Old 08-06-2014, 09:57 AM   #11
Canadiancrew's Avatar
Originally Posted by schrederman View Post
I just moved up from a '11 F-150 5.0 - 3.55 axle, towing 6200# loaded. I will be upgrading the TT to something on the order of 9000# loaded next year and was pretty sure the F-150 wouldn't handle it. The 6.7 Cummins doesn't act like the TT is back there... Being an old gear head, I was a touch dubious about the Eco... I am still wondering how one with 150K miles will be doing... The cylinder pressures have to be way up there to generate that kind of power...
Yes I have wondered the same thing. How will they stand up with high towing miles on them? I wonder how a gently driven never towed high milage ecoboost would compare to one that has towed a lot and been driven with the ecoboost operational a lot of the time. I would think a boost gauage or even an idiot lite would be a nice feature to monitor how your engine is being used. I do not use an ecoboost engine for towing but htinking I would prefer the 5.o Liter as we contemplate an f150 for our next TV. I do drive and ecobbost engine in my current company car and my last one. I like the way they perform. Currently have a 2014 Fusion. The 2013 escape I had with a 2 liter really performed but sucked in the gas milage.
Canadiancrew is offline   Reply With Quote
Old 08-06-2014, 01:01 PM   #12
thestrangebrew's Avatar
I currently have the Ecoboost & TT in my sig. I'm using the the Andersen WDH and so far I haven't had any problems towing it. It's a great TV for the lighter TTs and HTTs out there. I don't know if I'd go with anything heavier just for payload concerns. With gear and passengers, I'm already within 100lbs of my max. (~1770lbs or something like that).
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s GVWR #6402
thestrangebrew is offline   Reply With Quote
Old 08-06-2014, 01:26 PM   #13
jevanb's Avatar
Originally Posted by Canadiancrew View Post
I would think a boost gauage or even an idiot lite would be a nice feature to monitor how your engine is being used..
I dont have a echo, but on my boost gauge`s if the pressure goes up the MPG`s go down
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
jevanb is offline   Reply With Quote
Old 08-06-2014, 06:56 PM   #14
Disney camper
camper67's Avatar
I have a 2013 Ecobeast and a 269 Solaire (7,000 loaded) and it performs like a small diesel. That low end torque feels great. On my last trip to The beach I was able the let cruise maintain 63 mph in mostly 6th and 5th gear.
Like others have said, get one with a higher payload. Hitch weight, passengers, and bikes puts my 1400lb payload at the limit. I wish I had payload. Click image for larger version
Name:	ImageUploadedByForest River Forums1407369357.147503.jpg
camper67 is offline   Reply With Quote
Old 08-07-2014, 02:14 PM   #15
We have a 2013 Eco Lariat Screw with max tow 3.55 gears and the select shift transmission. Our previous truck was a 2007 150 with the 5.4 v8 3.55 gears. In our area we have many "grades" that we have to tow up and down to get anywhere. The biggest ones are the Whitebird grade and the Lewiston grade which are both 7% grades that climb for 5-7 miles. Our trailer is a 2013 Flagstaff 831FKBSS. GVWR at around 8,400lbs. The Eco climbs these hills with the trailer at 50-55 MPH in 3rd gear at 3-3,300 rpms. Iv taken to putting the transmission into manual mode while towing and it has worked very well. When going up the hills i can just lock it in 3rd and climb up one side with ease and back down the other side with minimal braking. When we pull into camp or a gas station people always remark about how they wouldn't think a 150 could tow a trailer of our size. The look on their face when i tell em its a V6 is priceless.
Name:	top of grade resized.jpg
imafordboi69 is offline   Reply With Quote
Old 08-14-2014, 08:41 PM   #16
I towed the Trailer in my Sig with the F150 EB, 3.73 in my sig. You will not regret that combo. Tows great, daily drives great. I ordered mine with the HD payload option so I could tow the Fiver. Ultimately I wanted 4x4, and even if I got a truck with HD payload I would have been over the GVWR on the truck. The F350 solved the GVWR problem quite well, though it is not nearly as good of a daily driver as the F150 was. I solved that by finding a gently used mid-size SUV to use for daily driver duties...
I started with this:
I went to this:
As mentioned, the truck performed great with both trailers. The low end torque is pretty impressive with the EB.
But, I ended up with this:
Next trip out I will have to get a picture or tow all hitched up.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 08-14-2014, 08:48 PM   #17
B and B's Avatar
No issues here with 9500 lbs of Rockwood behind mine. Mileage kind takes a hit but the torque is unbelievable. I also have a 5 year warranty so if after 5 its not working I will move on. For now can not beat it.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
Old 08-18-2014, 02:21 PM   #18
Picked up my new 2014 F150xlt ecoboost 3.73 max tow max payload Crewcab.
I upgradced the tires to E rated 10 ply HT3 Coopers. First tankd through, I averaged 18.7mpg,
rlocicero is offline   Reply With Quote
Old 08-18-2014, 06:24 PM   #19
acadianbob's Avatar
Nice! I remember we exchanged PMs awhile back and you decided to get the 5.0 as you were nervous about the new ecoboost technology. Enjoy your new truck. The torque delivery is tremendous.
2012 F150 FX4 Ecoboost, 2016 Surveyor 274BHS
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 08-18-2014, 06:46 PM   #20
BamaGanza FROG Promoter
BamaBob's Avatar
Just remember to drive the truck for 500 or so miles before towing your trailer....
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
ecoboost, towing
