Old 10-16-2018, 02:43 PM   #1
Towing with a 3.6 liter Jeep
Hi all. We recently are in need of a newer TV as our 2006 Durango (4.7 litre engine) was a write off in an accident. Do any of you tow a 4500 lb Shamrock with the newer Jeep or Durango with the 3.6? The dealers are all saying it will tow 6200 lbs but I drove one with a 5 speed and I don't think it will perform as well as our Durango (which had trouble uphill if there was any wind). The Shamrock has a 3" lift because some of the places we go need the clearance so it catches a little more wind than standard. Does the 8 or 9 speed (which ever it is) work better? Any and all comments welcome. Thanks.
Brian and Judy
perrogie is offline   Reply With Quote
Old 10-17-2018, 06:21 PM   #2
coney's Avatar
Brian and Judy
I am towing a rockwood Roo 19 ,weighing in at 4900 lbs, with a 3.5 liter Pathfinder just fine
Central Joisey
2017 Nissan Pathfinder SL
2014 Rockwood Roo 19
coney is offline   Reply With Quote
Old 10-17-2018, 06:54 PM   #3
fx2
The 8 speed trans will work better
2014 Surveyor SC321BHTS
2016 Nissan Titan XD SL4x4 Cummins
fx2 is offline   Reply With Quote
Old 10-18-2018, 09:57 AM   #4
Junior Old Fart
The Wrangler is rated for 2000 lbs on the 2 door and 3500 lbs on the 4 door.
On the Durango;
The 3.6L Pentastarģ V6 engine can tow up to 6,200 pounds*.
*When properly equipped. See dealer for details.
(taken from the durango web page
LTDunltd is offline   Reply With Quote
Old 10-18-2018, 02:59 PM   #5
Tow vehicle
We tow an EPRO 19FBS that tops out just under 4,000 pounds with a 6 cylinder Durango. Pulls fine. Runs mostly in 6th gear. Oil and trans temp stay right where they should be. If I was heading out west into heat and mountains Iíd probably upgrade to at least a half ton. But we have gone to Maine from Ohio and to Florida with it and had no issues.
mdc05 is offline   Reply With Quote
Old 10-18-2018, 04:25 PM   #6
Where do you plan to go with it. Lots to do with what you decide. Towed a TT at around 4200lbs all over the State of Michigan with a 2001 Chevy 4.3 V6 and it did fine. But would not want to drag it through the Smoky's or Big Horn Range.
markb422 is offline   Reply With Quote
Old 10-18-2018, 05:55 PM   #7
DieselDrax's Avatar
On the Durango;
They are likely referring to the Grand Cherokee, not the Wrangler, when talking about towing with a Jeep.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is offline   Reply With Quote
Old 10-18-2018, 08:42 PM   #8
Cooknavy's Avatar
So here is my set up
2018 Rubicon JLU with a factory tow setup.
I replaced the stock class 2 hitch with a class 3 Draw tite Stock number 75515.
I used a Tekonsha 3014-p wire connector from the brake controller connection (gray plug above brake pedal) too connect to a Tekonsha P3 controller .
I’m towing a 2019 ForestRiver E-Pro 19 FBS with a dry weight of about 3100lb.
I also have a Fastway E2 6k weight distribution hitch too help keep it on the road.
Cooknavy is offline   Reply With Quote
Old 10-18-2018, 08:58 PM   #9
Big-Foot's Avatar
2015 Jeep JK Unlimited with 5 spd Automatic and 3.73 gears towing an -ahem- 3500# (loaded) RPod.
I bought a SuperChips Trail Dash 2 not so much as to get more power (it did give a marginal increase) but to get a towing tune which would manage the shift points of the transmission better.
We have done a couple thousand miles so far and some limited mountain running.
It does an -okay- job. Roughly 12 mpg on 92 octane fuel. 60-65 mph.
More items of interest -
Equalizer weight distribution hitch, an extended hitch shank from etrailer to get the hitch ball out from under the spare tire. Hopkins Remote trailer brake controller. AirLift air bags really help the squat.
Note, I did not have but 5 psi in the air bags when this pic was taken. 30 psi works pretty good to keep it level without putting undue pressure on the hitch via the weight distribution bars.
Is it a good tow vehicle?
Not exceptional, but adequate..
Regards - Randy
Cedar Creek Cottage 40CFE
R-Pod 182G
Randyís Rod Shop & Fabrication
Big-Foot is offline   Reply With Quote
Old 10-19-2018, 05:54 AM   #10
DouglasReid's Avatar
Brian and Judy
Don't take the salesman's word. Have them show you the Towing Capacity in the Specs for the vehicle. If a factory "Towing Package" is available for the vehicle, make sure it is on the one you purchase.
More gears is always beneficial while towing. It allows the transmission to keep the engine in its "best performance" range for the conditions (mountains vs flats) you are towing in.
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
