Closed Thread
Old 05-09-2013, 04:23 PM   #1
Towing weight
I have a 2010 Ford FX-4x4 with a 5.4 liter V8 engine and a 3:73 rearend gearbox. A Sidewinder hitch, air-lift doughnuts and helper springs. I'm looking at a Palomino Sabre 5th wheel 35 ft with 3 slideouts. the dry weight is
9980 lbs. The truck GVWR is 7200 lbs and a rv dealer said I can tow 11,200lbs safely. Is this RV too much for a 1/2 ton pickup?
Buddy231 is offline
Old 05-09-2013, 04:26 PM   #2
fonzie's Avatar
Way too much trailer for you.....what is model of fifth wheel?
Fonzie
fonzie is online now
Old 05-09-2013, 04:27 PM   #3
MtnGuy's Avatar
IMHO, yes, that is way too much camper for an F150.
The problem is not going to be the towing weight, but the pin weight. That pin weight is gonna be probably be well over 1500 lbs. empty, and much more ready to camp.
Load up the family and expected camping gear and get your truck weighed. Add another 100 lbs. for hitch. Then see if you add 1500 to 2000 lbs. without going over the 7200 lb. GVWR.
And then the GCWR is a whole nudder ball game.
MtnGuy is offline
Old 05-09-2013, 04:34 PM   #4
Fulltime family RVer
I wrote this page for exactly this question:
http://learntorv.blogspot.com/p/what-can-i-tow.html
The other thing I've learned due to a weighing exercise is that the "dry" numbers are grossly understated. My camper has an advertised dry weight of 11,800. My actual yellow sticker is 12,300 and my "ready to camp" weight is 13,800 (which even that's low as I didn't have propane and we hadn't gone food shopping for the week). My advertised pin weight was something like 1,800 pounds but my actual weight was 2,300 pounds (with the same caveats that we were running lighter than normal).
You can read about that here:
http://learntorv.blogspot.com/2013/0...at-scales.html
Long story short- do the math and be realistic in estimates and make an educated decision from there.
ependydad is offline
Old 05-09-2013, 04:39 PM   #5
That is WAY too much camper for a F150, no matter what configuration it is. It would be plenty for a 3/4 ton if you want to be comfortable pulling.
Better to err to the side of caution than push your luck.
bakken is offline
Old 05-10-2013, 06:50 AM   #6
BDavis's Avatar
Don't do it.....had the same setup with a 7800lb trailer and it is not safe. Bought a F250 and all is good!
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is offline
Old 05-10-2013, 07:07 AM   #7
Platokidd's Avatar
Too much!
There is a new standard in 2013 and ton info on the web. Some tow limits will have gone down in 2013.
J2807 tow ratings
Looks like Truck mfg. will all have to start playing by the same rules!
Tow Ratings Finally Pass the Sniff Test - The Society of Automotive Engineers (SAE) - Automobile Magazine
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is offline
Old 05-10-2013, 07:12 AM   #8
In my hunt for a trailer, it seemed that the dealers would show you the number that is within your limits. You need to do your do diligence to figure out the rest. Payload will be the first thing you run out of in a half-ton.
MGordyan is offline
Old 05-10-2013, 07:27 AM   #9
Camper Less Camping
Cajun Po-Boy's Avatar
Yep...too much trailer, either get smaller unit or bigger truck...I say bigger truck!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline
Old 05-10-2013, 07:38 AM   #10
Herk7769's Avatar
My 3/4 ton GMC 2500HD is maxed out with my 9200 pound 5th wheel due to payload availability. I have the diesel engine and Alison transmission and carry a small generator in the bed (in addition to the slider hitch) that reduces "the book" payload somewhat.
Your truck must have an available payload and axle load to "carry" 2240 pounds of pin weight AFTER you load the truck with all your gear, family, and the hitch of your choice. Expect that to be significantly less that what the dealer, who wants to sell you the biggest most expensive rig he thinks you can pull off the lot, says you can pull.
If you break down at the first traffic light, he won't be accepting your phone calls.
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Closed Thread
