05-09-2015, 08:24 AM
Towing with a Rav4
Hey everyone, we will be going to Ohio in a month and we are bringing back a riding mower and a few other small items. I want to put a class 1 hitch on my wife's Rav4 instead of driving the truck. The specs say that the RAV can tow up to 3500 lbs with the V6 when "properly equipped." What does that include? What do I need to look for in the car to know?
Jared and Krista
2016 Sandpiper 371 REBH
2011 Ford F-250 SuperCab XL 6.7L TD, Curt 20K
05-09-2015, 10:15 AM
There should be some stickers in the drivers side door jam that will tell you the weights and limits.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
05-09-2015, 10:36 AM
Usually anything over 1000 lbs you will need a brake controller for. Use caution with u haul trailers as they make them so robust that they are twice as heavy as they need to be. And aren't class one hitches up to 1,500 lbs?
Just glad to get away
05-09-2015, 11:44 AM
Brake controller or just trailer brakes?
Class 1 - 2000 lbs
05-09-2015, 12:06 PM
Some U-Haul trailers have surge brakes. No controller necessary.
2011 Traverse LT, 3.6L, FWD
05-09-2015, 12:24 PM
You may want to inquire if there possibly was a factory tow package type option offered. This term may mean special gears and/or tranny cooler.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
05-10-2015, 02:26 PM
I don't know what year your Rav4 is. But a 2014 tow capacity is 1500 Ibs. You may be over doing it on the Rav4.
05-10-2015, 02:41 PM
Properly equipped means Factory tow package.
Check with Toyota dealer if yours has it, by its VIN.
05-11-2015, 01:52 PM
If you are sure you have 3500 lbs tow capacity (likely need an optional towing package), that's class 2. You should install a class 2 hitch, in case you want to tow something larger (like a utility trailer) someday.
Read your owner's manual to see what your tow rating actually is. Might need to provide your VIN to a dealer to find out.
05-11-2015, 02:49 PM
Ambassador
3500 lb towing capacity isn't the same as gross combined vehicle capacity. Be careful read your owners manual and check your manufacturers data plate. If it's just a lawn tractor then a class one should be fine, if it's 4 atvs and stuff then get a class 2. Most utility trailers don't have brakes.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
05-11-2015, 02:58 PM
Dad of 2 teenagers...
Toyota Towing package typically includes transmission oil cooler and wiring harness.
If you are towing 1500+ pounds, brake controller is a must (obviously the trailer should have electic brakes...).
Last thing, make sure to balance your cargo so you don't get too much weight on the hitch and exceed your RAV4's payload.
Bob the frog from Montreal
2009 Flagstaff 227 pup (Sold in 2014)
2015 Wildwood 261BHXL
2010 Mercedes-Benz ML350 Bluetec
ProPride 3P Hitch
05-11-2015, 09:35 PM
Ambassador
It's just a lawn tractor, not a toy hauler. the 4x8 trailer he will use for that probably has a 1200 lb capacity and most definitely does not have brakes of any sort. Tow package or not I think that V6 Rav 4 could handle a lawn tractor on a class 1.
05-12-2015, 12:38 PM
I agree. But if he has a class 2 vehicle, he might as well install a class 2 hitch. Cost and time to install is probably about the same.
05-17-2015, 03:09 PM
I read the brochure from 2008 and it just says the optional towing package has an upgraded alternator, fan coupling and radiator. But how do I tell if I have these vs normal ones?
Jared and Krista
05-17-2015, 03:54 PM
Usually a phone call to a toyota dealer parts dept. with your vin# and ask if you have the tow package. Or send me a PM and your vin and I can call my boys tomorrow and get u an answer.
05-17-2015, 06:09 PM
A small light weight trailer is what 400 pounds and lawn tractor another 500 more stuff your most likely still under 1200 pounds if you own a truck and have towing experience i would say you going to be fine just take it easy
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
