Old 04-09-2019, 12:26 PM   #1
CentralMePistol's Avatar
TPMS Question
So I am considering purchasing a TPMS system for my travel setup... I was curious how others have gone about it.
My truck has an internal TPMS, however, I am in the process of upgrading to E rated tires. Will the internal system do an effective job of monitoring them? I don't like the idea of having to scroll through my features to pull up the tire pressures- I prefer to travel with the Trans Temp displayed so that I can monitor that. Also, the alarm does not currently go off until I am at 27psi... far below what I will be towing at. So I feel like a separate TPMS would be better way to monitor them.
Now, if I buy one why does it seem that they come with only four or six sensors? Or of course, I found one system that comes with ten!I feel like it shouldn't be that uncommon for a system to come with 8 sensors... Or am I the only one with four tires on my truck and four on my trailer??? Or are we just expected to do the trailer and two rear tires?
I see in other threads TST is "THE" brand to have and everyone just loves them. Does anyone have experience with other brands just for comparison?
2018 Cherokee 274DBH
2012 GMC Sierra 1500
4x4, Crew Cab, 5.3 KDL HD Cooling, 3.42 ratio
Recurve R6 WDH w/Sway Control & SumoSprings
Days Camped:2019-18 and counting / 2018-30
CentralMePistol is offline   Reply With Quote
Old 04-09-2019, 12:36 PM   #2
bob213's Avatar
Just my thoughts...Many new trucks are coming with TPMS built in and I believe all SUV's have them. That may explain why basic set-up is 4 sensors. If you have a blow out on your truck you are going to know it and the chances are far lower since you are running a better tire than a ST tire. On the trailer, by time you realize it or someone comes up next to you pointing to the trailer you more than likely have substantial damage to the side of the trailer. I have TST and am happy. TireMinder and Tire Trakker? will do the same job but have not heard many stories about "Great customer service" like I have with TST.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
bob213 is offline   Reply With Quote
Old 04-09-2019, 02:04 PM   #3
Lins's Avatar
Maybe you can reprogram your truck TPMS? I reprogrammed mine on my 2500. The TST507 monitors up to 22 tires I think if that's the route you want to go.
If you go with E rated tires, what PSI do you intend to run? What size are your tires?
2007 Rockwood 2701SS
2014 Triumph Bonneville. NH Togas, TTP Tune 3
1953 GMC 9314
Lins is offline   Reply With Quote
Old 04-10-2019, 08:34 AM   #4
I've asked about reprogramming but the dealers have looked at me blankly...
I'm thinking I may run 40psi day to day and 60psi towing. Not sure yet exactly on the psi- that will likely be my next post
Old 04-10-2019, 08:50 AM   #5
Lins's Avatar
Yeah that’s a sensitive subject. Just having thicker sidewalks will help. I run about 60 front, 50 rear towing our TT. That’s using load and inflation tables and scale weights. Some will agree, some will say I’ll have a blowout but I get nice even wear.
I went aftermarket to reprogram my TPMS, dealer software isn’t allowed to change it for Ram.
1953 GMC 9314
Old 04-10-2019, 08:51 AM   #6
Lins's Avatar
Duplicate post for some reason
1953 GMC 9314
Old 04-10-2019, 08:56 AM   #7
Denver To Yuma In 90 Days
Even if you do go to a separate system for the truck tires, you may not be able to turn off the truck's built-in TPMS system.
I don't know this for sure...just speculating.
JohnD10 is offline   Reply With Quote
Old 04-10-2019, 01:31 PM   #8
The TST system is great for anyone that owns more than one trailer. The monitor can be programmed to monitor several trailers, each with their own sensors. Hook up to the Travel Trailer, use the number programmed for that trailer, including warning pressures/temps. Change to the boat or utility trailer, use their unique ID number and again the monitor now uses the set warnings for those sensors.
Not the cheapest system on the market but it's designed to monitor and protect tires that cost way more than those we use on travel trailers. For us it's getting sufficient warning to prevent damage to the trailer rather than just tire alone. A $50-$100 tire is nothing compared to damage that can be measured up to the thousands.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 04-13-2019, 10:22 AM   #9
I have the 507 and while it may work for multiple trailers, the PSI settings must be the same for both. So I decided to try something cheaper/simpler and love it - it's solar so there are no wires.
https://www.amazon.com/gp/aw/d/B078R...mob_b_pd_title
jeffnick is offline   Reply With Quote
Old 04-14-2019, 07:12 AM   #10
Just bought the same. Will see how well it works next weekend. The drive from storage to home seemed to work fine.
luker0 is offline   Reply With Quote
tpms
