Old 07-31-2016, 09:42 PM   #1
BandJCarm's Avatar
TPMS System
OK, time is up. I've waited all I can wait.
Picked up the 5'er in May. I need a TPMS system and was about to buy the 507 Flowthrough sytem, but I filled out a 'contact me' link on the TPMS website and got a reply that "great new things are coming soon". I called them.....somewhere in Georgia....and talked at length to a lady. I was told that they were coming out with a new system in "about 60 days" that would be A) solar and not need battery replacement and B) have a color monitor, and C) fix some 'problems' with previous units. I was told that they would have this available at the Goshen Rally. So, I've waited. I had only one trip planned, then the trip to Goshen, so I figured I'd wait for the newest and greatest and gamble till then.
I've emailed back several times. I got one reply, sort of vague. Nothing since.
I don't know if there is a Vendor List for Goshen, but I see nothing on their website about this.........and don't see anything about them being at Goshen with this 'new product'.
I've not said anything for 2 months because I wondered just how public this 'new product' info was. But now, I am going to need a TPMS, and nothing.
Meanwhile, even though this is just one guy's blog, I see this rating:
Top 4 TPMS Systems Comparison - Five In a 5th
never heard of EEZ but they are cheaper and higher rated (by this one guy!)
So, now what should I do?
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-31-2016, 10:34 PM   #2
Bill, I've had the TST 510 TPMS for 4 years now. I've had 2 of the 10 sensors need new batteries. On the 510 system, you have to send the sensors back for batteries. I'm not thrilled with that, but turn-around was very quick. Twice, it has saved me from issues. One time it was a 1/4" bolt threw my inner dual on my truck. The other time, it was a brake issue on my trailer wheel and it heated enough to alert me. I'm happy with TST. Don't know about the EszTire system.
2012 CC 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 07-31-2016, 10:46 PM   #3
Usually Confused Member
emm-dee's Avatar
TST told me a few weeks ago the color monitor system was in final testing but at that time didn't have a release date. My monochrome system works just fine so upgrade is not in my plan.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 07-31-2016, 11:16 PM   #4
BBBlue's Avatar
I for one would not leave home without a TPMS. In the past, I have not had too much luck jumping on the band wagon with brand new technology (mod 00), I usually wait a year or two and let the beta testers submit there issues and usually jump in at mod 3 or 4. I currently have the system by TST. Not the flow throughs. I can replace the batteries myself. The flow throughs stay on when making adjustment to tire pressure and require them to be sent to the vendor for battery replacement, I believe.
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2017 Days camping-190
2018 Days camping-66
BBBlue is offline   Reply With Quote
Old 08-01-2016, 12:45 AM   #5
GLCM Warrior
Lefty59's Avatar
We have the EEZ system (EEZ RV PRODUCTS - RV And Outdoor Recreational Equipment, Eeztire Tire Pressure Monitoring Systems) and haven't had any issues with its performance. The battery in the monitor lasts a long time without being recharged.
We originally ordered the flow thru sensors but didn't like how far they stuck out from the tires so we exchanged them for the anti-theft non-flow thru ones.
The system was fairly easy to set up and we are on our second year with the same sensor batteries. Batteries are user replaceable and system ships with extra seals in case they are needed.
We've been happy with our EEZ TPMS system and would recommend it to others.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 08-01-2016, 07:30 AM   #6
clr
There was a vendor at the rally selling the EZ system the year before last. They were not there last year for some reason. I looked at both systems and liked the TST 507 system better, but that was just me. I have the 507 system with the non flow thru sensors and have used it since this spring, and I love the system. The support folks are very helpful, I had to call with a set up issue, that was cockpit error on my part. The 507 system has customer replaceable batteries. Tip for either system have metal valve stems installed if you have rubber now.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 08-01-2016, 09:31 AM   #7
BBBlue's Avatar
x2
BTCM(SW) Ret USN
2013 Sanibel 3500
Old 08-01-2016, 04:49 PM   #8
I have the TST 507 with the non flow through, I have had them for a long time. I took the locks off mine, makes them lighter. I have metal valve stems on camper, actually the camper came with metal valve stems. The camper I had before had rubber valve stems and they worked great. I have rubber valve stems in truck. The 507 work good for me, I'm going to keep what I have
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 08-01-2016, 05:34 PM   #9
What do you mean by taking locks off? Do you mean the spinning plastic case?
Old 08-01-2016, 05:42 PM   #10
Mine came with locks on that you have to take off to check the pressure, TST sent a tool so someone else didn't steal the sensors off the stems. When I check the air pressure I just unscrew the sensors
