Old 04-10-2019, 11:48 AM   #1
Towing with Ram 1500
We are currently looking for a new tow vehicle and on a limited budget. Here in western Massachusetts it is hard to find a 3/4 ton that isn't rotting out or been abused as a plow truck.
I came across a 2011 Ram 1500 quad cab Laramie with 3.55 gears 20 inch wheels, our current trailer is 4000lbs dry and 22 feet so I feel confident this would be an improvement over the Durango we currently tow with.
My question is we are looking at a Salem cruise lite 263bhxl with the sticker weight just under 6000lbs dry. With this being a 32 foot trailer would towing with the half ton be difficult? Best information I found is max trailer weight 8350lbs but I know the length of the trailer can make a difference.
daybreak is offline   Reply With Quote
Old 04-10-2019, 12:20 PM   #2
Denver To Yuma In 90 Days
Look out west for a used 3/4-ton truck for sale in great shape...
They are all over the place!
JohnD10 is offline   Reply With Quote
Old 04-10-2019, 12:28 PM   #3
yea if you want a truck with 180,000 miles or more . been looking for quite sometime unless you pay almost retail for a used low mileage truck almost better buying new at least out west . plus you have to watch out for all the traded in oil rig trucks that get beat to heck
MR.M is offline   Reply With Quote
Old 04-10-2019, 12:30 PM   #4
VernDiesel's Avatar
That is probably ball to bumper the floorplan is likely 28'. 6k dry normally turns into 7k camp ready which would warrant a WDH with built in sway control. And if using a half ton a trip to the scales to assure a stable setup.
If you get a used Ram 1500 I would look for a MY 13 so as to find the dramatically better 8 speed transmission. You might also prefer the 3.92 gear.
I have had the best luck with Andersen, Husky Centerline, and Blue Ox sway pro weight distribution hitches. Chinese steel off brand hitches and harsh riding noisy square springs bars not so much. Make memories family camping.
The answer to what can my 1/2 ton tow; Generically whatever TT has a GVWR less than TVs max tow rating. Specifically is found on CAT scale via weight distribution with TV TT & WDH. Best motor & gearing all 5 Mfgs within specs IE safe & stable normally to 8k but passengers & bedload reduce this. RAM 1500 ED max tow 9,200, max axle ratings 3,900, max 09-18 CVWR 15,950, axle weights me & gear 3,240 steer 2,560 drive
VernDiesel is offline   Reply With Quote
Old 04-10-2019, 01:09 PM   #5
bikendan's Avatar
You need to look at the truck's payload capacity sticker. Payload capacity is more important than towing capacity since nearly all vehicles will run out of payload capacity WAY before reaching max towing capacity.
I wouldn't be surprised if that Ram had the same or lower payload capacity than your Durango.
You also didn't mention engine size or if it has the factory tow package.
Equalizer WDH
Old 04-10-2019, 01:30 PM   #6
Agreed, OP mentioned Laramie and 20" wheels, none of which are important to tow capability.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 04-10-2019, 01:38 PM   #7
I have a 2014 Ram 1500 Crew can. I use an E4 Equalizer hitch. My trailer is a 2019 Wildwood 30KQBSS. 32 feet total length. Dry weight is 6900. Pulls just fine. I even have 35 tires. Would do even better with stock 20s...lol
CUBS_WIN is offline   Reply With Quote
Old 04-10-2019, 01:39 PM   #8
I also have a Airlift 1000 setup in the rear as well
Old 04-10-2019, 03:48 PM   #9
Ok let me start by saying yes it is relevant if you look at the charts you will see that the 2011 Quad Cab Laramie 1. they only come with the 5.7 L Hemi, 2. the difference between the 17" and 20" wheels is small but makes a difference.
The GVWR 6,700 Payload 1,570, GCWR 14,000 with a recommended max trailer weight of 8,350 My questions was not about tow capacity as I can see a 6000lb dry weight is fine my question was about towing a 32' trailer with a half ton.
As for the Durango it has 3.21 gears with a 4.7 L V8, max tow capacity of 6,000 lbs. I can't recall the payload off the top of my head but anytime we go away for more than a weekend we are for sure over it.
VernDiesel thank you very much I didn't think of the length as being less for just the floor plan which is where the concern is. We use a WDH now and would get a bigger one for the new trailer.
2008 Dodge Durango
2015 Salem cruise lite 195bh
Old 04-10-2019, 04:15 PM   #10
Failure is my business
2Evil4U's Avatar
You can pull it of course. But the larger unit will probably be about maxed for the 3.55s.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 278,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83, 2018: 44, 2019: 78
2Evil4U is offline   Reply With Quote
500, towing
