Old 03-27-2011, 06:36 PM   #11
(Kim)
Labzy's Avatar
Ok, I'm real new also, and I have learned alot from the helpfull guys on here.
So, you have come to the right place for guidance!!!!!
I also was told faulty information about towing stats etc. from trailer and auto dealers.
But I guess if I always remembered the addage "mediocrity cuts across all professions" I wouldn't have been so surprised by it.
This is my understanding about trailer ratings as learned from this forum and my good friend Google.
To determine what your truck can handle, first you need to know what the Trucks GVWR is, and from there determine what your payload capacity is.
So lets try this and fill in the blanks with your numbers.
(GVWR of Truck) 7150lbs - Curb weight = _______lbs of payload
_______lbs of Payload - Passengers - Cargo - Tongue Weight = _______lbs
This last number must be higher than 0 if it isn't you are over the GVWR of the truck, and you better look at a different trailer.
If you are all good here, let's move on.
GCVWR = 13,000lbs
13,000lbs - 7730 (GVWR of Trailer) = 5270lbs Truck weight (which is too high)
If you take your 13,000lbs and subtract the number that you calculated on the 2nd line, that to me would be a more correct GVWR of a possible trailer (factoring in a lower tongue weight of course)
Please correct me if I'm wrong
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 03-27-2011, 07:17 PM   #12
Go to website (Changears.com) you supply the INFO and they tell you,No guessing! Youroo!!
youroo is online now   Reply With Quote
Old 03-27-2011, 07:56 PM   #13
Could not find changears.com website typed in and googled nothing came up?
Doll86 is offline   Reply With Quote
Old 03-27-2011, 08:35 PM   #14
sherdep's Avatar
he must have meant changingears.com
Travel Trailer Weight Calculator
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 03-28-2011, 05:40 AM   #15
Yes thats it, Thanks. Youroo!!
Old 03-28-2011, 05:59 AM   #16
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
Go have your truck weighed to see the REALLY weight loaded (gas too)...13k is NOT what a F150 can haul... I have one! Also depends on the accessories too... is it a 4 door? Do you have a bigger/ heavier rear axle? Truck manufactures tend to over estimate their towing capacity.
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 03-28-2011, 08:00 AM   #17
prof_fate's Avatar
Ain't that the truth! And google isn't helpful on this subject as you'll always find the max tow rating a vehicle can handle under ideal conditions/options.
The difference between ideal and reality on my expedition is 1500 lbs. Things I didn't find on the net that are in the owners manual that affect tow rating are rim/tire size. Bigger rims lower the tow rating (cause the lower the load rating). 4x4 will lower tow rating (more weight on tow vehicle), options as mentioned affect it, and then there's the little paragraph that says "trailer frontal area not to exceed 60 sf"
Since the expy is F150 based i'd imagine it's about the same for you truck.
13,000 - truck wt empty (5400?) leaves 7600. Add in cargo (people, pets, gas, firewood, HITCH, etc) - 800lbs? That comes off the 7600 leaving 6800 lbs for the trailer and everything you put in the trailer.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 03-28-2011, 08:10 AM   #18
itch'n to road trip
campnqueen's Avatar
Pro fate - "trailer frontal area not to exceed 60 sf"? is this for a fifth wheel? I am just guessing....Never heard this term before.
Jasper Ga.
Old 03-28-2011, 09:54 AM   #19
prof_fate's Avatar
Thats in the book for the expedition, an SUV so it can't be for a fifth wheel. Makes sense regarding wind resistance on the highway though.
I've not measured the frontal area of any trailer, but if it's 8' wide and 8' tall that's 64 sf... now the grey wolf we bought has a very sloped front of the hard plastic material so it will be more slippery than most other designs.
2011 Grey Wolf 28BH
Old 03-28-2011, 10:08 AM   #20
Herk7769's Avatar
I found this article regarding DRAG index
This article regards how drag is computed based on shape, speed, and area presented to the wind. It is pretty complete but the example is F-16 external stores (which vary from sleek fuel tanks to "dirty" munition shapes).
Drag index of a store is a shorthand way of estimating the drag of a store at a typical cruise mach number. The basic airplane has a drag index, and each piece of added equipment (pylons, tanks, bombs, pods, etc) had a drag index. When all the drag indexes (indicies??) are added, the complete configuration drag index is found.
The drag on a body is drag coefficient x dynamic pressure x reference area, or D = Cd x q X S. To get the total configuration drag, you could look up the Cd for each item (store, pylon, pod, basic airplane), look up the reference area for each item, calculate the drag on each item, than add all the drags together. A simpler way is to use the same reference area for all elements, add all the coefficients (drag indexes) together, and calculate the total drag.
There should be a list of store drag indexes somewhere in the stores TOs, but if you can't find it or if the store isn't listed, all is not lost.
A drag index for a clean F-16 is the drag coefficient at 0.8 mach using the reference area of the F-16 (300 sq. ft.). So what is a drag coefficient? Using a clean F-16 as an example, say the drag at 0.8 mach, sea level, is 8000 pounds.
D = Cd x q x S
so Cd = D / qS
D = 8000 lb
q at .8 sea level is 947 lb/ sq ft
S = 300 sq ft
so Cd = 0.0282
The basic airplane drag index would be 282, because it is more convenient to use whole numbers instead of all those decimal places.
To calculate a drag index for a store, first you have to find its drag coefficient based on it's cross section area. That information (Cd) may be difficult to find, but the manufacturer should be able to give it to you. If that fails, then use 0.15 for pointy store (Mk-82) or .20 for a blunt store (AGM-65) as a good estimate for Cd. Then calculate the Cd based on the F-16 reference area, 300 sq ft.
Cd (F-16 ref area) = Cd x (store cross section area / 300 sq ft). This value, after removing the 4 decimal places, is the store drag index.
Another way to estimate a store drag index is to find another store of similar shape, and use its drag index multiplied by the ratio of the store cross section areas. For example a Mk-84 and a Mk-82 have similar shapes. If you know the -84 drag index, (DI-84), you can estimate the DI-82 :
DI(82) = DI(84) x Area (82) / Area (84)
I apologize if I've gone into more detail than you wanted.
So if you made it this far; drag must be overcome with engine power delivered to the drive wheels, so fuel economy and towing performance is based on:
Pointy is good; blunt is bad
Slow is good; fast is bad
Smaller cross section is good; tall and wide is bad
HAM CALLSIGN - KC3FFW
f150
