Old 09-17-2012, 09:26 PM   #21
Oklahoma Proud
MillerTime's Avatar
For got to add manual says not to use in traffic situations- no brainer but since I was quoting the manual, there it is.
Old 09-17-2012, 09:42 PM   #22
B47
Originally Posted by Road-King View Post
In my 07 Dodge, if I press the tow/haul button once, it goes into tow/haul mode. Press it a second time and it locks out the O/D. Third press and it's back to normal.
That is different than my 2012 Ram 6.7L diesel - you press the T/H button and it is engaged and when you press it again it is disengaged. It also disengages each time the engine is turned off.
Old 09-18-2012, 08:25 AM   #23
Helmsey's Avatar
2004 Chevy Duramax\Allison - One push of the tow\haul turns it on\off, press and hold tow\haul and it locks out OD (5th gear for my truck). When on the interstate I will usually turn on CC, if I see a larger hill coming up I will hit the gas pedal until I hear the turbo spooling and can easily hold speed. I have tried locking out OD for climbing longer\steeper grades but doesn't seem to be any different than getting the turbo spooled in OD.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 09-18-2012, 09:00 AM   #24
J_KHawthorne's Avatar
I use CC and also Tow/Haul mode when towing on the open road and the InterStates, but kick it off in towns. I also go out of CC and switch to manual when going up hills with steeper, extended grades. I also like to switch to manual on steeper extended downgrades so the engine helps control braking.
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 18,950 Nights camped 192
J_KHawthorne is offline   Reply With Quote
Old 09-18-2012, 09:29 AM   #25
I do the same except for the kicking it into manual part. My 2011 F150 has a 6-speed and tow/haul mode that does all that for me including engine braking.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 09-18-2012, 10:45 AM   #26
Another rat in the race
jar3316's Avatar
Talked to my company mechanic and he was a trans shop owner for years before he "semi retired" and works for us 2 days a week doing mait. and repairs on all our vehicles.
He stated and I am quoting as close as I can. If your tach is higher at a specific gear and speed than normal (unloaded), AND the vehicle "hunts" for a lower gear more, you should always put the vehicle in the lower gear.
As for CC he said the problem is that most vehicles will not down shift until the throttle is all the way to the floor, and most CC systems will not "floor a throttle" so even a small uphill section with a strain on the truck will cause a "bogging" state in the engine and the trans will react with "hunting" and "torque slip" in the trans until the CC gives up (because it can not maintain its speed) and shuts it self down.
So in his opinion CC used for either overdrive or a lower gear while on the open HWY with the person actively monitoring the throttle, tach, and shift count will be fine and in CA I would almost say it's a must considering the 55mph speed limit when towing (I got a speeding ticket for towing an empty HF trailer at 58 once on the 99 near Sacramento cost me $400+).
I personally use CC and overdrive/Drive in my tow rig but I have a V10 and only tow a >5500lbs trailer (I turn off overdrive for hills and mountain roads up and down)
A rainy day camping is better than any sunny day at work
2004 F250 V10 SD Xcab 2011 Wildwood T26BHXL
jar3316 is offline   Reply With Quote
Old 09-18-2012, 11:02 AM   #27
Guess you are finding there is no simple answer. You just have to listen/monitor your vehicle and use some common sense. Steep hills, turn it off. Heavy traffic, turn it off. Transmission hunting gears, turn it off.
Flat, free flowing interstate? Enjoy!
crasher is offline   Reply With Quote
Old 09-18-2012, 11:56 AM   #28
BeagleIL's Avatar
That's a new one on me. I've used the CC while towing for years and never had it shut itself down. I think my first reaction would be to think that the whole engine bit the dust before looking to see if the CC was still on...
Mark, Jenny, Adam & Lucy
2013 Rockwood Roo 233S
2015.5 Silverado 2500HD CCSB with Duramax/Allison
BeagleIL is offline   Reply With Quote
Old 09-18-2012, 12:08 PM   #29
My 06 Chev 2500 w/gas and 4 speed auto loses about 1mpg using cc. On almost every rise in the road it down shifts 2 gears to get up to speed right away. With the cc off, I can give it enough throttle to down shift only one gear.
wayne anthony is offline   Reply With Quote
Old 09-18-2012, 02:14 PM   #30
Timex's Avatar
Nothing wrong with the transmission downshifting to get up a hill is it?
Timex is offline   Reply With Quote
