Old 10-11-2017, 07:11 AM   #41
rsdata's Avatar
Looking for a truck that is able to handle a travel trailer Cherokee 36ft 7900 dry weight. In general, Will a 150/1500 model truck handle the load?
Another thing to look at when sizing your next tow vehicle is... What is the primary purpose for the vehicle? Is it also a daily driver?
gas consumption, ride comfort all come into play when towing is only a secondary consideration...
If your usage is 30-50% towing and your trips are long and over mountains, then get a 2500. If you keep your tow vacations close to home and don't plan on anything much over several hundred miles from home in fairly flat land and the truck is a daily driver then get the 1500 for better mileage and easier ride when not towing. If going the 1500 route, then payload capacity is the number that you will bump into... 1500's generally have the towing capacity but not always the payload as others have indicated.
2014 Shamrock 183
Old 10-15-2017, 05:47 AM   #42
Wow! There is a lot of misleading advice here. You need to do your homework and research and find the truck that work for you. You DONT need a diesel and you don't need a true 3/4 ton truck. A properly equipped 1/2 ton can get the job done well. Today's Daily Pick had a thread about a guy pulling a fifth wheel with his Tundra. Several Ford and Chevy 1/2 ton owners then piped in with their fiver experiences.
My 07 Tundra CrewMax with the 5.7 hemi, 6 speed tranny and tow package can pull a little over 10,000 pounds and has a cargo capacity of 1,600 pounds. That's stock and it's classified as a 1/2 ton. I think you'll find Ford and Chevy trucks with the tow packages and big V8s will spec out in the same neighborhood.
Just do your homework and stay within specs. You don't need a diesel.
2 in a Roo is offline   Reply With Quote
Old 10-16-2017, 06:07 PM   #43
larry2c's Avatar
So the OP says his TT has a dry weight of 7900 #'s. Just to make it easy let's say he adds 1000 of camping stuff in his TT so now his TT weighs 8900 lbs. Average tongue weight is 13% of the trailer weight so that means the TT uses around 1157 lbs of the truck's cargo limit. Take away around 90#'s for the WDH and you are down to 353#'s left for wife/significant other, kids, dogs, snacks and anything else that you might want to carry. Ooops, you've exceeded your cargo limit - and for most half ton trucks that is where they come up short. Not the tow capacity but the cargo capacity.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
larry2c is offline   Reply With Quote
Old 10-16-2017, 06:14 PM   #44
Who Dares, Wins
doc73's Avatar
This is the sad truth and why people seem to hate the weight police... You run out of CCC (payload) LONG before you ever hit your towing capacity. But no one seems to remember this (or wants to remember this is more like it).
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 10-16-2017, 08:01 PM   #45
SailorSam20500's Avatar
My view...
No knowledge on 1500 capabilities.
F-150 with max payload package (gets payload limit over 3,000 lbs), max tow package, and a 3.5 EB engine would likely work. You would likely be inside all the max weight issues. If not max payload - you need to stay with a lower trim level and, as others have stated, really pay attention to payload (lots of >2014 Lariat and XLT trucks are > 1,900 lbs - see spreadsheet available in a payload thread on the F150forum.com). The 3.5 EB engine will comfortably pull a heavy trailer.
I've read a number of posts that a 1/2 ton doesn't have the brakes to stop a heavy trailer. Personally, I expect the trailer brakes to stop the trailer and doubt even a 1 ton would do the job in many cases if the trailer brakes fail. Also, I've been surprised that the idea of upgrading the trailer installing disc brakes doesn't show up regularly (reported cost of about $2k). Seems to me that that would help a lot with the stopping issue and support use of a 1/2 ton as a daily driver.
I would spring for the safest WD hitch you can afford and recommend the Propride or Hensley if you decide on the 1/2 ton truck.
YMMV...
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 10-16-2017, 08:12 PM   #46
llr
I would not buy any 1/2 ton to tow that size. If you already had a well equipped 1/2 ton you c it try it carefully. Since you don't have a truck now you could wind up buying 2 trucks if the 1/2 ton is not working.
I have a similar size and weight trailer and start with a f150, power was OK, it just never felt stable and safe. I went with a 3/4 after 3 short trips, much better
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
llr is offline   Reply With Quote
Old 10-16-2017, 08:46 PM   #47
Here's a little note. My 2018 Cherokee is 7914 dry, 900 hitch, and a gross of 11,060. (3146 cargo cap) Towed home dry with 2013 Silverado 1500 crew. Hill with stop light outside dealer. To get thru light I hit 6000 rpm's to top hill. Month later towing home from dealer with 2014 GMC 2500HD diesel and all our camping gear in trailer. Hit same light and was at 1900 rpm's when I topped the same hill.
My Two cents.
TheWolfPaq82 is offline   Reply With Quote
Old 10-22-2017, 04:22 PM   #48
My Two cents.
Just goes to prove that the gasser will get you there just like the diesel!
joshuajim is offline   Reply With Quote
Old 10-22-2017, 04:34 PM   #49
My god.
That's the example you choose to prove your point?!
WERA #13
'17 Work and Play 25WB
'11 F350 DRW
T11ravis is offline   Reply With Quote
Old 10-22-2017, 04:46 PM   #50
I just can't for the life of me figure out why people keep quoting dry weights. Their trailer never weighed that and never will!
DRY WEIGHTS ARE FOR SUCKERS!
2011 Traverse LT, 3.6L, FWD
Old 10-22-2017, 05:22 PM   #51
Insert witty title here
Use the GVWR of the trailer when deciding how much tow vehicle you need.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 10-22-2017, 06:02 PM   #52
Originally Posted by T11ravis View Post
My god.
YEP, it definitely proves that the gasser will get you there just like the diesel.
Old 10-22-2017, 06:36 PM   #53
My Two cents.
That's a lot of RPMs. WOW.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 10-22-2017, 06:52 PM   #54
Canadian Member
The OP decided what they are going to get in Post #12. How did this thread get to over 50 posts!?
Old 10-22-2017, 06:53 PM   #55
Towing question
Becasue as of this post, 44 more messages have been posted.
Old 10-22-2017, 06:56 PM   #56
Canadian Member
Originally Posted by timfromma View Post
Becasue as of this post, 42 more messages have been posted.
...because most of those 42 other posters didn’t bother to read the first 12 to discover that the OP has already made their decision!
towing
