Old 05-31-2014, 09:02 AM   #1
Towing Single or Tandem Axle - Comparison
I am trying to decide between 2 travel trailers with both being around 3,000 lbs and under 22 ft long with one having a single axle and the other tandem (tandem is a little heavier) and leaning towards the single axle unit but seeing and hearing all sorts of comments with likes and dislikes and hoping someone has experience pulling both. Negatives on single that I've heard is that you can pull any faster than 55 MPH on highway and they tend to bounce more and at times sway. I understand that an anti-sway bar should correct the sway issue but wondering. Also, is gas mileage any better if only have 2 wheels instead of 4?
johnlee is offline   Reply With Quote
Old 05-31-2014, 09:12 AM   #2
Witch Doctor's Avatar
I say go with the tandem, much better ride and safer if you get a flat or blowout.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 05-31-2014, 09:20 AM   #3
BooBoo23's Avatar
For a smaller TT I would prefer a single axle. Less towing resistance, less tire wear (you always slide 2 of the tires on a turn with tandems), easier to maneuver. As far as towing over 55mph, that should be plenty fast enough for any TT (55-60). As long as your weight distribution is proper shouldn't be a problem. One less set of brakes but for a small TT that should be ok. Also, proper size axle and tires is important to carry the load.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 05-31-2014, 09:37 AM   #4
Batts-toy's Avatar
I prefer tandem due to possible flat situation, look at the allowed weight you can load in each then consider what you want to load up to take camping, this may help you decide.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 05-31-2014, 10:55 AM   #5
AquaMan's Avatar
If you have a long wheelbase vehicle, backing a single axle is more difficult than a tandem. IMO.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 05-31-2014, 11:21 AM   #6
Ret E-9 Anchor-clanker
donanddona's Avatar
Have you looked at max rated tire speed. I generally travel at 53. Yea, retired, no hurry, full timer. I have seen very fast, swaying RVs. Of course I normally never have to pass.
donanddona is offline   Reply With Quote
Old 06-01-2014, 12:08 PM   #7
If the trailer weights are close to 3000 lbs as you say then I would go for the tandem axle as it would give you more carrying capacity(2-3500 lbs capacity axles compared to 1-3500 lbs axle and more braking power if needed).
09grizzly1
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 06-01-2014, 12:11 PM   #8
DDC
DDC's Avatar
I've had both and find the tandem more stable.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 06-02-2014, 11:01 PM   #9
Explorer
My experience:
Weight is the biggest issue, get axle/s that give you 20-40% margin with good tires; bigger axles will give you bigger breaks.
Short trailers(1 axle, 2 axle or 6 axle) respond extremely fast and can be hard to back up.
For short distance, more maneuverability single axles are good.
For long distance, smoother ride multiple axles are good.
Safety-wise multiple axles are nice but take care of your trailer and you shouldn’t have any problems.
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
Old 06-03-2014, 11:25 AM   #10
tanddc's Avatar
I prefer the tandem as well. Yes they crab around the corners but you just cant beat the additional stability. Also, when you hit pot holes on a single, the are rougher than a tandem (unless of course it is a really big one
tanddc is offline   Reply With Quote
axle, towing
