Closed Thread
Old 05-13-2013, 10:41 AM   #51
My take on the O/P is NO! Now in regard to Mini Van,I was at my Paver yard and a Guy wanted a (Skid of Pavers) loaded in the side door(he said he removed the seats and the pavers would FIT)! The lot boy said NO,you need something that will handle a (LOT) of weight. He came back with the (SAME Mini Van) 1/2 Hr later,He put more (AIR) in the Tires?? Talk to the Hand! Youroo!!
youroo is offline
Old 05-13-2013, 10:43 AM   #52
Not sure what is complex about the point.?.? If a minivan or a car has a CCC of 1100-1300 pounds, and everything about it is lighter and weaker, why would a truck have the same CCC? No one else finds this odd? How is comparing CCC of different types of vehicles and pointing out the fact that in no way in the real world is a car or minivan as capable of hauling 1300 pounds as a truck comparing apples to donuts?
dustman_stx is offline
Old 05-13-2013, 10:43 AM   #53
Originally Posted by oldcoot View Post
i think dustman is just pointing out how ridiculous the load ratings are on 1/2t pickups when the same folks will state all sorts of facts on trucks and then load up their minivans and think nothing of it. Just my take on it.
exactly!!!!
Old 05-13-2013, 10:46 AM   #54
Originally Posted by f1100turbo View Post
But he's not taking in consideration that the minivan may have a high ccc like a half ton but its also not rated to tow 10, 000 + lbs either.
Which is why you can't compare.
What does tow rating have to do with CCC?
Edit: I can foresee this statement being torn apart, so let me clarify. How does the tow rating of a truck somehow lower it's CCC? It doesn't. They are two independent ratings. You seem to be saying that since a truck is designed to TOW we cannot compare it's CCC to other types of vehicles and draw a conclusion that it is ludicrous to believe a truck cannot HAUL any more than a minivan or some cars.
Old 05-13-2013, 10:49 AM   #55
rosebunch's Avatar
Just a quick note. Just read in Trailer Life Magazine that the new 2013 Dodge Ram 3500 diesel can tow 30,000 lbs and a GCWR of 37,600 lbs. Now that is some impressive numbers. I think prior to this the max for any brand of pickup was 30,500 lbs
Bob
2013 Columbus 295RL
now 2010 RAM 3500 Diesel Crew Cab Laramie
killed by drunk driver1995 Dodge Cummins Exhaust Pac brake, DTT trans, cold air intake mods, TST #5 cam plate & others.
Pull-Rite Super 5 15.5K hitch
Been trailering since 1977
rosebunch is offline
Old 05-13-2013, 10:49 AM   #56
TURBS's Avatar
In your mind ccc is a suggestion ?
TURBS is offline
Old 05-13-2013, 10:49 AM   #57
Golflover's Avatar
I just bought my Crusader 5th 260rld and pull it with my 2004 Silverado 1/2 ton extended cab. Truck has the extra coolers, beefed up suspension, and I added timberllins for the suspension in the rear. Truck pulled my old Puma 5th "ok" but it pulls the new camper much better. When we moved out of the PUma we downsized allot of the extras we carried which I think helps. Plus I think the Crusader is a bit lighter also. I did the numbers and after calculating believe I am within the weights. We don't pull that far for just doing weekends 25-50 miles but it does seem to pull easier and smoother then the Puma ever did.
Golflover is offline
Old 05-13-2013, 10:51 AM   #58
But they would have loaded it into the bed of a 1/2 ton truck, right? Even though the door sticker probably said they can actually carry the same weight!!!! You prove my point that, even though the door sticker doesn't say it, a 1/2 ton truck is capable of carrying a much greater load than a minivan.
Old 05-13-2013, 10:52 AM   #59
Originally Posted by rosebunch View Post
Just a quick note. Just read in Trailer Life Magazine that the new 2013 Dodge Ram 3500 diesel can tow 30,000 lbs and a combined CC of 37,000 lbs. Now that is some impressive numbers. I think prior to this the max for any brand of pickup was 23,000 lbs
Bob
Ok. But those ratings are pretty meaningless for the RV world. CCC is way more important. I'm guessing these are not the new SAE standard numbers either.
BarryD0706 is offline
Old 05-13-2013, 10:52 AM   #60
FandRChambers's Avatar
Ok I guess I understand Oldcoot's point...a little. but when I load the family in our honda mini van I don't compare it to my Dually. I guess because I don't tow or haul anything with the mini that weighs more than a our luggage. Not what I purchased it for. For argument sake, I don't think that's what they were built for either. They advertised as a family vehicle to haul the kids around in comfort etc. But some people are different. Some will haul anything, on anything that will move safe or not.
Fred & Teresa
2005 Coachmen Encore Sportscoach
2005 Harley Road King
2002 EZGO Golf Cart
FandRChambers is offline
Closed Thread
