Old 03-20-2017, 08:32 AM   #1
Towing with a late model Ram...6.7 CTD
Went on our first trip with our new Ram 2500 (posted about it in a previous thread).
Truck towed GREAT. Loved all the new features, seat warmer, steering wheel warmer, exhaust brake, Sirius radio and traffic/travel apps, more HP and torque. Truck definitely towed with more "authority" than my old 07 2500 (5.9 CTD).
For the most part, hit the Tow/Haul button, put it in drive and went. It down shifted a few times going up hills...once or twice I dropped it out of OD (6th) when it seemed to be lagging a bit going up a hill. There was a few times where it was in 5th and stayed there for awhile before it went back into OD.
Other than the higher RPM/bit more engine noise there did not seem to be much difference in 5th and OD.
Anyone else work things differently?
Thanks,
2016 Heritage Glen 272RLS
2017 Dodge Ram 2500 Big Horn, 6.7 CTD, 4x4
KRSmitty is offline   Reply With Quote
Old 03-20-2017, 08:48 AM   #2
EB should always be on regardless of towing or not. It definitely helps reduce soot on the turbo vanes. With the newer trucks you definitely need to drive it like you stole it. Around town lock it out of OD and it will run for ever.
donniedu is offline   Reply With Quote
Old 03-20-2017, 08:57 AM   #3
I agree...I like how the EB works. You keep it in the Full or Auto EB? I do see where it has a tendency of up shifting to fast. Must be a common thing. We own a Ford Edge and it does the same thing. Will use the manual shifting to keep it in a lower gear at times.
Thanks,
Old 03-20-2017, 10:56 AM   #4
shorthorn's Avatar
I always run my truck with Tow/Haul on and the EB on full. Only time I use automode is if I am in the hills on the interstate... Full EB is for coming to a stop. Auto EB is for holding a set speed.
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is offline   Reply With Quote
Old 03-20-2017, 03:57 PM   #5
Chuckinca's Avatar
We put ours in Tow/Haul and drive. It takes over most of the braking when in the mtns and will slow you down more when you let off the pedal for a while on the flats.
GR8!
2011 Rockwood Windjammer 2102W
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
(the max loaded 2006 F150 5.4L V8 would only go 55 MPH Westbound on I-80 in Wyoming)
Chuckinca is offline   Reply With Quote
Old 03-20-2017, 04:11 PM   #6
Wondering what kind of mpg you're getting while towing and how much weight are you pulling?
Ortep is offline   Reply With Quote
Old 03-20-2017, 04:44 PM   #7
13,500 pound fiver 10.5 to 11.5MPG at highway speed. Whatever that is.
Old 03-20-2017, 04:53 PM   #8
shorthorn's Avatar
13k lb 5er... to Pigeon Forge and back averaged just over 12
Old 03-20-2017, 05:25 PM   #9
My first trip with it...9-10K travel trailer loaded. 11.5 to 12.5 mpg
Old 03-20-2017, 05:56 PM   #10
Pathfinder75's Avatar
Just wanted to point out what some people do not realize. Both 5th and 6th are overdrive ratios. 4th gear is the 1:00 to 1 gear ratio. See: Aisin AS69RC vs Chrysler 68RFE Transmission Comparison for information on both
2007 model year launched (This should be your Transmission for non-H.O. motor)
CHRYSLER 68RFE TRANSMISSION RATIOS (1st=3.23 :1) (2nd=1.84 :1) (3rd=1.41 :1) (4th=1.00 :1) (5th=0.82 :1) (6th=0.63 :1) (Rev=4.44 :1)
or the 6.7L H.O. Trans. Introduced for the 2013 model year
AISIN AS69RC TRANSMISSION RATIOS (1st=3.75 :1) (2nd=2.00 :1) (3rd=1.34 :1) (4th=1.00 :1) (5th = 0.77 :1) ( 6th=0.63 :1) (Rev=3.54 :1)
My only point here is that you are not really straining it when it drops to 5th just keeping engine in the best RPM range.
Trade in progress - for Montana HC 353RL & Ford F350 6.7L
will miss 2012 Coachman Leprechaun 319DSF
TOAD -2011 Chevrolet Equinox 4-cyl. AWD
Souris River Canoe leTigre Quetico 17
Old Town Canoe Penobscot 17 Royalex
Pathfinder75 is offline   Reply With Quote
towing
