10-26-2016, 05:43 PM
TPMS system on Amazon.
Anyone using this system? For the price, I was thinking of getting it.
TireMinder TM55c-B Tire Pressure Monitoring System (TPMS) for Trailers, Travel Trailers, Toy Haulers, 5TH Wheels and more
https://www.amazon.com/TireMinder-TM...2%3A1248861011
2017.5 Rockwood Ultra Lite 2905WS (all the options)
New TV- 2017 Ram 3500 SRW Sport 4X4
Old TV- 2007 Dodge Ram 1500 Sport (Hemi)- towing vehicle
10-26-2016, 05:54 PM
10-26-2016, 05:56 PM
Just ordered a tst tpms 5 minutes ago.... try a web search for reviews, I was swayed....
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
10-26-2016, 05:57 PM
While I don't use it, I have seen positive remarks about it on this forum. I use the TST-507 system which seems to be the most popular and has excellent reviews.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
10-26-2016, 06:00 PM
Does the TST-507 work on a travel trailer? i see a lot of them stating you need the signal booster. Does the kit come with everything needed? Here is the one I found:
https://tsttruck.com/product/507-starter-system-kit/
Just want to make sure it is the right kit.
10-26-2016, 06:39 PM
Always Learning
Yes, the TST-507 works on trailers. I use mine on my 42' fifth wheel mostly without issue. I do have one tire that disappears pretty regularly and that started more recently. I'm going to get a repeater but was fine for a good year.
Personally, I'd try to go without a repeater until you find that you need it.
The linked starter set has 4 sensors, so it's good for 4 tires (e.g. your trailer). I wanted protection for my truck tires also and so I bought extra sensors. Otherwise, it has what you need.
10-26-2016, 06:42 PM
Great. Thanks for the info. I am upgrading my truck soon, so i will make sure it has the TPMS already, and if not, I will order more sensors too. thanks!
10-27-2016, 12:28 PM
Love my TST 507 works great on my RV, I believe there is a different model for trailers
Lee Hartwig
Ford V10
2009 Forest River Lexington
10-27-2016, 12:38 PM
I did extensive research on TPMS systems and took a hard look at the TST system. I went with this one https://www.amazon.com/EEZTire-Tire-...words=eez+tpms
I have had it over a year without any problems. It works great and has a larger display than the TST.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
10-27-2016, 12:40 PM
Very Happy with !
EEZTire Tire Pressure Monitoring System- have used for last (2) years- Saved me from blow out this summer !
10-27-2016, 01:07 PM
I've used a Tire Minder for years. I monitor 12 tires with mine (8 on coach + 4 on Toad). Has saved me several times. The only problem I've had is that occasionally it will lose signal to a sensor. Usually this happens when the battery is starting to go. The batteries are real cheap on Amazon, so I just change them all at the start of the season and have very little trouble.
One thing to check is what are your valve stems made of? They have a special sensor made for aluminum stems (the one you linked to had sensors for everything else). Trying to remember my chemistry here, but if you have aluminum stems, and attach a steel-threaded sensor to it there may be corrosion problems... Amazon sells aluminum sensors too: https://www.amazon.com/2-Pack-Alumin...inder+aluminum
10-27-2016, 08:05 PM
That's the one I've had for a few years. It's a fabulous system. I highly recommend the 507. Over the years I come to realize that the anti theft jacket was more trouble than it's worth so I removed it. It also makes it much easier to change the battery without that jacket. I also do not have the flow through sensors as I don't want to replace my rubber valves with metal ones.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
10-27-2016, 08:24 PM
I have the TrailAir pin box and I'm installing one sensor on it, it will be the flow through. Another vote for TST
10-27-2016, 09:08 PM
Try replacing the batteries before you buy the repeater. It's not uncommon for the transmitter range to decrease as battery level gets lower. If it has worked good for a year, it's about battery time anyway.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
10-27-2016, 09:15 PM
Always Learning
Cool, I'll try that.
10-28-2016, 07:50 AM
I use TireMinder A1A system. Works great. Caught couple issues immediately. Pressures are very accurate compared to a handheld pressure gauge while temperatures run slightly off compared to a digital IR temperature reader. Approaching 10K miles on OEM Westlake tires. I don't buy into China Bomb rhetoric. Take care of your tires (pressure, proper loading, road speed, inspections, storage etc) and you will get normal life span out of them. I pushed last set if tires to to just over 6 years and 25K miles. It starts with good TPMS.
10-28-2016, 07:55 AM
TST 507RV ordered from Amazon to be delivered tomorrow.
10-28-2016, 08:14 AM
Great rv products is a good place to order the TST 507 from, free shipping and no tax
10-28-2016, 08:34 AM
Ependydad, if you are going to replace one battery, replace them all at one time. VOE.
10-28-2016, 09:27 AM
I did a lot of research before I bought my Eez tire system, it was one of the few that no one complained about signal loss using no repeater. I use mine pulling a 36' TT behind a long bed truck and have never lost a signal. Their boast was not needing a repeater, and I believe that to be true from my experience.
