Old 04-07-2014, 06:19 PM   #1
Towing Problem
I recently purchased a 2006 Rockwood Roo 21ss. I am having towing issues I think due to air drag. My tow vehicle is a 2006 Ford Expedition Eddie Bauer 4x4 with the 5.4 V-8. I thought that my truck would walk away with this relatively light trailer, but it struggled to get to 65 mph on relatively flat ground.
Any suggestions or similar issues? I have pulled heavier trailers in the past with a Chevy Suburban with a 350. Never experienced this before.
Captain110 is offline   Reply With Quote
Old 04-07-2014, 06:45 PM   #2
davel1971's Avatar
have you towed this trailer with any other vehicles? That truck shouldn't have a problem with that size trailer. Check to see if any brakes dragging on trailer. Is all your maintenance up to date on truck, fuel filter, etc.
David & Lynn
Old 04-07-2014, 06:50 PM   #3
2007 WildCat 32QBBS
18CrewDually's Avatar
A Roo should be no problem for a 5.4l. You may have issues with the vehicle such as a partially clogged catalytic converter or low fuel pressure. Keep us posted...
18CrewDually is offline   Reply With Quote
Old 04-07-2014, 07:34 PM   #4
bikendan's Avatar
with only the 5.4 engine for info, you don't state what the rear end ratio is, nor if it has the factory HD tow package.
it may have a high mpg rear end ratio, that's lousy for towing.
the 21SS is on the heavy side for hybrids, due to the big superslide.
are you using a good WDH with sway control?
Old 04-07-2014, 07:37 PM   #5
dieselbobcat's Avatar
Pulled a 2011 Roo 23SS with a 04' Expedition Sport 5.4L for almost 6,500 miles... never a problem maintaining 65mph... Bad mass air sensor maybe?
2021 Cedar Creek 37MBH
2020 F350 Powerstroke Super Duty Lariat Crew Cab
Northern NJ - God Bless America!
dieselbobcat is offline   Reply With Quote
Old 04-07-2014, 07:41 PM   #6
davel1971's Avatar
the lowest towing capacity for a 5.4 4x4 is 6000 lbs so no way that trailer is anywhere near its limit
David & Lynn
Old 04-07-2014, 07:53 PM   #7
Thanks everyone. Yes,the truck does have the HD towing package. I don't know what the rear end ratio is. Just bought it! It's not showing any codes. I guess I better take it to a mechanic to have it looked at?
I have a Fastway E2 Roundbar 6000lb hitch. Trailer wt is approx 3800 lbs empty.
Old 04-08-2014, 04:40 AM   #8
Engineer of Crazy Train
ChooChooMan74's Avatar
I sometimes wonder what people expect from towing a camper. My 21BH, although lighter, has the same frontal area as your trailer. I maintain 60 with my 2.8l, which IMHO, is a good towing speed.
Sent from my Samsung Galaxy Note 2 using the FRF mobile app.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 04-08-2014, 06:17 AM   #9
chicagoslick
chicagoslick's Avatar
Exhaust
Intake
Poor Tune-up,
Bad gas
Rear end gear
Transmission issue
Trailer dragging brakes
Low inflated Tires
Way too many possibilites...Mechanic good idea...Has the vehicle ever pulled loads in the past without issues?
Gary, Tonia, Baile, Summer and Otis our Boston T.
Flagstaff 27RLWS Emerald Pkg
2015 Ford F150 King Ranch FX4 Max Tow 3.5EB, 3.55
Equalizer 4 WDH, 1,200 / 12,000Lbs
chicagoslick is offline   Reply With Quote
Old 04-08-2014, 05:00 PM   #10
Towing Problem
Well, I jacked up the Roo, and all fuor wheels spin freely. I was hoping that the camper was the problem. Now I'll have to dig into the Expedition!
ChoochooMan74, I appreciate your comment, but I am not a novice to towing. That's why I'm stumped by this problem. Good to see ya spending lots of family time!
BTW, I checked with a Ford dealer to see what having new plugs installed would cost. $600 plus $35 each if the plug breaks! The rest of the replacements I think I can do myself, but now I'm apprehensive about tackling the spark plug replacement!
Thanks to all for your help!
Old 04-08-2014, 05:03 PM   #11
Resident Masshole
force's Avatar
Let them do it, trust me. I tried replacing my plugs (2004 F150) at about 75K miles, and broke the first two in half. Known issue w/ the Ford's (they rust into place basically), they have a tool to deal with it.
EDIT: they did mine for around $200, but I had already bought the plugs. $600 sounds like WAY too much.
Tom F.
2013 GMC 2500HD SLT Crew Cab
2013 Rockwood Roo 23SS
Nights camped in 2014: 8
Nights camped in 2013: 30
force is offline   Reply With Quote
Old 04-08-2014, 05:44 PM   #12
2007 WildCat 32QBBS
If it was plugs you would feel the miss and it would shake the whole vehicle and throw a light. I'd check for air restriction like a clogged air filter or the clogged cat or muffler. Both conditions will cause power issues but never throw a check engine light. Air cleaner and the box it mounts in is easy enough to look for mice nests or just a dirty filter. The exhaust I usually disconnect before the cat and road test (yes it's loud). Or you can drill two 1/8" holes, one before/one aft the cat, and do a back pressure check with a gauge. There should not be a huge difference in your readings.
All this might be overwhelming for many, so you may want to take it to a reputable mechanic. I'd hold off on dropping 600 bucks on plugs.
Old 04-08-2014, 05:53 PM   #13
davel1971's Avatar
The plugs will definitely let you know via misfires and a CEL when they need attention. I would start with an air and fuel filter, then fuel pressure checked and exhaust restriction.
David & Lynn
Old 04-12-2014, 10:54 PM   #14
Our 2010 F-150 5.4 used to pull a 28 foot Bullet and we downsized to a 24 foot Wild Cat. (empty weight on the Wild Cat is 6,000 just a bit over the Bullet. The 5.4 seems to take care of this just fine.
Brandon 2
brandon 2 is offline   Reply With Quote
towing
