Old 07-24-2015, 08:12 PM   #1
towing questions rockwood mini lite
Have a question wth towing my 2016 Rockwood Mini lite 2304KS. I have a 2014 Ford F150 5 liter V8 4 x 4, 3.55 rear end and the trailer towing package. Took my first trip with the camper and truck struggles to maintain Interstate speeds. The transmission is constantly shifting between 4th and 5th gear. Is anyone getting the same performance ?
jimjacobs62 is offline   Reply With Quote
Old 07-24-2015, 08:30 PM   #2
acadianbob's Avatar
That doesn't sound right at all. That's not a very big trailer. It would almost seem that the trailer brakes are on or dragging. You shouldn't have any problem pulling that trailer.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 07-25-2015, 06:29 AM   #3
Jhochst's Avatar
Do you have/use tow mode? I have a lite trailer and can accelerate up steep hills with my 5.7 hemi. No struggles at all
Sent from my iPhone using Forest River Forums and cruising speed is rock solid. It will not down shift unless going up steeper grade. Tow mode makes huge impact
Jhochst is online now   Reply With Quote
Old 07-25-2015, 06:40 AM   #4
Georgia Frog Rally 2018
aceinspp's Avatar
Sounds like you have not engaged the towing mode. Should handle fine. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-25-2015, 06:42 AM   #5
LandJ's Avatar
What is interstate speed? And how many gears in that tranny?
If you're traveling above 65mph, I'm not surprised that you're having trouble. I have a 2502 and usually tow at 63mph.
The trailer is a parachute, the faster you go, the more it resists.
John and Linda
2016 Rockwood 2604WS
2017 Ram 3500 CTD SRW
2016 - 47 nights
2017 - 47 nights
LandJ is online now   Reply With Quote
Old 07-25-2015, 09:57 AM   #6
Thanks for the tips. I have 6 speed automatic transmission and was in tow haul mode mode the whole time. Interstate speeds range 70 to 75 mph. I did check my trailer brakes after several miles and they were cool to the touch. I do have a manual shifter on the transmission, should I try using it for towing?
Old 07-25-2015, 10:13 AM   #7
etothepii's Avatar
Try driving at 100. Should improve a lot.
That's kph. About 62mph. For most gas trucks, 60-65 is the sweet spot. Drag does not increase linearly with speed. If I recall correctly, it is a square relationship.
Your RV tires may not even be designed to go above 70 mph. So that may be a safety concern as well.
2014 Rockwood 2306
Fastway E2 equalizing hitch
Prodigy P2 brake controller
2011 Ford F150 Ecoboost, Supercab
etothepii is offline   Reply With Quote
Old 07-25-2015, 10:23 AM   #8
LandJ's Avatar
Sounds like your truck is responding normally for the conditions you're creating. I would use tow/haul mode and stay below 65mph.
John and Linda
2016 - 47 nights
2017 - 47 nights
Old 07-25-2015, 10:34 AM   #9
Citrus County, Fl.
GL1800Rider's Avatar
Just my opinion but I would definitely keep it down under 65. If you have the China Bombs you are asking for a disaster!! If they are load range C, I do believe they are rated for a maximum of 65. You might also want to invest in a TPMS as they may give you early warning for a tire failure.
When I had the TT I usually ran between 55-60 in the interstate. Much less fuel being burned and a more relaxing trip. More than once I have seen either a 5er or TT pass me doing 70 or more and later found them on the side of the road.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 07-25-2015, 12:25 PM   #10
RVPP's Avatar
2013, F-150, V6 no eco-boost, tow mode, 60-65 NJ to Fl, towing a '04 FR Surveyor about 4300 lbs. It's not happy over 65MPH, and neither am I.
Safe trip, Paul
RVPP is offline   Reply With Quote
rockwood, towing
