Old 08-17-2016, 04:10 PM   #1
Towing rating on Chevy Silverado
I have a 2004 Chevy Silverado with a tow rating of 4900 pounds. When I subtract people and cargo weight my tow capacity is 4500 pounds. I am looking at purchasing a travel trailer with an empty weight of 3910 pounds. I do not have a transmission cooler. Will IO have issues towing this trailer even though I will not exceed 4500 pounds?
doeagle2009 is offline   Reply With Quote
Old 08-17-2016, 06:35 PM   #2
bikendan's Avatar
Sounds like your Chevy doesn't have the factory tow package and it has a v-6 engine.
Also need more info:
Payload capacity
Rear end ratio
Engine size
What make and model of trailer are you looking at.?
And is the 3910 number from the trailer's yellow weight sticker or from brochure/website bogus numbers?
Equalizer WDH
Old 08-17-2016, 07:01 PM   #3
My Chevy doesn't have the factory tow package
Payload capacity:1554#
Rear end ratio:3.42
Engine size :4.6 L V6
What make and model of trailer are you looking at.? 2016 Coachman Freedom Express, 192 RBS
And is the 3910 number from the trailer's yellow weight sticker or from brochure/website bogus numbers? 3910# comes from subtracting maximum cargo (1990#) from GVWR (5900#). Trailer yellow sticker didn't have actual trailer weight printed on it.
Thanks!
Old 08-17-2016, 09:55 PM   #4
Tom
Seachaser186's Avatar
You could probably tow a pop-up camper. Even a small TT with the height would be a challenge with that vehicle.
Seachaser186 is offline   Reply With Quote
Old 08-17-2016, 10:24 PM   #5
dannyabear's Avatar
Yep, not nearly enough engine
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 08-17-2016, 10:33 PM   #6
aufinger's Avatar
You don't subtract people and cargo from your Tow Rating. Your Tow Rating is the max allowable weight of the travel trailer when fully loaded with cargo and water. You subtract people, cargo and tongue weight from your Tow Vehicle's available Cargo Capacity ensuring you don't exceed it. Larry G.
2016 Toyota Tundra 5.7L DC
2016 Flagstaff Micro Lite 23LB
USMC (Retired) 70-91
aufinger is offline   Reply With Quote
Old 08-17-2016, 10:39 PM   #7
bikendan's Avatar
That trailer will will be closer to 4400lbs when it leaves the factory and you add a battery.
NO trailer weighs its dry weight when it leaves the factory.
That number is for a stripped down version of the trailer.
Equalizer WDH
Old 08-17-2016, 10:44 PM   #8
CWSWine's Avatar
The RVSEF (RV Safety and Education Foundation) that has been weighing RVs since the 1993 disagrees with you and the you do subtract people and cargo from the tow ratings. Here is their training video explain how to match a truck to RV and how to figure your tow capacity ratings.
Matching Trucks to Trailers
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 08-17-2016, 11:06 PM   #9
GVWR for that trailer is 5900 lbs per the website below. That's the number you should be figuring with. Dry weight is a scam; it doesn't mean squat. The hitch weight is listed at 392 lbs, but I'm guessing that is dry also. Hitch weight should be 10-15% of total weight, so I'd figure it's really going to be 590 - 885 lbs.
Coachmen RV - Manufacturer of Travel Trailers - Fifth Wheels - Tent Campers - Motorhomes
I'm thinking you're pushing it.
2011 Traverse LT, 3.6L, FWD
Old 08-18-2016, 02:32 AM   #10
aufinger's Avatar
[QUOTE=CWSWine;1293073]The RVSEF (RV Safety and Education Foundation) that has been weighing RVs since the 1993 disagrees with you and the you do subtract people and cargo from the tow ratings. Here is their training video explain how to match a truck to RV and how to figure your tow capacity ratings.
Please tell me where I’m wrong. A truck has a GVWR. The combined truck’s Curb Weight, Cargo and Passengers cannot exceed the truck’s GVWR. A truck’s Tow Rating (Max Towing, Towing Capacity) is the allowable weight for a fully loaded towed vehicle. While in the video he’s backing out the weight of the passengers and cargo on a graphic showing both the GVWR and GCWR but not the tow rating as the OP asked about. He left everything left over as what the truck can tow. However, it’s my understanding that most trucks have a listed Tow Rating. In my case, my Tow Rating and GVWR equals my GCWR. My comment to the OP was based on information listed (on his door stickers and charts) for his truck to indicate that passengers and cargo in the truck determines if the truck exceeds the listed Cargo Capacity and GVWR, not necessarily to determine Tow Rating. If you go by the video, it suggests that you can exceed your listed Tow Rating if you do not max out your GVWR. I personally would suggest against advising someone to exceed any of their listed weights limits. Larry G.
towing
