Old 01-31-2019, 09:25 PM   #1
Towing with 2016 F150 Supercrew
I have a F150 with towing package and I'm looking for a good travel trailer that can accommodate between 5 and 6 people. I don't have experience towing, but would like to hear some recommendations for the proper size trailer. My current F150 is used as a daily driver to basically get things for the house at the local home center, etc.
The payload on the truck is 1834lbs and the towing rating comes in at 8900lbs (3.31 gears). I was looking at various Apex models. Unfortunately Nano editions are very limiting for us, so we'll most likely go towards something in the ultra lite category. A local dealer has 289LE on sale, the price seems right and we could potentially knock it down a little bit more. My problem with this trailer is that it's kind of hitch heavy at 720lbs. Dry weight of the trailer is 5654lbs and GVWR is 7600. Also it is rather long at 32 feet (bumper to hitch). The total weight of all passengers will be around 600lbs.
We will be towing this eventually across the US (from IL to CA).
Some of the upgrades that I would like to do:
- go with LT tires
- Airbags in the rear
- Equalizer hitch; maybe ProPride ($$$)
We are also thinking about Imagine 2400BH, but honestly I do like Coachmen product a bit better; I think primarily because they use Azdel.
luke79 is offline   Reply With Quote
Old 01-31-2019, 09:55 PM   #2
You should have plenty of options with that kinda of payload people will tell you that your truck is to small or that dry weights are useless but others will say the opposite. I would say go enjoy a day looking at trls that donít exceed the the 8k range find a floor plan you enjoy make the upgrades you mentioned and enjoy
moose074 is offline   Reply With Quote
Old 01-31-2019, 10:49 PM   #3
Grammar Pedant
67L48's Avatar
Figure your trailer will be 6600-7000 lbs when optioned out, loaded, hitched, and ready to go. That's going to put around 850 lbs on your hitch. Add your 600 lbs of human cargo (that number needs to include the driver, not just the passengers). Add another 50-100 for the hitch. So, you're around 1,550 lbs. Still have 300 lbs for wood, gear, options on the truck, bikes, pets, heavier trailer load, etc.
Should be fine.
I'd expect the truck to already have LT tires on it. Mine came from the factory with LT. If not, then you need some, sure.
I love my Equalizer WDH, but my trailer is 6' shorter than yours.
Good luck.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 01-31-2019, 11:27 PM   #4
bikendan's Avatar
Which tow package do you have? The regular one or the Max Tow package? With the 3.31 rear end probably means it has the regular tow package. That's your weak spot.
My 2014 F150 has the 3.5 Ecoboost with the Max Tow package and 3.73 rear end ratio. I have almost the same payload capacity.
I comfortably tow a 26ft TT with a loaded weight of around 6000lbs. Measured tongue weight is 750lbs.
For the number of people you want to sleep, a bunkhouse model is about all that can.
Airbags won't increase payload. They'll only help with rear end sag.
Equalizer WDH
Old 01-31-2019, 11:46 PM   #5
Regular tow package, I think max changes gearing to 3.55.
Old 02-01-2019, 12:29 AM   #6
bikendan's Avatar
You must have a newer F150. Did your truck come with the integrated brake controller?
Equalizer WDH
Old 02-01-2019, 12:42 AM   #7
SailorSam20500's Avatar
My personal view...
Unless you need tires, stay with what you have and apply the $ to the ProPride hitch. My truck has 20" P rated tires and I haven't felt a need to change tires.
As noted, air bags will address rear end sag but does nothing to return weight to the front axle which IS critical, no weight on the front axle, no steering. Any good WD hitch will address the weight issue.
Air bags may help with porpoising if that bothers you. I have not installed one of those either.
The above is based on towing 20K+ miles with a ProPride hitch, both a 2016 and 2018 F150 and the trailer in my signature which weighs in at 7k lbs.
YMMV
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 02-01-2019, 01:40 AM   #8
dbledan's Avatar
I have a 16 F150 and a 7K fully loaded 30' trailer. It is very tongue heavy. I have been on long and short trips. The biggest concerns I would have is sway and weight. Your trailer will be longer and weigh more than your truck. The tail will wag the dog.
With that many people I would be way over my weight limits even maxing at 600lbs. Dont forget kids grow fast so 50lbs this year is 100lbs next year. The few times we have had to take that many folks we took another car. Normally it is just 3 of us and maybe a small dog. You have decent payload so hopefully you have some room to grow. You may be fine as every trailer is different.
With that trailer you will see squatting. My truck was hopping on bumps. I bolted on timbrens to resolve that. Airbags work too. Neither helps your weight problem.
I had sway in 20mph cross winds with a 30' trailer. I upgraded to the Propride and will never go back. The propride will get you there and is worth the money as someone who tried to pull without it. It has kept me in the F150 another season before upgrading trucks. This will also not help you with a weight problem because the hitch is 260lbs but it tends to be able to offset itself. I will still use the propride with a new truck.
Sailorsam20500 is right about priority. LT tires will improve the ride but wont change the loading sticker so you still have the weight problem anyway and from my experience the tires alone did not solve stability but the propride sure did. Dont get me wrong LT tires helped but money better spent was on the propride.
Good luck, but be ready to make some tough choices if you have to upgrade trucks or downsize trailers later. Getting close to limits can become very expensive very quickly if you gambled on the wrong side and need a major change on the truck or TT. If you can find something lighter it would be cheaper in the long run but not sure if you can sleeping that many.
I think you could make it work but it will be very close. Someone else will have to tell you about CA as I have no direct experience but I hear they weigh everything so make sure you are legal and feel safe.
dbledan is offline   Reply With Quote
Old 02-01-2019, 08:18 AM   #9
No it didn't. It was a $500 add on. I can get the one from Ford or something else. $500 for brake controller is a little steep.
Old 02-01-2019, 08:23 AM   #10
I think my main issue is the ability to control the sway. I think that Apex is too large so we'll look at something else or maybe a smaller Apex. I really want to make the current truck work. I don't see myself upgrading tow vehicles right now as it can be very expensive. Also I can still park F150 in the garage; F250 most likely won't fit.
What would you guys recommend for a TT for the current F150 for the family of 4-5?
f150, towing
