Old 07-08-2014, 12:08 PM   #31
Platokidd's Avatar
Towed for years with a half ton truck and it did a fine job. Upgraded to 3/4 ton truck, big improvement. jmo.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 07-08-2014, 01:47 PM   #32
thestrangebrew's Avatar
Just did my first ever real tow with the rigs in my sig. TV did fantastic going uphill. Going downhill was a little different. Could've been just me not knowing exactly what my setup could do, or my newb comfort level, but I felt the engine braking lacking in the ecoboost.
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s GVWR
thestrangebrew is offline   Reply With Quote
Old 07-08-2014, 02:08 PM   #33
Mddle of the Rd Extremist
MeepMeep's Avatar
No such thing as "too much truck". After trading up from 1500 to 3500, my only regret is that I didn't do it sooner. Takes a lot of pressure off knowing you can tow pretty much anything and go pretty much anywhere.....
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 07-08-2014, 02:21 PM   #34
B and B's Avatar
Dynamic braking while in Cruise control in an Eco is different than out of cruise, give it a try.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-08-2014, 02:21 PM   #35
cat1956's Avatar
I tow a Flagstaff 27rlws with a 2010 ford crew cab. 5.4 engine and a 3:55 rear end with tow package and intergrated brake control. I do have the equalizer hitch with built in sway control and LT tires which makes a world of difference to me.
Tommy and Wanda
2014 Flagstaff 27RLWS
2017 Ram 1500 5.7 Hemi
Equal-i-zer 1,200/12,000 Weight Distribution w/ 4-Point Sway Control
cat1956 is offline   Reply With Quote
Old 07-08-2014, 02:51 PM   #36
Did you have tow/haul on? It really helps out with the engine braking on descents.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 07-08-2014, 03:01 PM   #37
I did. Like I said, it was probably me being such a newb and not knowing what my setup could do on a descent more than the truck's fault. I literally popped my towing cherry this weekend so I'm not nearly experienced towing than some of you guys lol.
Old 07-08-2014, 03:55 PM   #38
ARLO
2011 F150, 5.0l, 3.73 gears, tow package, Reese torsion and sway control. .
We have towed our 829fkss flagstaff through the Canadian Maritime Provinces, the Adirondacks, around the great lakes, Myrtle Beach thru the hills of Pennsylvania and West Va. with no problems at all. I did install E rated 10 ply LT tires on the truck and E rated 10 ply ST tires on the trailer. You DO NOT need a hd truck if your 1/2 ton is properly equipped and matched to the size of the trailer you want to pull. .
rlocicero is offline   Reply With Quote
Old 07-08-2014, 05:47 PM   #39
schrederman's Avatar
Originally Posted by JohnIII View Post
I'd think at 6200# the F150 would still do rather well.
As I said, it does OK, but not great. Probably because my rear gear is 3.55 and I do not have the Max-Tow package. It's a 5.0 V-8 and not the Eco-Boost. The main reason I'm upgrading now is to upgrade the TT in a year or two. If not for that, I'd keep what I have. I'd consider getting the 1-ton but it is my daily driver and I doubt I'd ever have the need for it. The F-150 has been a great truck, and is still clean as a pin... complete with sling-in bed liner... (old furniture-movers quilt)...
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
f150, towing
