Old 08-27-2013, 06:54 AM   #1
Towing with 2013 Silverado 1500
Attachment 38726This is all new to me so I went by the CAT scales as recommended here in this forum. DW and I purchased a 2013 Silverado 1500 4x4 Crew Cab with the 5.3 and 3.42 gears (old truck was paid for), and a Coachmen Freedom Express 291 QBS. Here are my truck specs and weights from scales.
Truck specs
GVWR= 7000
GVAW front= 3950
GVAW rear= 3950
GCWR = 15000
Max payload = 1712
Max Trailer weight = 9500
The yellow sticker on the trailer lists the dry weight at just over 5400
I have the Reese WDH with friction sway control and it pulled from KY to FL just fine at a speed of 60 mph. To say I was nervous pulling it here for a week on the beach is an understatement but I followed all the tips you guys gave me and here we sit watching the ocean for a week and loving it!
Here are my CAT scale weights,
Steer axle = 3180
Drive axle = 3300
Trailer axle = 5900
Gross weight = 12380
These weights are with a full tank and fully loaded for a full week in Destin FL.
Does all of this seem OK?
2013 Coachmen Freedom Express 291 QBS
2013 Chevy Silverado 1500 Crew 4x4 5.3
Jandj1026 is offline   Reply With Quote
Old 08-27-2013, 06:56 AM   #2
After 600 miles we are finally here!
Old 08-27-2013, 07:42 AM   #3
I have the same truck towing a Micro Lite 21FBRS with an Equal-i-zer 4 way (600 lb bars):
Trailer Dry Weight: 3742
Drive Axle: 3300
Steer Axle: 3300
Trailer: 3980
Gross: 10580
I get around 10 mpg with 62 as my target towing speed. That’s about 2 +/ - mpg less than I got with a Toyota 4Runner towing a heavier Sunline 2363, but the Silverado holds a lot more stuff. The long wheel base makes for a really wide turning circle and also makes it a bear to back a trailer in a tight space.
I put the Chevy tow mirrors on mine. A little on the pricy side, but a lot more stable and convenient than the McKesh strap-on mirrors I used with the 4Runner.
Overall, I give the Silverado a big “thumbs up.” I hope you enjoy yours as much as I enjoy mine.
00buck is offline   Reply With Quote
Old 08-27-2013, 07:49 AM   #4
avolnek's Avatar
The loaded weights as you posted are only part of the equation here. We would really need to know what the unloaded weight of each axle is. The idea for the weight distribution is to return the front axle to the same weight or a touch more would be ideal IMO. It doesn't look like you are too far off if you are...
You stated you were nervous... what were you nervous about?
I noticed you mentioned you were using a reese w/d and sway control hitch. Is this the hitch with snap up chains and separate friction sway bars that clip on the side? If so, did you have those tight?
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 08-27-2013, 07:55 AM   #5
I averaged 10.2 mpg towing it down here to FL for vacation. That's abt what I expected after reading some of these forums. Trans temp got to around 190 going through Tenn. hills with an outside temp of 90.
Old 08-27-2013, 08:02 AM   #6
This was my first time towing my RV more than 30 miles from home. We stayed in some parks close to home since June when we purchased the RV just to get familiar with it.
The hitch that I have just has the two bars that sit in saddles.
Old 08-27-2013, 08:06 AM   #7
Dave_Monica's Avatar
By the numbers you've posted, all is well within the specs of your truck. It would have been helpful if you did 3 weighings so that you'd be able to determine the tongue weight and if its distributed properly. To do that you'd have to weigh truck axles/trailer axles all hooked up; same as before but with the W/D bars unloaded and lastly, a weight of the trucks axles alone with the hitchhead and W/D bars on. This would tell you if you have enough tongue weight (looking for around 13%) and whether it's distributed properly to the truck's front axle and trailer's axles.
Dave
Old 08-27-2013, 08:12 AM   #8
Dave
Will try that next time. This was my first time on scales and the teenager working inside the Love's wasn't very much help. So I just pulled onto the scales and then he came on the speaker and said to come inside. Thanks for the help.
Old 08-27-2013, 08:14 AM   #9
avolnek's Avatar
that's seems to be about par for the course for scale operators. If you are near any of the local co-ops of smaller towns they generally have a scale and the reading facing out of a window in a near by shack. I live just a couple miles from one and go after hours and spend all the time I need... Just a thought.
Old 08-27-2013, 08:20 AM   #10
Thanks for the advice, I will look into it.
2013, 500, towing
