09-02-2015, 07:30 AM
Towing with 2015 Chevrolet 1500 4x4
Good Morning,
I know I've seen a ton of posts about this, but none that addressed my specific question.
We are a family of 5 (Ages: 14, 10, 10). We are looking at a Surveyor 32BHDS that comes in dry at 6,866 lbs and has a GVWR of 9,534 lbs. The max tow capacity of the truck per the manual is 9,200 lbs. and requires weight-distribution hitch for any weights above 7,500 lbs. The hitch weight of the travel trailer is 734 lbs.
I do not intend to camp anywhere without hookups. Water weighs 8.34 lbs for gallon so that means 717 lbs. of that gross weight will never be realized, leaving my max trailer weight at ~8,800 lbs.
Truck Payload = 1,746 (according to door sticker)
Truck GVWR = 7,200 lbs.
GAWR Front = 3,950 lbs.
GAWR Rear = 3,950 lbs.
Max Hitch = 1,200 lbs with weight distributing hitch
My question is why doesn't any of the analysis that I see done online not reference the impacts the weight distributing hitch will have on payload, hitch weight, or trailer weight? Why doesn't anyone take this into account when evaluating the towing capacity of their vehicle. My owner's manual clearly states that weight distributing hitches are required for anything over 7,500 lbs.
My understanding is that a weight distributing hitch will take 25% off the hitch and put it back on the trailer, take 25% off the hitch and put it on the front axle of the truck, and leave 50% on the hitch directly. With that being said (towing dry), if my hitch weight of the truck is 734 lbs, doesn't that mean that 183.5 lbs will be added onto the weight of the trailer to bring it to 7,049 lbs, another 183.5 lbs will be added to the weight of the truck's front axle, and the remaining 367 lbs will be on the hitch?
09-02-2015, 08:04 AM
Try googling: towing basics, relationship between gvwr and weight distributing hitches. There's a lot of information out there. You have a lot of trailer @ 32' and whether you're carrying a full tank of water or not, everything in the trailer from pots,pans, clothes, food to toothbrushes adds to (or detracts) from the towing capacity. Everything in the truck from you and the family to a full tank of gas and a box of firewood works into the equation. It's surprising how much stuff you take with. WDHs take some of the squat out of the TV and shift it to the front wheel of the TV. Does your TT set pretty much level when you're ready to hit the road? The setting on the bars have a distinct and noticeable effect on the steering. When in doubt, you can always go to the scales and see if you're overgrossed
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
09-02-2015, 08:46 AM
I tow a Rockwood 2702 SS (28' box, 5600 lbs) with a 2015 1/2 ton Silverado utilizing an Equalizer WD hitch. If the trailer weighs 6866 lbs you won't be "adding" to that weight using a WD hitch. I believe my Equalizer works by distributing the hitch weight to the front of the tow vehicle and not by shifting any weight to the trailer. As far as a WD hitch adding tow capacity I don't know. You will probably never see towing 8800 lbs trailer weight as that would be adding almost 2000 lbs of stuff in your trailer. (Unless you plan on carrying a couple anvils.) If your truck can tow 9200 lbs I wouldn't worry about it. By the way I highly recommend the Equalizer, I found one for $477.00 including the ball.
09-02-2015, 09:25 AM
Thanks for the replies.
We do not yet have the travel trailer, but it's a model and floorplan that we really like. We are also looking at a 294QBLE which is a little bit shorter (33' vs 36' 6") and a little bit lighter at 5,564 lbs unloaded. Unfortunately, it doesn't have the outdoor kitchen, 50 Amp service, option to add second A/C unit, or the larger bunkhouse for the kids.
Also, won't be able to upgrade tow vehicle to a 3/4 ton for at least 3 years - it's a lease. So, I'm assuming that as long as i'm towing within limits, it will be covered under warranty.
Towing spec is 9,200 lbs for my configured vehicle. I'm just trying to figure out where they get that number and the only way it makes sense in my mind is that if the weight distribution hitch has an impact. The manual says the Payload is calculated with a full tank of gas and two front seat passengers at 150 lbs.
Before jumping into the purchase, I want to make sure everything checks out for towing it with my vehicle. I understand this is a forum and I will see both ends of the spectrum - from you'll need an F-450 to tow it to I tow it with my 1968 vw bug. I hope to be somewhere in the middle to just above the middle of that spectrum.
09-02-2015, 10:21 AM
I have a 3008 Windjammer and tow it with a 2011 1500 Silverado 4x4. GVWR on the truck is 7000 and max tow is 9600 pounds. I have a cap over the bed which reduces the payload some. Weighed the truck one day with me, the wife, a full tank of gas and the hitch installed in the receiver. Truck weighed 5950 on the scale. That leaves me with 1050 of payload left from the trailer and anything else in the truck. So I am careful not to put very much in the bed when towing the trailer. For me that is the problem with a 1500 series truck and there are only two of us.
As for the trailer we are well under the 8900 GVWR when we go out. The brochure said 6950 for the trailer but the factory weight was 7350 out the door. Only 8000 of that can be on the trailer axles.
09-02-2015, 11:42 AM
esloser, I towed a 24fqsl toy hauler that I figured weighed around 8000 fully loaded ( bike etc ) with a 2014 gmc 1500 with the trailer package, and wdh and it did ok on fairly level areas but when we got to mountainous areas the truck really fell short on the power and suspension areas, without a doubt I was really putting a hurting on this truck going up big grades, me personally I would never try to go to the max 9500 pounds that it states, I recently traded it in and got a chevy hd2500 that I plan on taking it out next weekend on its maiden voyage and hope I see a big improvement in towing, my bud has a chevy 2500 with a much heavier trailer and can leave me in the dust on grades l.o.l. not trying to discourge you but just letting you know what my real world experiences were with towing with a very similar setup that your talking about, it towed great on the interstates ( no sway etc ) but really fell short on other areas, whatever you do, good luck and be safe. thanks joe
09-02-2015, 11:53 AM
You will run out of payload way before you obtain your published towing limit. You will never be able to safely tow a 9,200 pound travel trailer -- it just can't happen.
What is the GCWR for your truck?
Bruce
09-02-2015, 11:54 AM
Bruce
X2
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
09-02-2015, 12:12 PM
Towing
We have a Windjammer 3008. The TV is a 2006 5.3 Silverado 4X4. We don't overload, but do not have any problems towing. The truck has a 10,000 lb tow rating
John
09-02-2015, 12:23 PM
The tongue weight does not change when using a WDH.....it just moves the weight around. In the case of my setup with a ~700 lb. tongue weight, ~180 lbs is moved back to the trailer axles, and ~360 lbs. is moved to the front TV axle.
As Jeff64 indicated, everything that adds weight to the axles of the TV are included in the overall weight of the TV.....including what weight you hang on the hitch. With a family of 5, that could be a substantial amount of weight just in passengers. And you can't go by the payload stats on the door. My stats show almost 2000 lbs. of payload capacity, but with my personal gear, a bed liner, TracRac rails, running boards, small portable tool box in the bed, and me in the driver's seat (about 195 lbs), I only have 1200 lbs left for the missus, dog, some other gear, and the trailer tongue weight.
IMHO, 700 some pounds is entirely too much weight to be added to a hitch of a 1/2 ton pickup without using a WDH. 700 lbs hanging several feet behind the bumper might cause the weight rating of the rear axle to be exceeded, plus it will take off several hundred pounds from the front axle.
09-02-2015, 12:28 PM
esloser,
I think you may want to check your trucks GCWR . If I figured out your model correctly --Crew short box you have a GCWR Rating of 15,000 lbs- your 8800 leaves you a 6200 GVW for your TV.
09-02-2015, 12:50 PM
The WDH does not increase the towing capacity. It just more evenly distributes the weight across the TV axles. Also it appears you are trying to manipulate the numbers to justify your situation. That will not work. Yes the truck and trailer will go down the road but you will not enjoy your trip nor will you have any margin for unexpected emergencies.
Not trying to give you a hard time, but I would not tow that trailer with your existing TV.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
09-02-2015, 01:07 PM
I'm with you Joe in PA! My '03 1500 struggled pulling my old Wildwood 27'. It would do it but struggled on long grades. Not to mention the strain on the tranny. The truck did ok with the Equalizer Hitch. The hitch kept things in line but you still had to drive the truck, took a lot of attention. I up graded to a '09 2500HD 6.0 gasser, 6 speed tranny. It made all the differance in the world. The heavier truck made pulling much easier. I felt more at ease. I have moved to the 5th wheel world pulling a '14 Keystone Sprinter, 32' with the same truck. It still has the MOJOE to pull this trailer with ease. Plus the 5th wheel pulls way easier than the ball hitch unit.
The other thing to look at is the load range rating of your 1500 tires. They may be too light for the weight your thinking of going to. All in all the 1/2 ton trucks are light. They were not built to pull BIG trailers. My thought is if you are maxing out the payload and pushing the length you are getting on thin ice.
Safety is everything! FWIW
09-02-2015, 01:11 PM
Georgia Rally Coordinator
Bruce
X 3 Remember also that the trailer is not weigh with full LP tanks nor with battery. Trailer weight varies and are estimates listed in brochure Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
09-02-2015, 01:20 PM
The law of moments ( explained very clearly here) says equal moments (torques) are applied forward of and behind the TV's rear axle. The transferred weight will thus be distributed so that:
weight added to trailer axle
weight added to front axle
distance between front & rear axles (TV wheelbase)
distance between rear axle & trailer axle
For example, if the distance from the rear axle to the trailer axle is 2 times the TV's wheelbase, then:
wt added to trailer axle / wt added to front axle = 1/2
so 1 part in 3 is added to the trailer, 2 parts in 3 to the front axle
or 33% is added to the trailer, 67% to the front axle.
Esloser's case of redistributing equally between the front and trailer axles will be true if the distance from the rear axle to the trailer axle is equal to the TV's wheelbase, which would imply a very short trailer.
09-02-2015, 01:37 PM
Sounds like you have convinced yourself. Get out there and enjoy the outdoors.
09-02-2015, 02:13 PM
That's going to be your limitter.
You have 5 people to put in the truck, and any stuff, plus the weight of the hitch.
That dry hitch weight is not very helpful. you should have 12% of the total wet Tt weight on the hitch.
You're very quickly eating up that 1,746 that the truck can CARRY (not tow).
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 Coachmen Freedom Express 292BHDS -- SOLD
2013 RAM 2500 CTD
2018 Prime Time Crusader 319RKT
09-02-2015, 04:49 PM
overloaded
Just my 2 cents.
Get a 2500 or 3500 truck. You are way too close to overloading a 1500.
I agree with everybody here 's comments. Don't ask a car salesman!!!!!
Mort
09-02-2015, 05:19 PM
Bruce
GCWR for the truck is 15,000 lbs.
09-02-2015, 05:31 PM
Believe me, if I could talk myself into a bigger truck, I'd already be down at the dealership. But, this is my daily driver and is leased for another 3 years. I did look at 2500's but owning a vehicle just doesn't make sense to me anymore. You're looking at $45,000 - $60,000 and $1,000+ per month payment. You'll be underwater until the day you pay off the note or trade it in on a loss, unless you put a ridiculous amount down - but why do that for a depreciating asset. I just figure a vehicle is an expense - most certainly not an asset. And, of course, most car companies don't like to lease 2500's or 3500's.
