Old 08-01-2016, 05:45 PM   #11
Originally Posted by spock123 View Post
Mine came with locks on that you have to take off to check the pressure, TST sent a tool so someone else didn't steal the sensors off the stems. When I check the air pressure I just unscrew the sensors
Mine also needs a tool to remove because the case spins freely. I'd like to be able to replace my own batteries. BTW, I re-installed all 10 of my sensors today to get things ready for FROG. I found out from TST that when the sensors have pressure on them, they are using the battery. So, I only put them on when I'm towing.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 08-01-2016, 05:48 PM   #12
BendOrLarry's Avatar
Originally Posted by Lefty59 View Post
We have the EEZ system (EEZ RV PRODUCTS - RV And Outdoor Recreational Equipment, Eeztire Tire Pressure Monitoring Systems) and haven't had any issues with its performance. The battery in the monitor lasts a long time without being recharged.
We originally ordered the flow thru sensors but didn't like how far they stuck out from the tires so we exchanged them for the anti-theft non-flow thru ones.
The system was fairly easy to set up and we are on our second year with the same sensor batteries. Batteries are user replaceable and system ships with extra seals in case they are needed.
We've been happy with our EEZ TPMS system and would recommend it to others.
I also have the EEZ system. Works great and has a bigger display than the TST.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 08-01-2016, 07:37 PM   #13
I leave mine sensors on all the time, I never know when we take a trip besides the sensors are on my truck
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 08-01-2016, 07:51 PM   #14
Why do you have to check the pressure? Isn't that what the monitors are for?
Steve29rlx is offline   Reply With Quote
Old 08-01-2016, 08:01 PM   #15
I last used my camper at the end of February and I knew it was going to be 5 or 6 months before I used it, so it made sense to save the batteries. It cost $20.00 per sensor to get the batteries replaced! I have 6 sensors on my truck and 4 on my camper.
Old 08-01-2016, 08:19 PM   #16
Berkshire 390QS
NO3putt's Avatar
Have the TST 507 System without the flow thru, however have had to buy 3 replacement sensors so far at around $50 each. Think we will be looking at a system with lifetime warrenty.
2015: 188 days, 2016: 72 days,
Skip
Old 08-01-2016, 09:43 PM   #17
I have had my 507 for a long time, seems like a long time, I have replaced the batteries once and I never lost a sensor. Worth every penny I paid for system
Old 08-01-2016, 09:46 PM   #18
I double check the sensors at least once a month with a digital gauge. I like to be sure everything is working properly. Just me
