Old 05-16-2011, 08:27 AM   #31
UpNorthMgoBlue
dlzeller's Avatar
Hi Doug, I have the 5.0 V8, sorry if I misslead anyone. I do love the way the truck pulls..................
dlzeller is offline   Reply With Quote
Old 05-16-2011, 08:31 AM   #32
DF5.4's Avatar
I've heard good things about the new 5.0
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 05-16-2011, 08:46 AM   #33
acadianbob's Avatar
The new 5.0 is awesome. I've only test driven it though. But I am concerned about that fact that the torque peak is at over 4,000 rpm. It's too bad that Ford finally caved in to the automotive mags that continually ragged them about their horsepower. Ford bravely pointed out that it was torque production that counted. The 5.4 did pretty well in that regard; at least peak torque was in the 3,400 rpm range. Now we get the high rev'ing V-8 that the competition has had. Not sure that is a step forward; at least while towing. GREAT sounding motor though and it moves well empty.
Not knocking anyone's 5.0! It's a very nice engine.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 05-16-2011, 09:23 AM   #34
Doesn't the 5.0 out-torque the 5.4 through most of the rev range though? My 5.4 was a great torquer, and if the 5.0 out-torques it down low plus likes to rev and can breathe at higher RPMs, then it should be great for towing and all-around! The 5.0 truly sounds like a great engine (and from what I have heard, sounds great).
2012 Flagstaff 8528 BHSS
2008 Ford F250 Crew Cab 4x4 6.4L Power Stroke
fordmantpw is offline   Reply With Quote
Old 05-17-2011, 12:58 PM   #35
thebrakeman's Avatar
Most non-towing people don't understand that torque generation is a more important stat than horsepower. Not a problem on sites like this.
But I think there may be some here that see a torque peak at a higher rpm, and automatically think it won't be as good for towing.
As someone already implied, I think the 5.0L generates more torque at it's torque peak. The question is, how much torque is the 5.0L generating at the 5.4L's torque-peak rpm (3400 according to Acadianbob)?
If the 5.0L generates about the same amount of torque @ 3400 as the 5.4L, then continues to generate more torque thru 4000 rpm....that's a good thing!
The Ecoboost engine appears to generate less torque at the 5.4L's peak, but it quickly makes up for it within about 500rpm (IIRC).
I think the 5.0L is really meant to be the improved replacement workhorse for the 5.4L, with the V6-turbo intended more fpr part-timer towing (a step-up replacement for the 4.6L 3-valve).
thebrakeman is offline   Reply With Quote
Old 05-17-2011, 01:01 PM   #36
Right. The 5.0L V8 is not an Ecoboost engine.
THAT would be a screamer!!
Old 05-17-2011, 01:32 PM   #37
Ecoboost has more power and torque than the 5.0 so I believe there is a complete shift. The 5.0 is probably not meant to replace the 5.4...It is meant to provide a viable option for those truck buyers klinging to V8's and skeptical about a blown v6.
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 05-17-2011, 04:50 PM   #38
acadianbob's Avatar
Yep right on!
And that IS a good point on 5.0 torque. It would be interesting to see the torque output of the 5.4 and the 5.0 both at about 3,500 RPM. It's quite possible the 5.0 matches or exceeds the 5.4 at that speed. Still, too bad that the peak is so high on the 5.0. I still say Ford caved in on this one.
Old 05-19-2011, 06:00 PM   #39
Steeljag's Avatar
removed by poster!!
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 05-24-2011, 11:23 PM   #40
TheHugens's Avatar
New Eco Boost Owner
I just bought a 2011 F150 4X4 Lariat with Max Tow, 7650 GVWR, short bed. We are considering the Rockwood Ultra Lite 8280WS. Anyone out there have an experience with that?
TheHugens is offline   Reply With Quote
