Old 03-13-2019, 08:49 PM   #1
Towing with Ford F150 with 3.5 Eco Boost
Hi all, I am looking to haul my 2018 Forest River Heritage Glen 272 RL. I have a 2011 Suburban but capacity is 8000 pounds so I am maxed out. I am looking at leasing a 2019 Ford F150 with the 10 speed trans, 3.5 eco boost, 3.55 rear, and max trailering package. This combo is rated at 13,200 lb. towing. Does anyone have feed back on this truck for towing. Would appreciate good and bad. Thanks all.
Pop Pop is offline   Reply With Quote
Old 03-13-2019, 09:06 PM   #2
I've a 2011 f150 crewcab ecoboost with 3.73 rear diff and max tow package. The payload for my truck is 1830lbs. It towes my trailer Rockwood 2703ws really well. I am very happy with my set up. I also use an Equalizer 4p distribution hitch.
pibi is offline   Reply With Quote
Old 03-13-2019, 09:19 PM   #3
SailorSam20500's Avatar
You are likely going to be pushing your payload limit on the truck. Trailer has a GVW of around 9,600 lbs. Your ready to camp TW can easily be above 1000 lbs. From what I've seen, payload on the F-150's will be somewhere between 1400-1800 lbs unless you get one of the max payload trucks which are low trim and probably special order only. If you go with this combo, I would strongly recommend a Propride or Hensley hitch.
I think there is one for sale used on this site and myrvtalk.com has one for $700 (located in KY).
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 03-13-2019, 10:57 PM   #4
bikendan's Avatar
The Payload package you should look for is the HD Payload package, not Max Payload package.
If you order the HD Payload package, it should automatically come with the Max Tow package.
Equalizer WDH
Old 03-13-2019, 11:03 PM   #5
Scoundrel
HangDiver's Avatar
^^^^^This.... or you might want to consider a 3/4ton F250 gasser...
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 03-13-2019, 11:07 PM   #6
I have a 2018 F-150 and it's an excellent truck but there is no way I would use it to pull that trailer.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 03-14-2019, 12:35 AM   #7
bikendan's Avatar
Holy Mackerel! That TT is HUGE!
No way would I tow a 34'+ TT of that weight, with a F150. And I own a F150 3.5 EcoBoost with the Max tow package and 1828lbs of payload.
That TT needs at least a 3/4 ton.
Equalizer WDH
Old 03-14-2019, 05:18 AM   #8
From my own experience you will certainly be able to pull that trailer. What you will find though is that you will be close in all your numbers and you will be doing math in your head before every tow trip to ensure that you are not exceeding payload. You will also be looking for ways to improve the tow experience (tinkering with the hitch, air bags, LT tires, etc etc).
My experience became a whole lot less complicated when I went to a 2016 F250 6.2L gasser.
Either way, have fun!!
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
Martsing is offline   Reply With Quote
Old 03-14-2019, 12:35 PM   #9
I wouldn't want to be in front of you if you had to stop quickly. Go with at least a 250.
Jdb95650 is offline   Reply With Quote
Old 03-14-2019, 01:30 PM   #10
Unhappy
Thanks all for your feedback thus far. Ford does not lease 250 series trucks so if I do this it will have to stay in the 150 series truck. I only tow it a few times a year and have been towing trailers of all kinds for 40 plus years up to and including 80,000 pound tractor trailer combos. Payload is 7030 lbs for the max trailering combo 1500 and I will be at 6500 max. Trailer weighs 7400 and tow capacity is 12,700 . Both the Ford dealer and the RV dealer says I will be fine with plenty to spare. Can't understand why everyone is so against this truck for this trailer.
f150, ford, towing
