Old 03-15-2016, 08:09 AM   #1
Towing with Equalizer hitch and air bags or Timbrens
Sorry if this has been already addressed.....looking for actual experience with Timbrens and/or air bags (Firestone or Air Lift) specifically on an F150. My TV is a 2015 F150, 3.5 Ecoboost, Max Trailer tow pkg. My TT is a 2016 Lacrosse 324RTS. TV rated to tow 11,900. TT GVWR is 9800. Tongue weight 980. I am using a n Equalizer brand 4 point 12K hitch with 1200# tongue max. My issue is that when towing the front end feels very loose/ unstable. I have worked with Equalizer tweaking the hitch settings but still have not solved the problem. Dealer is no help at all. Head of service told me that the Equalizer hitch was for sway only not weight distribution. DUH!!! Any suggestion/input/ etc. appreciated.
Mypedlcar is offline   Reply With Quote
Old 03-15-2016, 08:15 AM   #2
Yes Dont use that Dealer for Hitch advice! Youroo!!
Old 03-15-2016, 08:16 AM   #3
northstar1960's Avatar
IMO to much TT for the TV
northstar1960 is offline   Reply With Quote
Old 03-15-2016, 08:21 AM   #4
I was thinking the same thing northstar. However Ford dealer swears it will tow 11,900. I am 2100# under max. Forest River advertises this TT and even the next size up as half ton towable. Frustrating for sure!
Old 03-15-2016, 08:28 AM   #5
fonzie's Avatar
Post your door jam sticker for max ccc (yellow sticker) this will tell us how much cargo your truck is rated for.......
Here is 2015 Ford towing guide for more info...
http://www.ford.ca/resources/ford/ge...de_english.pdf
Fonzie
Old 03-15-2016, 08:28 AM   #6
WFD
First mistake was listening to the dealer with regards to tow capacity. Although the figure he quoted you may be accurate and straight from the Ford info...majority of these dealers and sales people have never even towed a utility trailer let alone a travel trailer. Onus is on us to know what we can and can't tow comfortably.
Not sure about current F150's but I used to have an '09, and when Ford moved their location for rear shocks installing the Firestone airbags required some modifications, mind you I was towing a 5th wheel so not sure if that was the difference.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 03-15-2016, 08:52 AM   #7
Name:	ImageUploadedByForest River Forums1458049863.426075.jpg
ID:	101982Click image for larger version
Name:	ImageUploadedByForest River Forums1458049882.899785.jpg
ID:	101983Click image for larger version
Name:	ImageUploadedByForest River Forums1458049899.840299.jpg
Here are pix of the stickers from the TV and the TT...
Old 03-15-2016, 08:58 AM   #8
For the record...left out of,original post......truck is a super crew, 2WD with a 3:55 rear end.
Old 03-15-2016, 11:47 AM   #9
You're rolling on P series tires if I read into those stickers correctly. You've got almost 5 tons of TT wagging you around on those soft sidewalled tires. Not to mention the lesser TV weight of a 150 vs 250. A switch to LT's would certainly help, I would think.
David and Vicki
7 year old Springer rescues Sydney and Piper
2014 GMC Denali 3500HD Dually Crew Cab Duramax/Allison stock
2016 Dutchmen Denali 287RE "The Dog House"
Eaz Lift WDH 1400# w/ Blue Ox 2 1/2" trunion
EezTire TPMS
Springerdad is offline   Reply With Quote
Old 03-15-2016, 11:48 AM   #10
WSY DD693's Avatar
My TV is a 2010 Dodge Ram 1500 4WD with Firestone spring air bags. My TT is a 2008 Surveyor 303. I have not used scales, but guess to be towing around 8,000 and TV is rated for 10,500. I also used the Equalizer weigh distribution hitch and have no issues. I blew a TT tire at 65 and didn't even feel it until my wife thought she heard a noise. Are you sure the Equalizer is adjusted properly?
2008 Modified Surveyor 303
2010 Dodge Ram Laramie 4x4
2013 From FL to Pick up Surveyor Islip,LI, PA,NY,VT,NH,MA,CT,NY and Home
2014 Sebastian Charleston,SC to Finger Lakes, Lake Erie, Lake Cowanesque,PA and home
2015 Sebastian to PA,NY,WI,MN,return to NY and home
2016 GA,SC,NC,TN,KY,OH,PA,NY,to Sebastian,FL
WSY DD693 is offline   Reply With Quote
air bags, equalizer, hitch, towing
