Old 07-31-2013, 08:23 PM   #1
Kash76's Avatar
Towing tires
I bought a 2013 F-150 XLT 4x4 w/Max Tow. It has Goodyear SR-A tires on it that are rated to pull 2,600 lbs each.
The camper that I am picking up this weekend is a 2013 Palomino Solaire 317BHSK Eclipse which tops out at around 86xx full and 35' long.
I have a GVWR of 7650 lbs and a payload of 1800 lbs. On the door sticker it says that these Goodyear 275/65R18 T114 tires are ok to use with that load.
I am looking at Michelin LTX M/S 2 (LT275/65R18E1 123R W) based on my Uncle suggesting, "it is silly to pull that camper with passenger tires".
I would like to hear everyone's thoughts on investing in light truck tires
1. Is the Goodyear overkill?
2. If you were in my position, would you buy the LT tires and sell the almost new Goodyears? It will cost me about $600 out of pocket.
I am trying to determine if this 'upgrade' makes for safer pulling.
Thanks!
2013 Palomino SolAire 317BHSK w/Eclipse package using a ProPride 3P Hitch
2013 Ford F-150 Ruby Red SuperCrew 4x4 EcoBoost w/Max Tow, e-lock, Michelin LTX M/S2 tires, & Air Lift 5000 Ultimate w/Load Lifter
Campers: Me, DW, DD, DS
Nights camped: 2015 (4) as of 5/25 2014 (44) 2013 (26)
ProPride Review
Kash76 is offline   Reply With Quote
Old 07-31-2013, 08:44 PM   #2
Sgt. Schultz's Avatar
I personally do not like the Goodyear SR-A's for any situation (but that's just me) IMHO trucks have P type tires for ride only and they really should not be used for hauling or towing for some further info see
http://www.tirerack.com/tires/tirete....jsp?techid=70
http://www.tirerack.com/tires/tirete....jsp?techid=55
I don't believe you need load range E (123/S) it would be overkill for your truck but a good LT C may be in order such as http://www.tirerack.com/tires/tires....Clar=SuperCrew
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 07-31-2013, 08:54 PM   #3
acadianbob's Avatar
That's a mighty long trailer. Surprisingly, your tongue weight does not appear to be too bad. If you figure a loaded tongue weight of about 800 pounds, you should be OK on payload. General rule of thumb on trailer length is your wheelbase divided by 5. That comes out to be about 31' for your 157 inch wheelbase. You are probably OK at 35' if you are properly set up with a weight distribution hitch and sway control. Given that you are on the upper end for your truck, LT tires might be a good idea. I'm not sure that load rating E is required. The LT tires that you can order from Ford are load range C. I have those tires on my Ecoboost Max Tow and I will say that I get a better towing experience from them vs P-metric tires. There is less vertical bounce and less vehicle lateral movement because of the stiffer sidewalls and increased tire pressure. You should check to make sure your Ford rims are rated for the pressure of an E rated tire (80 PSI) before you spring for E rated tires. I wanted to put E's on my last F150 but the tire shop refused to mount E's; saying the truck was not equipped to handle an E tire.
Bottom line. I would get an LT tire. You want all the control you can get pulling a trailer of that length IMO.
Happy camping! Enjoy your new trailer and truck. Be safe.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 07-31-2013, 09:03 PM   #4
Kash76's Avatar
Thank you both for the input.
Actually, I do have a 5.5' box so I am a little shorter than your recommendation of 31'. I have a WDH that will be on it and if I am not happy with that Equalizer 4 point then I will likely move up to the ProPride.
I will be sure to ask about the rims and see what options I have in load range C.
Thanks again.
ProPride Review
Old 07-31-2013, 11:22 PM   #5
wyo700's Avatar
I have the passenger tires on my 2013 tundra and have towed several times with no problems. Keep the air pressure where it needs to be and you will be fine. They are not gonna put the tires on the truck and give you your payload rating if the tires can't handle it. Of course different LT tires would help some with towing but not so much you have to get rid of brand new tires.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 07-31-2013, 11:28 PM   #6
I just put Michelin LTX MS2 in the size (LT275/65R18 E load).
I was concerned about them impacting mileage or being too noisy, but they have been great thus far.
LT vs P Michelin LTX M/S 2 - Ford F150 Forum - Community of Ford Truck Fans
buckeyefan is offline   Reply With Quote
Old 08-01-2013, 07:18 AM   #7
Kash76's Avatar
Great to hear, having the Michelin tires installed this morning :-)
ProPride Review
Old 08-02-2013, 01:02 PM   #8
billt01's Avatar
I have the LTX's on the Tundra...Mich's are worth the $$
"Camping invloves a tent, bugs, and incliment weather. This aint camping"
-Bill Thomas
Palomino Solaire 317 BHSK
billt01 is offline   Reply With Quote
Old 08-03-2013, 10:01 AM   #9
thebrakeman's Avatar
New tires on a 2013 truck? Sounds like a waste. If the truck came with those tires, with a "max tow package", then they are rated for use up to whatever ratings came with the truck. With a WDH, electric brake controller, and whatever else the owners manual requires, you should not need to be replacing tire already.
thebrakeman is offline   Reply With Quote
Old 08-03-2013, 10:46 AM   #10
Kash76's Avatar
These original this only had 500 miles on them so I decided to take the hit and all them on Craigslist. I have more confidence with the safety of pulling and these new tires will perform better with pulling. As others have suggested, the passenger tires are "squishy".
To me it was worth it and I appreciate all of the feedback here.
ProPride Review
tire, tires, towing
