Old 02-23-2011, 08:33 PM   #21
sherdep's Avatar
I am currently running 305/70-18 (35") Dick Cepek FC II on my Dodge Lifted 6" with the Hemi - so far havent had an issue with what I have towed with them
They are Load Range E - 10 ply
I have also had the Nitto Mud Grapplers in 35 x 12.5 x 20 and have towed a 21 foot boat or car trailers - only issue I have ever had was when it was wet and when applied the brakes it made my truck slide since the trailer didnt have brakes - this will be the first travel trailer to tow with my present setup
The less sidewall you can go with - the better the ride IMHO and also like stated above the Load Range and the Ply will make a diffrence as well - which being a tech I would think you have already factored that in.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 02-23-2011, 11:11 PM   #22
Glenn5995's Avatar
Toyo Open Country M/Ts are a good choice if you want a somewhat aggressive tread, but still retain good road manners and stability for towing. They are kind of an aggressive AT or a mild MT depending on how you want to look at it. By their own description:
The Open Country M/T is designed for full-size pickups driven by enthusiasts who require extra ground clearance, load-carry capacity and off road capability with great on-road performance.
Just something for your consideration. Good luck with whatever you decide upon.
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
Glenn5995 is offline   Reply With Quote
Old 02-24-2011, 08:34 AM   #23
Jsr9878's Avatar
Thanks skidoonut. That's what I was wanting to hear, someone who has them and has no issues.
Jsr9878 is offline   Reply With Quote
