Old 05-02-2011, 09:39 PM   #11
I guess it takes gas to make all that power.
But thanks for the report, my friend has ordered his, so will be glad to hear about your experience. He will only tow about 5% of the time, so it will work great for him.
Old 05-02-2011, 11:01 PM   #12
acadianbob's Avatar
The ecoboost moves so effortlessly that it may be that people are accelerating faster and towing at higher speeds? Or not . . . . It would sure be a kick in the pants if tow mileage was actually less than the 5.4. There is an extensive article in pickuptruck.com that inferred that the new 5.0 V-8 might actually get better mileage when towing. But a direct comparison has yet to be actually done. They were also clear that unloaded mileage is great with the ecoboost. This will be interesting to watch.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 05-04-2011, 10:01 AM   #13
thebrakeman's Avatar
Typical non-full-timer is only towing 5-10% of their total annual mileage.
IMO, the goal for a V8 alternative would be:
a. Similar or better NON-towing performance as the V8 alternative.
b. Better NON-towing gas mileage (90-95% of driving) than the V8 alternative. Should pay for the upgrade premium within a few years. If it takes 10 years to offset the engine upgrade premium, then you really haven't saved money, right?
c. Similar TOWING performance (5-10% of driving) as the V8 alternative, regardless of gas mileage.
If point b is satisfied (better non-towing mileage), then lower mileage while towing will not be a significant issue, since it's such a small percentage of total driving.
This is why many of these independant articles recommend full-time RVers stick to the larger V8 or SuperDuty/Diesels. For them, if towing mileage isn't any better, you might as well benefit from the added torque at low rpm from the big V8, and maybe better fuel economy of the diesel.
thebrakeman is offline   Reply With Quote
Old 05-04-2011, 10:09 AM   #14
MtnGuy's Avatar
Originally Posted by tugboat View Post
i have a eco boost, 4x4, crewcab short bed, 3.73 rear, tow max, i have just got back from a trip, towing a 30' tt rv, total wt. 6500 lbs. I had no problem towing with this motor, power was great, but, i did get, 8.3 mpg ave on this trip, i was easy on and off the gas, and stay around 65 mph. i was hoping for 10 to 12 mpg, i now have 4500 miles on it, so maybe next trip will be better. tug
tugboat, good report, and I hope you keep us update with future trips.
Old 05-04-2011, 10:09 AM   #15
acadianbob's Avatar
I agree with most of what you say except the latter. The 6.2 does have more torque ultimately than the ecoboost but that torque is at 4,000 RPM. Down low, where most of us tow, e.g. 2,000 RPM, I'll bet that the ecoboost is putting out more torque than the 6.2. It's tough to beat turbos for torque production.
Now diesel is a different matter of course.
Old 05-04-2011, 10:24 AM   #16
I'm a definite turbo fan (pardon the pun ). Drove a '89 Probe (turbo) for 10 years. It was the low-rpm torque that I loved most about it, as I didn't have to shift to pass somebody, and it was easy to drive around town without winding it out.
I was referring to the typical V8 generating torque at the lower rpm ranges (1000 rpm), versus the Ecoboost not doing anything until 2000 rpm.
The torque curves I have seen showed the Ecoboost not doing much below 2000 rpm, but the VERY steep curve quickly overtakes the V8s by 2500 rpm.
It's probably a V8 benefit that's only noticed when driving around town, especially when starting from a stop. But to some, they may appreciate putting around town between 1000-2000 rpm between shifts, rather than having to push to 2500 rpm.
I've never driven either of them. Perhaps the Ecoboost revs into it's happy place so easily that it's just as satisfying as the V8 at 1500. But I think that's about the only plus to the V8 (5.4 or 5.0 I'm not sure), is that torque generation WAY down low.
And when I say not doign much at 2000 rpm, I'm referring to the actual torque curve for the Ecoboost. It's torque curve literally starts at 2000 rpm. Below 2000rpm, the 5.0L V8 (and probably the 5.4L, too) is generating a LOT more torque than the Ecoboost, although they are equal by 2500. I'm not sure what that means. Does it idle at 2000 rpm? If not, what's it doing below 2000? I'm just trying to interpret what I see in the data.
Old 05-04-2011, 10:24 AM   #17
acadianbob's Avatar
I've been thinking about ecoboost towing MPG a bit. My guess is that this is a Jekyl and Hyde motor. I think every understands that unloaded mileage is quite good. But there is a lot of HP and TQ available there, and if you use it, I'm sure it will happily provide it while using the fuel to do it.
If you have driven and ridden in an ecoboost, you will discover that they are deceptively quick and powerful. It doesn't feel like you are doing anything. My buddy's ecoboost loafs onto the freeway; 1,400 RPM shift points. Then as you enter the freeway you look to see that you are already doing 65 mph. Now my 5.4 would be working pretty hard to do that; 2,500 RPM shift point, lots of throttle and lot's of effort and noise.
Because of fuel consumption, I have a light throttle foot with my 5.4. If you drive an ecoboost in the same leisurely way, the mileage is way better. (I've seen it on my buddy's dash computer; and watched it)
Similarly, when towing, I try to stay in overdrive. If a hill provides too much load, I back off to let it stay in overdrive; sometimes dragging down to 50 mph. Here again, the ecoboost will be deceptive. It will easily maintain the original speed where my 5.4 cannot hold overdrive. So, I think you will find yourself "doing more" with the ecoboost; perhaps without even realizing it. That is likely to take fuel. My bet is that a light foot when towing will return good fuel economy.
Well, I have the 5.4 with 3.73s (4WD) with a Surveyor 235RKS. My buddy has a 4WD ecoboost with 3.73s and a Surveyor 264. We are doing some camping together so will have a chance to compare fuel mileage in exactly the same conditions and speeds. The trailers are nearly identical in profile and weight as well. We shall see . . .
Old 05-04-2011, 10:41 AM   #18
Reality will prove out over charts and graphs, for sure.
I definitely agree about the driving ease of a turbo. And that's the beauty that it's taken American OEMs so long to deliver. It took $4 gas before they would invest in real turbo technology at a hi-volume basis.
My 2.2L I4 turbo-Probe beat 5.0L V8 Camaros, yet I got 35mpg on a trip to Traverse City and back one weekend. That was technology from 22 years ago!! It's not new. When they put a 2.0L Ecoboost in the new Focus (with direct injection and other doodads), it will probably be a screamer around town, getting 40mpg on the highway.
Like you said, my mpg was probably no better than that Camaro's during that stoplight race. But that's my point: When you want/need the performance (small percentage of driving), it's right under your right foot, just waiting. But when you want to save money, you just take it easy! You can't do that with a non-aspirated engine.
Jekyl & Hyde....I like that analogy!
Old 05-04-2011, 12:01 PM   #19
If you are referring to the torque curve from pickuptruck.com, they mentioned it was very hard to get readings from the EcoBoost at low RPM's. It took a Ford engineer to finally get decent numbers. The torque is there, it is just very tough to measure on a dyno.
Look at the image below. The steady state torque of the 3.5 EB is NEVER below the torque of the 5.0.
Below is the full writeup:
http://news.pickuptrucks.com/2011/04...8-engines.html
2012 Flagstaff 8528 BHSS
2008 Ford F250 Crew Cab 4x4 6.4L Power Stroke
fordmantpw is offline   Reply With Quote
Old 05-04-2011, 01:33 PM   #20
acadianbob's Avatar
Fun discussion everyone!! And a nice chart there. The chart does make the point I was trying to make about the ecoboost "out-torqueing" the 6.2 at any RPM below 4,000; where you really want it. And the 5.0 never matches it.
Brakeman, I'm with you on turbos. I had a 1.8 turbo VW Jetta. Pulled like a V-6 when needed and economy like a 1.8 4 cyl in normal driving. Best of all worlds.
If there is any issue coming off of idle with the ecoboost, it would be somewhat masked by the very low first gear; 4.xx something.
