03-29-2014, 08:26 AM
#21
Originally Posted by goduc
Your low payload comes from all the bling on the Limited.
Yeah, ultimately, there tends to be a trade-off between bling and functionality.
Normally, I'm against exceeding the truck's ratings; but you might be able to manage this OK. It might help to keep as much of the load as possible in the trailer rather than in the truck. That way 10% of the weight goes against your payload rather than 100%.
If you decide to go ahead with your plans, keep your family safe with reduced towing speed. Good luck. Happy camping.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
03-29-2014, 08:44 AM
#22
Originally Posted by OldCoot
If you have (4) LT LR D or E tires, I wouldn't worry about it.
Nope, got the stock Ps. But I still don't worry about it. I trust them more than the Loadstars they put on my trailer.
Mind you when the time does come to replace them ( probably later this year) I'll be looking at LTs.
03-29-2014, 09:31 AM
#23
If your over your trucks gvwr I wouldn't worry about it. The only rating I would look at is the rawr which I'm sure you will be fine with. IMO if your under the rawr or right at it and over gvwr and still under fawr how does the truck know the difference. As for you only being at 6000-6400 loaded with your ecoboost you won't have a problem one pulling that. I think once your all hooked you'll realize everything will be fine. I have a tundra and a toy hauler which my biggest concern is staying under my campers gvwr now that I have a sidexside. I already know I will be right at my trucks gvwr if not slightly over but I know I'm at 100 pounds under rawr and I now have E rated tires. I know my truck is more than capable enough to do more if I wanted. Get your camper get you hitch set up properly load the family and go camping.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
03-29-2014, 10:06 AM
#24
Denver, CO
To illustrate the difference between Payload and rear axle ratings. My chebby 2500, when I first weighed it was 460 lbs OVER on payload (2220 pin weight) and yet still 640lbs under on rear axle rating. The GVWR is 9200 lbs but the combined axle ratings are 10,754lbs. So IMO, if you are only over on payload, you should still be pretty safe. Be careful, leave plenty of distance in front for braking and don't worry.
2017 Fuse 23T
03-29-2014, 11:11 AM
#25
I have tosay, reading all these posts this morning makes me feel much better about my choice to purchase the 23IKSS rather than opt for a different trailer or trade in my truck that I just got last year.
Thanks for all the advise and look forward to picking our new Roo up in a few weeks.
I will defenetly be ready to go camping. My wife brought up the other night that we should pick up the camper and leave from the dealer to do an overnight trip. Can't wait.
I will post picks and let everyone know how it goes.
03-29-2014, 12:17 PM
#26
Camper Less Camping
That's why we are all here for on this Forum...no BS...real world answers!
2013 Sabre 32RCTS-6 (sold)
03-29-2014, 01:13 PM
#27
gspage53
Towing Question (Payload) 2013 F150 Limited
I have a 2013 F-150 XLT 4WD with the extra tow package. We bought a 31 ft winnebago TT with a 900 lb Tongue weight. With a Husky hitch it rides 6 inches off the ground. I've been very disappointed with the ride and the ground clearance. Ford says you can add a Timbren suspension package but you run the risk of a harsher ride when the springs bottom out.
03-29-2014, 01:56 PM
#28
I have a 13 FX4 Eco max tow with every option. It would probably weigh very similar to your Limited. The max tow gives me around 400lbs extra payload. As far as I know your suspension is identical to mine. I would say the sticker is the limiting factor not so much the suspension.
03-29-2014, 03:11 PM
#29
strongly suggest you camp near the dealer or do a night of Camp Driveway.
you'll almost surely find some issues that may require being close to the dealer.
never recommend someone taking an untested trailer straight from the dealer, on a long camping trip.
03-29-2014, 06:04 PM
#30
You lost me with all those numbers but I have a f150 ecoboost and my camper is about 7200 dry...and I can't even tell if it's behind me..I have a 352 rear end..I'm rated at 9700 lbs...you should be around 11,300 with the 373 rear end
831RESS FLAGSTAFF
F150 FORD ECOBOOST
03-30-2014, 06:36 PM
#31
Disney camper
I just bought a 2013 f150 Ecoboost crew 4x4 back in sept and just took delivery of Solaire. Can't wait to see how it pulls the 26BHDSK.
I pulled the empty trailer home from the dealer with just me in the truck. It felt loose and all over the lane. I hope it's better when it's loaded. I have a sway bar and the truck has trailer sway control. So I don't know why the issue.
Any thoughts...
03-30-2014, 07:04 PM
#32
Any thoughts...
When I had my old camper I had an older hitch with a sway bar..it did test my truck's sway control system..worked great but you only want it to engage when the trailer's sway is excessive ...with my new camper I purchased the Equalizer 4 point sway control system..no sway at all...now my truck's sway control may never be used..which is a good thing..I'm towing about 7200 dry
831RESS FLAGSTAFF
F150 FORD ECOBOOST
03-30-2014, 07:17 PM
#33
Disney camper
I don't know the truck sway control works. I just noticed I huge control difference with the new truck. I had a 2006 f150 before and didn't have a control issue. I bought the ecoboost because of the higher torque and it's a 4x4.
Would the 1-3/8" higher ride height cause a control issue? Maybe I need to lower the WDH.
03-30-2014, 07:44 PM
#34
It basically slows the truck down when sway becomes excessive..I had a '97 150 2 wheel drive before I bought the Ecoboost..I did notice more sway with the 4 wheel drive...you don't want to rely on your trucks sway control system to control sway..it's only there basically as an emergency(swaying out of control)..I think there are threads on here on sway control
831RESS FLAGSTAFF
F150 FORD ECOBOOST
03-31-2014, 08:03 AM
#35
Wanna Be Camper
Most if not all your issues are probably due to your hitch not being properly setup for your new truck if there is a height difference in the hitch height. Get the hitch dialed in and then see how it tows.
John & Deb
2011 Flagstaff V-Lite 30WRLS
03-31-2014, 08:12 AM
#36
Disney camper
Great. I like this forum and all the good advice. Better than info from the get you outa there dealer
03-31-2014, 08:39 AM
#37
I've come to almost the same conclusion. My research indicates that the MaxTow has 3.73 gears, rear "GG" springs, "upgraded" receiver hitch, tow mirrors and a slightly different steering gear ratio(17:1 versus 20:1). My conclusion is that with the newer 6 speed transmissions, gear ratio has much less affect on towing capability. Trucks with 20" or larger wheels have the "GG" rear springs. The receiver hitch has no affect on payload. Steering ratio change I see as pointless? I added the tow mirrors to mine, added XL load range tires, air bags and am about to change out the shocks. I believe that in a head to head comparison my truck would fare much better than a stock Max Tow. A MaxTow would give slightly better acceleration numbers, but I think you'd see little difference in holding speeds.
03-31-2014, 06:56 PM
#38
Somethings wrong with your numbers. My 05 with a 5.4 3:73 has a gvwr 7200, gcwr 15000. max trailer tow of 9600. Max tonque wt 990. axles about the same.
Paul, Dawn, Brennan & Blake Kurek
2013 Coachman 292BHDS
2005 F150 Lariat SuperCrew 4x4
1 spoiled lab and 1 even more spoiled boxer
03-31-2014, 07:27 PM
#39
FYI,
Maybe some more info. you can use here.
Tow Vehicle Sizing
03-31-2014, 07:40 PM
#40
Originally Posted by Cajun Po-Boy
X2
X3
B and B
