The rating you need to be concerned about is the max cargo capacity as this one is usually exceeded before towing capacity. The max cargo capacity should be on sticker on divers door post. Start with cargo capacity then subtract TV passengers, Cargo, 100 lbs for WD hitch, The remaining amount is the max tongue weight the vehicle can haul. Keep in mind that just because the numbers may say you are within the limit, they do not guarantee towing will be an experience you want to do.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
