 10:18 PM   #3
GuppyWN's Avatar
Yes! Plus you can then have the ability to add a sway control bar.
GuppyWN is offline   Reply With Quote
Old 07-07-2015, 10:26 PM   #4
Equalizer--problem solved.!!!
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 13 days
mogman is offline   Reply With Quote
Old 07-07-2015, 10:30 PM   #5
Christian_D's Avatar
Agree with the above... Definitely a weight distribution hitch with sway control.
I learned a lot poking around the etrailer site. They provide good information and helpful videos. Trailer Hitches, Fifth Wheel, Ball Mounts, Hitch and Towing Accessories - etrailer.com
Christian
Reno, NV
2015 Georgetown 270
Days Camped 2015: 40
Days Camped 2016: 03
Christian_D is offline   Reply With Quote
Old 07-07-2015, 10:32 PM   #6
asquared's Avatar
Get a good weight distribution hitch with integrated sway like equal-i-zer or Reese dual cam. Take the time to set it up properly. Towing will be a night and day difference for you.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-07-2015, 10:33 PM   #7
asquared's Avatar
Oh and as for the chains you can shorten them.
2014 Sabre 34REQS-6
Old 07-07-2015, 10:38 PM   #8
I can't emphasize enough the importance of learning to use the WDH properly.....both for effectiveness and personal safety. Maybe someone can go through it with you once you get it??
I agree with the above.....it'll make an amazing difference.
Christian
Reno, NV
2015 Georgetown 270
Old 07-07-2015, 11:51 PM   #9
Left Coast
For the chains, you can also just twist/wind 'em up some.
Old 07-08-2015, 09:36 AM   #10
thetanu539's Avatar
This would be solved by just about any WD Hitch. I personally have a Fastway E2 Trunnion 2-Way Sway control hitch and it is great. If I had ti to do all over again I would but the Fastway Equal-i-zer 4-Way hitch. This is a great debate as everyone seems to have a favorite. Anderson makes a good one, Blue Ox makes a good one, if you want to spend thousands (I don't) ProPride makesa GREAT one. I say middle of the road ($400-600) variety is sufficient.
Randy
14 PT Avenger ATI 27BBS
09 Nissan Armada
Central Ohio
thetanu539 is offline   Reply With Quote
towing
