Old 05-27-2016, 09:29 PM   #1
TPMS
I'm looking for feedback on TPMS accuracy.
My TPMS seems to read about 4psi low.
Same error consistently on all four tires plus spare.
I compensate for it, but wish it weren't there.
The TPMS vendor, who seems honest, doesn't see the error at his location in California.
I've checked against several different gauges. All the gauges agree with each other and not with the TPMS.
The only thing that comes to mind is that I live at 6600ft elevation. Perhaps my TPMS doesn't properly compensate for altitude.
Gyrogearloose is offline   Reply With Quote
Old 05-27-2016, 09:50 PM   #2
Commercial Member
Various TPM claim 3 to 5% accuracy. TPM is a monitoring and warning device and is not intended to be a substitute for a good quality digital hand gauge.
When tires are cool and at ambient (not driven for at least 2 hours and not in direct sun for at least 2 hours. Set all the tires to your Cold Inflation goal pressure based on your digital hand gauge.
You can look at your TPM Monitor after doing a "Signal reset" command or resetting the monitor so it registers the new cool temperature pressure. Now you know the monitor reading to expect.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
Tireman9 is offline   Reply With Quote
Old 05-27-2016, 10:02 PM   #3
Blackhat6mike's Avatar
Recently bought a second digital pressure gauge as a backup just in case I lost or damaged the original one. The second gauge was 2 psi lower than the first. I took it back to Auto Zone and they let me exchange it for another unit. The new one was one lb over the first. I tried two mechanical gauges I've had for years and the results varied. Go figure!
My original digital gauge is never more than .5 psi different from the TSTM 507 sensors, so I'm happy with it.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 05-27-2016, 10:13 PM   #4
Agreed on when and how to set cold inflation levels.
My TPMS claims +/-1.5psi accuracy, which is comparable to the spec on my AccuTire digital gauge. Based on comparison on multiple tires using a variety of gauges, my Accutire gauge reads correctly and the TPMS is low by 4psi. Kinda disappointing.
Despite the error, it's fun to be driving along and notice that the right side tires are at higher pressure than the left, and then realize that the sun is on the right and is warming those tires.
I also noticed that here in Colorado where there can be a wide temperature swing during the day, if I set my tire pressure early in the morning when it's still cold, pressure when towing at 2pm in the afternoon warmth can be surprisingly high. Tires set at 65psi cold may be running at 75psi warm, which is getting close to the 80psi rating of my wheels.
Old 05-27-2016, 11:06 PM   #5
Chief tinkerer
Gidyupgo's Avatar
Sunseeker 3010 running TST 507s internally mounted on metal bands. After 5 camping trips, the Passenger side inside dual runs consistently 5 degrees warmer. Cold pressure is exactly the same on the pair. Wanna guess which side the exhaust is on? It's nice to know the digital temp, but the little things like this can bug you until you get to the A'ha! moment.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 05-28-2016, 08:43 AM   #6
That would have driven me nuts.
Nice sleuthing!
Have you checked the accuracy of your TSTs?
If so do you know the altitude where you checked?
Old 05-28-2016, 11:06 AM   #7
Commercial Member
Pressures for setting tires or wheel limits are based on "cold" tires.
"Cold" tire means not warmed up by Sun or driving. It does not mean you have to put the tires in the fridge.
Tire pressure will increase by about 2% for each 10°F. Here is the Engineering info with links to even more details for those interested in understanding the "why".
Old 05-28-2016, 11:17 AM   #8
Commercial Member
On my blog I have a number of posts on Temperature and Pressure and even on Elevation effects.
Also some information on how to have, use and preserve your own "Master" gauge.
I suggest you start HERE.
Then if you want or need more details simply look at index on left. I am not allowed to simply re-post my blog writings here.
FYI I use Accutire Tire MS4120 from Amazon for about $10. I have checked three of these againsed certified ISO Laboratory master gauges and the Accutire units were always +/- 0.5 psi
You might also read "Measurable vs Meaningful"
Old 05-28-2016, 02:22 PM   #9
DaveSchwartz's Avatar
You just have to choose which guage you want to believe when you set your cold pressure. I believe the digital guage I've been using for years. Compared to that, my TPMS reads 2psi low consistently across all tires and I've just gotten used to that.
The point of a TPMS is not necessarily to be able to tell your absolute pressure, its to be able to monitor for unexplainable relative differences, especially sudden changes (which should trigger an alarm anyway). The initial conditions, once I know they have been properly set, are not important to me.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 05-28-2016, 02:25 PM   #10
Commercial Member
X2
Old 05-31-2016, 04:56 PM   #11
Chief tinkerer
Gidyupgo's Avatar
TPMS
Nice sleuthing!
Slow responding, just got back from Texas Gulf coast. I have access to precision calibrated gauges if I wanted to be precise, but alas, I figure I am well within the safe zone with my servicing. I am at 875ft. TSTs show about 3lbs below the gauge I use so, for example, I air to gauge press of 78 on fronts for 75 on TST reading, 83 gauge for 80 on the drive axle, etc, and I don't worry about it being + or - 3 as long as the dual pairs or fronts don't have a big split.
Biggest thing I found during pre-trip servicing is that adding to the passenger inside dual caused the passenger outside pressure to increase. Scratched head and then realized that the shop that mounted the pre-assigned internal 507's last month had them switched.... hah. There is a simple relearning procedure but we were in the middle of a 3500 mile trip at the time and I didn't want to give Murphy a chance to mess with me. Home now, so will do this.
Gary
