Old 07-21-2013, 08:32 PM   #1
towing power
Does anyone have a 327ck wildcat fifth wheel? Am interested in what you tow it with. We have a 2013 Chevy 3/4 ton HD 4x4. The camper pulls nice on flatter roads, but pulls kind of hard going up hills. Any info would be appreciated.
Wildcat327ck is offline   Reply With Quote
Old 07-21-2013, 09:04 PM   #2
aka Windjammer2012
Crankshaft's Avatar
You don't mention whether it's gas or diesel. I really don't know how experienced you are because we don't know each other so I'm just asking the question of do you use the "Tow/Haul" feature? I have a '04 GMC diesel that probably has too much power but I still use the Tow/Haul feature.
Wayne & Vonnie
Layla (American Eskimo dog)
2012 Windjammer 3008W
2004 GMC 2500 HD CC Longbed
Crankshaft is offline   Reply With Quote
Old 07-21-2013, 11:19 PM   #3
wyo700's Avatar
If its pulling hard going up hills I can almost be sure he has the 6.0 gasser. Just part of pulling with a gas engine. Gotta know how to drive them high Rpms are common but done right is no problem.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 07-22-2013, 07:07 AM   #4
Oakman's Avatar
X2!
Gas engines are designed to produce the maximum horsepower and torque at high RPM’s, usually around 4500 to 5700 RPM’s. Many drivers find the sound of the engine a bit unnerving when running this high and tend to drive slower than they have to going up hills. The 6.0 Vortec engine produces maximum HP at 5400 RPM’s and maximum torque at 4200 RPM’s. When you’re climbing hills, don’t be afraid to run at high RPM’s with the gas engine.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 07-22-2013, 07:25 AM   #5
Camper Less Camping
Cajun Po-Boy's Avatar
That camper as a GVWR of 12K lbs...if your Chevy is the 6.0, I bet you do feel it having some struggle going vertical.
As others stated, you must get the rpm's up in the 4500 range or higher to utilize all the torque/HP in the chevy gasser to get some pulling grunt
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 07-22-2013, 07:26 AM   #6
Towing power
We have a 6.0 gasser. We use the tow-haul feature. Thanks for the info everyone, it was very helpful since we are new at this. Appreciate any helpful hints from you.
Old 07-22-2013, 08:02 AM   #7
jevanb's Avatar
I know your feeling, went from a 04HD 6.0 to a 06HD diesel night and day towing, the first time it went into 3rd to climb a hill the next week I had a brand new truck in the driveway. it was great on the flats but hit anything remotely like a hill with a load and the engine sounded like it was coming thru the hood
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 07-22-2013, 08:11 AM   #8
My 8.1 produces max torque at a lower 3200 rpm instead of the normal gas engine of 4200 to 4500 rpm. The 8.1 doesn't have to wind up to get its torque. I wish GM still installed that engine. I would get it again on the new generation.
TV:2006 Chevy 2500HD 8.1 Vortec - Allison Tran
TT: 2014 Wildwood Heritage Glen 300BH
11XLITE28BH is offline   Reply With Quote
Old 07-22-2013, 08:16 AM   #9
jevanb's Avatar
the 8.1 is a beast, brother inlaw had 1 in a avalanche and it smoked the tires off. my LBZ makes it max tq at 1600 rpm and I can tow all day in the hills in that gear add a few large ones and it might drop into 5th or I make it go if I need the egt`s to stay in check
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 07-22-2013, 08:33 AM   #10
Camper Less Camping
X2...wish they still offered this engine, so much better than the current GM gas engine ( 6.0 is such a disappointment for the HD truck line).
