Old 02-28-2016, 07:46 AM   #31
Oklahoma Proud
MillerTime's Avatar
Originally Posted by danny4127 View Post
Illegal in KS Unless you have a 5th wheel not with bumjper pull
Same for Oklahoman.
1st trailer is to be a 5th wheel if towing tandems.
Old 02-28-2016, 09:14 AM   #32
head gamez's Avatar
I hope this detailed explanation of my answer of "NO" helps you make a "safe" choice about towing a 2nd trailer.
I don't thin he was questioning your answer of "NO". The fact that you included an emoji rolling on its back laughing is most likely what prompted the response.
2016 Sandpiper 376BHOK
2500HD Chevrolet
head gamez is offline   Reply With Quote
Old 02-28-2016, 09:20 AM   #33
Originally Posted by 07 ThunderRoad View Post
Rules of the Road
Lippert makes 98% of the trailer frames. They will tell you NO to towing a 2nd trailer.
Your sway control is only for 1 trailer, the trailer connected to the truck, not the 2nd trailer.
Most states restrict or do not allow towing 2 trailers. See above link.
I'm going to guess that the utility trailer has no brakes. What frame do you think is going to take the stress of stopping that 3,000 lbs? That would be the rv frame that was never designed to do that. If the utility trailer has brakes, you need to modify and adjust utility trailer brakes so the utility trailer will not jack knife behind the rv.
The added weight of the utility trailer hitch on the bumper of the rv reduces the weight of the rv hitch on the trucks "bumper". This can reduce sway control and cause porpoising of the rv and truck.
You asked the question of "safely tow". You are NOT driving a semi, you'r towing an rv with a pickup truck.
You say you want to take a golf cart or a quad with a tt, put the golf cart or quad in the pickup bed, then connect the tt to the truck. If you have a short bed, have a bed rack made for the golf cart.
Check with the rv and/or state park your going to. Alot of them do not allow quads or gas powered golf carts. You people are too noisey. Ya, I'm OLD.
Yes people tow two trailers. This is usually done with a 5th wheel. Oh ya, Lippet still says NO to towing 2nd trailer with a 5th wheel.
Go figure. Them engineers don't know anything.
Oh ya, you could always have DW tow the utility trailer with a 2nd vehicle. It's only 3,000 lbs.
I'm not pulling 2 trailers, if you want to pull two that's your business. Lippert engineers are going to always say you can't add nothing to the frames, Lippert does not want to get sued because all the company's frames are not made the same. I plan to add something to the frame at the rear of my camper. It's my camper, warranty is out. I'm not going to ask Lippert, I think most people want to be safe. The people that pull a trailer behind there fifth wheel have really beefed up the hitch and frame, at least the ones I have seen. Besides its there camper let them fix it like they want too. When I see people pull to big a camper or pull two trailers or three it doesn't bother me, I just smile and go on.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 02-28-2016, 10:19 AM   #34
CWSWine's Avatar
Rules of the Road
I agree with 99% of what you saying but Lippert makes a hitch made to tow a boat and will sell it aftermarket to the end users.
72 1/2 Boat Hitch Receiver
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 02-28-2016, 10:26 AM   #35
Just because they make a hitch does not mean it can be used on every frame they make.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 02-28-2016, 10:36 AM   #36
That's true. You have to use a little common sense. But that's in short supply. But then again you can't use my way or no way.
Old 02-28-2016, 12:10 PM   #37
My biggest issue with what the op wants to do is they want to pull two bumper pulls with the second one weighing half what the first one weights. If they had a 10000 lbs fifth wheel I would be less concerned.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 02-28-2016, 12:14 PM   #38
I'm not concerned at all its there camper.
towing, trailer
