Old 06-16-2015, 08:45 PM   #1
roadmaven's Avatar
Towing Question
Have a question for some of you experienced towers of longer trailers. My experience prior to our 29' Oasis 25BH was a 15' T@B and a 16' Scotty. Never needed a weight distribution hitch for either and never knew either trailer was back there when hauling.
However, since doubling the length of my trailer, I'm experiencing some things when hauling that I'd like to get opinions on. First, I've got the Blue Ox Sway Pro weight distribution hitch. The Shasta is completely level when on the hitch. My tow vehicle is a 2003 Toyota Sequoia. When I'm on the interstate and I've got a 18 wheeler passing me, I can feel some instability from the force of air that the semi is pushing against the trailer, all the way until he passes me. It gets to where in most cases I need to completely back off the throttle to 1.) let him get by faster, and 2.) to gain some stability. Since I'm new at hauling a longer trailer, is this sympton "normal"? I've had so many thoughts into this that asking for personal experiences will be my first...and cheapest...option as to fix this. The wheel base on the Sequoia is 119", which is somewhat on the short side for a full size SUV. Just wondering if this is my problem, or if in fact it could be normal. Or maybe I could stand to try a different WDH. Or maybe getting a different tow vehicle with a longer wheel base.
Thanks in advance for all your insight!
Pat
Pat B.
Speedway, IN
2016 Shasta Oasis 18BH
roadmaven is offline   Reply With Quote
Old 06-16-2015, 09:11 PM   #2
All the things you mentioned would certainly help, but with your current setup you might still be able to tweak it. And no.. it's not normal or safe to be getting pushed around like that.
The first thing I would do is to find out exactly what my pin weight is. If it's too light and you have a heavy rear... that could certainly lead to excessive sway. I would also drop the nose of my TT to level or just slightly down.. maybe 1/2" or so. You also want to check that your hitch is installed and fine tuned. I can't tell without a picture...
You might "also" be heavy on the pin for your particular TV. I dunno.. didn't catch any weights. If your light on your front axle and your TT is rear heavy I wouldn't be surprised if your rig wasn't waggin your TV. :-)
rana is offline   Reply With Quote
Old 06-16-2015, 09:23 PM   #3
Tonkatoy77's Avatar
What kind of tires do you have on the Toyota?
2007 Chevy Duramax EFI Live and other supporting mods.
2015 Wildcat Maxx T26BHS
Nights camped 2015....23
Tonkatoy77 is offline   Reply With Quote
Old 06-16-2015, 09:26 PM   #4
My initial thought was the wheelbase of the suv. I normally drive short box crew cab trucks and have had those issues. I am not familiar with your hitch system, but I know it is up in quality compared to other hitches. I will say that every hitch system I have had the dealer install had to be readjusted by myself. I would suggest reading the manual and doing the measurements and hookup yourself. Check out some videos on youtube or etrailer. Another issue may be the passenger tires if you have issues with rear having a spongy feeling.
2013 Salem 30KQBSS TT
Equalizer 4pt Hitch system-12K
2016 Ram 1500 Crew Cab Sport 5.7 Hemi w/8 Speed
Great Laker is offline   Reply With Quote
Old 06-16-2015, 09:55 PM   #5
roadmaven's Avatar
Great Laker: The dealer hooked up the WDH for me when we picked up the trailer. It was waaay out of whack...not level whatsoever! I got the hitch properly adjusted based on a very helpful etrailer video. My front wheel well height was the same height prior to hitching up compared to after I hitched up with the WDH.
Tonkatoy77: The tires are Continental CrossContact "EcoPlus" 265-65-R17.
Yarome: Weights are something I'm looking into. I took advantage of etrailer's sale on tongue weight scales last week. The trailer's currently in the shop for some warranty work, so I can't weigh it just yet, but the payload on the Sequoia is a paltry 1300lbs. The factory weight on the tongue is 530, but with the battery and dual propane tanks I'm sure I'm well over 600. The bars I have for the WDH are rated at 750 lbs. Not sure if going up to 1,000 lbs bars would help or not.
Here's a pic of the trailer & SUV hooked up. Nice & level.
Also, here's the setup of a Blue Ox. This is the installation video I followed to hook up mine, and I'm confident everything is hooked up correctly:
One of the cheap things I'm going to try is hooking it up to my brother's '04 Silverado. Basically trying that to see if by chance a TV with a longer wheel base helps, as it's some 14" longer wheel base than the Sequoia.
Pat B.
Speedway, IN
Old 06-16-2015, 10:15 PM   #6
B and B's Avatar
I know the Toyota is a daily driver but putting LT tires will help with sway and the yaw and roll feeling when a truck passes. I would also check the tongue weight as you have mentioned. If the water tank is rearward travel empty. I had a 32 Ft Rockwood TT on a F 150 and it handled like crap. I traded the truck and with the new heavier truck it was better but not great until LT tires where on the truck did stability improve. You have a good hitch, I do know the setup of this but possibly a local hitch shop can help.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-16-2015, 11:06 PM   #7
That looks pretty good.. um.. it might just be the angle of the photo, but it almost looks like your TV's rear is jacked up a bit (front axle looks like it's compressed). Again, it may just be the lighting and angle, but the back tires on your TT look like they might be riding a bit heavier than the front axle. You might try dropping the nose of your TT down just a touch.
Just tossing out ideas... You can't really do much to it until you have your weights. I'll be interested to see where your pin weighs out at.
A larger wheel base and heavier TV are definitely going to improve the handling, but if you don't take it out all that often, I don't know if it would be worth upgrading your TV. Your within you limits so there has got to be a tweak that will give you a little better handle on it.
LT tires are a good idea. That's a lot'a surface area to overcome though.
Old 06-17-2015, 06:38 AM   #8
DF5.4's Avatar
What pressure do you run the TV tires when you tow? I tow a 30'TT with a Ford Expedition. Same wheelbase as yours. When I had P rated tires on it I would air all the tires to max (50 PSI). I towed it once without airing them up and I could feel it squirming around. Luckily it was across town to get the TT inspected. I would never do interstates like that. I just replaced them with LT this year. I still run them about 35 PSI empty. I don't think it rides any harder. In fact i think it rides and handles better. I've only towed with them a couple of times this year but I air them up the 55 PSI when I did. It made a huge difference compared to the P rated tires.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 06-17-2015, 07:12 AM   #9
acadianbob's Avatar
Bigger bars are not going to help you. Your rig looks nicely adjusted and level. Sway is the issue. It may come down to the wheelbase of your tow vehicle and the tires.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 06-17-2015, 09:09 AM   #10
Phat Phrog Stunt Crew
elind's Avatar
I was pulling a 35' TT @ 7000 lb with a GMC 1500. I had a cheap no name hitch with a friction sway control on it.
First make sure the air pressure on all the tires is at their max inflation. Then make sure the TV is has proper weight on each axle by dialing the hitch to lift the rear to add the weight to the front axle. You can do this by measuring the height of top of the wheel well front and back without the TT and with the TT. The key is that the front wheel well height stay the same or even be lower. After you find the right setting then set your TT height to look level. After that loading the TT could be adjusted to keep the balance in order. The next option is LT tires to tight up the tire roll.
The bottom line is to learn the limits of your equipment. Like the time you see a 40' FW towed by a one ton dually passing doing 70mph and you can't keep up. Just drive in your comfort zone and be safe.
2014 Wildcat 327ck
elind is offline   Reply With Quote
towing
