Old 07-14-2014, 02:56 PM   #1
Question Towing Rockwood Roo 21ss with Acadia or Traverse
We just bought a 2006 Rockwood Roo 21SS and we are wondering if my wife's GMC Acadia can pull it effectively? By weight specs and towing capacity of the vehicle it should be able to do it but wanted to see if anyone out there has tried it?
weyant53 is offline   Reply With Quote
Old 07-14-2014, 05:42 PM   #2
RamsFan1's Avatar
What is the dry weight on the yellow sticker on your trailer?
2015 Chevy Traverse
2011 Chevy Traverse (traded 2018)
2014 Solaire 147X
RamsFan1 is offline   Reply With Quote
Old 07-14-2014, 08:28 PM   #3
Taybrynn's Avatar
What year and model Acadia ? It appears your two rating could be as high as 5200 lbs and payload as high as 1700 lbs. It appears to 21ss roo has a dry weight of 4600 lbs and a hitch weight of 500-600 lbs. you subtract 600 from 1700 and the leaves 1100 lbs for all passengers, all cargo, all pets, etc. might be enough,
Could you tow it in absolute terms? Yes
Would it be a pretty good tow vehicle for that trailer? Not in my opinion
i had a 2006 22cp coyote hybrid, a similar trailer ... And towed it with a 2006 nissan titan with tow package and 9600 tow rating. And it could handle it, but power was not wonderful on bigger hills. I can't imagine towing it with. V6. Mileage will be horrible. Will be tough on the vehicle and power lacking, but you could do it. Safety handling could be an issue potentially.
Ideally you need at least. 1/2 pickup or bigger SUV.
If you have plans to get a bigger tow vehicle you could tow it with the Acadia for a year but be careful and go slow.
2015 Wildcat 337FB
2006 GMC Sierra 3500 SLT DRW - Duramax
Taybrynn is offline   Reply With Quote
Old 07-15-2014, 11:44 AM   #4
thebrakeman's Avatar
Someone else on a recent thread here is considering towing a 21SS with a Durango V6 with tow package (6200 lbs max towing capacity). In my opinion, this is the most they should tow with the Durango, but they will still have some breathing room.
IMO, I think at best you will be line-to-line towing a 21SS with 5200 lbs max towing capacity, and that's if you can pack light. This also assumes you have 5200lbs rating. When I was considering the GM crossovers as tow vehicles, only the then-new Traverse could get 5200 due to some unique cooling. The Acadia/Outlook/Enclave versions could only get 4500 max. Maybe that has changed (?). Either way, I think the 21SS is not a good match for your Acadia.
thebrakeman is offline   Reply With Quote
Old 07-15-2014, 07:28 PM   #5
Thanks for the info. The weight rag on trailer says 3856 dry weight with 1000lbs capacity. I double checked and our 2012 acadia does have 5200 towing capacity. We live in central illinois which is fairly flat and we would only use it once or twice per year when I have to tow the boat with my truck. I think my best option will be to hook it up and just run around locally for a bit to see how it does with the weight dist hitch. Any other thoughts are welcome in the meantime.
Old 07-16-2014, 09:59 AM   #6
If you already have all 3 of these vehicles, then by all means, try out the Acadia for a local trip. It seems you will be able to stay within your limits, so it's simply about what you feel comfortable with.
Old 07-17-2014, 12:47 AM   #7
Incheon, S. Korea
BigBaron's Avatar
If your Acadia has a "tow/haul" button, then it has the factory towing package and you're good to go. No button, no go.
I looked at a few Acadia forums and was surprised by what they tow, and do it easily.
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 07-17-2014, 02:57 AM   #8
bikendan's Avatar
i wouldn't. my 2007 23SS, which weighs about about 500lbs. more than the 2007 21SS, weighs over 5000lbs. loaded for camping.
your 5200lbs. rating is with only a 150lb. driver in it.
IMHO, as a experienced Roo owner for over 7 yrs., too much trailer for a Traverse/Acadia.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-17-2014, 05:14 AM   #9
Incheon, S. Korea
BigBaron's Avatar
Actual experience trumps what looks good on paper every time...
I'm changing my vote to "no."
Old 07-17-2014, 06:40 AM   #10
Dave Lyon's Avatar
A friend of mine has a Traverse and tows a 19' Roo. I beleive he is at the wall with his numbers and there are only two people.
Even with a WDH he says he wouldn't want to be towing any more of a trailer.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
rockwood, rockwood roo, roo, towing
