Old 05-04-2011, 03:16 PM   #21
I believe that the problem is two fold, people are complaining about mpg's while towing with a 3.55 in an ecoboost that was not yet broken in yet. Let's look at the mpg's of people towing with a 3.73 rearend and a broken in engine.
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 05-09-2011, 10:16 PM   #22
acadianbob's Avatar
My buddy with the Surveyor 264 and the ecoboost with 3.73s just got 10 mpg at 65 to 70 mph on his first towing trip. only 1,000 miles on the truck. flat topography.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 05-10-2011, 08:10 AM   #23
getting better
I did get better mpg on a very short trip towing the other day, 10 mpg, I now have 5000 miles on the motor, (ecoboost 3.73 tow max, 4x4, crew) my first trip was 8.5. I tow a 30 tt, flagstaff, total wt. 6500. I have a very long trip coming up soon, and will post my info.
tug
tugboat is offline   Reply With Quote
Old 05-10-2011, 02:13 PM   #24
acadianbob's Avatar
Yep, it's the long trips that really tell the story. Then you can do back to back tanks and often under different conditions. I can average 11 mpg towing on 55 mph 2-lane highways in the midwest but a trip to the Rockies with wind and elevation changes is usually 10 mpg. These are 2,000+ mile trips so a good read.
Old 05-12-2011, 10:20 AM   #25
UpNorthMgoBlue
dlzeller's Avatar
I have just purchased a F150 with eco boost and it's great, no problems at all with towing and I also have a 30' trailer. I have towed 3 times already and it's been great. I got almost 9.5 mpg. I am taking a longer trip this weekend and will see how it does and post.
dlzeller is offline   Reply With Quote
Old 05-14-2011, 08:08 AM   #26
acadianbob's Avatar
detail are always good. trailer weight. travel speed. temp and wind conditions. obviously, wind and travel speed have a huge effect on mileage. i look forward to reading about your results. thanks!
Old 05-14-2011, 09:00 AM   #27
DF5.4's Avatar
Think of it this way. Normal/empty cruising, low boost, the engine is using 3.5 L of air. Maybe a little more since there is some boost. It uses the proper amount of fuel for that amount of air. When you need the power the the turbo spools up and forces the equivalent amount of air the bigger V8s need. It has to add the correct amount of fuel for that amount of air. It does not matter what size the engine is. Fuel use is determined by the amount of air it uses.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 05-16-2011, 07:58 AM   #28
thebrakeman's Avatar
Right. So unless you are constantly drag racing or doing heavy hauling, there is money to be saved.
Let's say 5% of total mileage is towing, and another 5% is having fun at stoplights. That leaves 90% as normal cruising and getting to work and back. That's 90% of the time getting better gas mileage.
The 10% you are working it or having fun, you expect to use more fuel. But overall, you will save money.
thebrakeman is online now   Reply With Quote
Old 05-16-2011, 08:15 AM   #29
UpNorthMgoBlue
dlzeller's Avatar
Hello, just got back from a weekend haul to Boyne, I have a 30' Wildwood and the road was hilly, windy. Had to travel back at about 50 mph due to the wind and trailer was empty of water and waste. I got 9.7 mpg on this trip and was very happy with that due to the weather conditions. My 2011 Ford F150 5.0 with eco boost did very well with power and holding the road. Travel distance was about 190 miles
Old 05-16-2011, 08:21 AM   #30
DF5.4's Avatar
Do you have the 5.0 V8 or the 3.5 V6 EcoBoost?
Doug
