Old 06-17-2015, 11:07 AM   #11
Ret E-9 Anchor-clanker
donanddona's Avatar
X2 on DF5.4 !!!
donanddona is offline   Reply With Quote
Old 06-17-2015, 12:02 PM   #12
roadmaven's Avatar
Thanks for the input on tires. I typically run mid 30's on my pressures in the Sequoia. Sorry for my ignorance on this, but I've always just followed the factory PSI that's on the door when towing. The Continentals I have show a max PSI in the sidewall of 44. When I get the call from the dealer that the Shasta is ready to pick up, I'll pump them up to 44 and see if it behaves differently on the drive home.
As for going to LT tires, is there any particular brand/style that's a favorite? Hate to put out $1k on a new set of tires when the ones on there are less than a year old with maybe 6k miles on them, especially without knowing if it's going to fix my wiggle.
Pat B.
Speedway, IN
2016 Shasta Oasis 18BH
roadmaven is offline   Reply With Quote
Old 06-17-2015, 12:10 PM   #13
I would bump them to 44 and see how it goes. I towed my vibe with a minivan and needed to bump up the pressure to reduce the movement in the rear. I find it interesting that north american and Japanese cars only have one pressure listed. The European cars I have had , had two pressures, one for normal load and higher for full load, they also recommended upping the pressure for high speed driving.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 06-19-2015, 10:25 AM   #14
The sway control has an adjustment. You may not have enough tension on the bar. Tighten the adjustment to several positions while driving around and see if that does the trick
trackmanbfa is offline   Reply With Quote
Old 06-20-2015, 02:50 PM   #15
dsjohns71's Avatar
I have the same tires as you. They are a pretty stiff tire and seem to last as I have about 40k miles on mine and are hardly worn. I air mine up to 42 psi while towing and they seem to handle better. My next set will be LT tires and I really like the Michelin LTX AT/2. I also have 20" wheels.
dsjohns71 is offline   Reply With Quote
Old 06-20-2015, 09:41 PM   #16
B and B's Avatar
x2 on the Michelin LTX AT/2. Great rubber. Noisy but the stick to the road!
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-21-2015, 03:59 AM   #17
Just a member
kandl's Avatar
The wheel base on the Sequoia is 119", which is somewhat on the short side for a full size SUV. Just wondering if this is my problem...
Pat, I think you nailed it. And no conventional WDH/sway control is likely to cure your woes. LT tires and/or increased tire pressure can help but ultimately the size differential between your TT and the Sequoia will manifest in some undesirable handling characteristics. If you're intent on keeping the Toyota, a ProPride or Hensley hitch could rectify many of these handling issues. However, they're pricey and won't negate that fact that your TV is likely just a wee bit too small (wheelbase) to comfortably tug you TV.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 06-21-2015, 05:28 AM   #18
fmc
fmc's Avatar
I had the Blue Ox hitch with my TT. It work very good but as you say from time to time I noticed some sway.
fmc is offline   Reply With Quote
Old 06-21-2015, 06:00 AM   #19
Might be the camera angle, but it looks to these old eyes that the trailer is a little high in the rear and the tv a little low in the front. IF, that is the case, you need to raise the hitch head and lower the tension on the bars. LT tires are a must! You can sell the P's on Craig's List to offset the cost of new ones.
Old 06-21-2015, 07:09 AM   #20
One caution. I have not seen any discussion of hitch capacity. With 530lb tongue weight posted, you most likely have a hitch rated to tow only 5000lb. My $.02.
Travel safe
2001 Ford F-350 Super Duty CC Dually, 7.3 Diesel
2011 Cedar Creek 36CKTS Touring Edition
FordHauler is offline   Reply With Quote
towing
