Old 03-19-2016, 02:09 PM   #11
Trailer brake intermittent
This may sound crazy, but if it didn't happen to me just yesterday I wouldn't believe it.
Getting same readings as you on my 2015 Chev 2500 with HD Tow and factory integrated BC.. Just yesterday.
After checking everything 2x. I pulled out truck owner manual (always a last resort)
It said to un plug TT from receptacle, turn off TV wait five min start over and I be damned it reset and all was good.
Not saying this is your problem, but worked for me, and I'm still amazed at the internal workings of these complex systems....they simply talk to one another.
Try it......nothing to lose. Or consult your TV manual if you have integrated system. If not may be a moot point. Good luck..
Poper is offline   Reply With Quote
Old 03-19-2016, 02:35 PM   #12
Canadiancrew's Avatar
Possibly just a ground problem when they moved it.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 03-20-2016, 05:52 PM   #13
D-maxx dave's Avatar
Had two Chevrolets (09, 12) had under hood wiring not connected from factory. Lighting worked, but no brakes.
Truck dealer set them up for me.
David & Kelly
2015 Sandpiper 355RE
2015 Silverado 3500 CCSB SRW 4X4 D-maxx
Nights camped in 2016:03😄
D-maxx dave is offline   Reply With Quote
Old 03-21-2016, 07:43 AM   #14
Winter Texan
Same problem on GMC 1 ton no trailer connected
I had to cancel our vacation and spend 4 hours at the GMC dealership to find out it was a trailer break connector causing the problem. 2 more hours at my trailer brake specialist. He cut out the yellow connector at the break and reconnected each of the wires and shrink wrapped them. Problem solved. Cost was one vacation cut short with our grand daughter and around $400.00 out of pocket. This is a new 2016 36ckts Cedar Creek. Too much trouble getting it back to dealer from our vacation location so I opted to pay on my own. Dealer and factory authorizations can shorten your life on earth. Not worth it.
Gilpalmer is offline   Reply With Quote
Old 03-21-2016, 08:44 AM   #15
I had something similar happen and after many hours of scratching my head found that the brake wires went from one side of the trailer to the other inside the axle. All the bouncing around from the travels wore the insulation off from rubbing on the rough inside of the axle. Replacing the wires and running them outside solved the problem. Just a wild thought.
AURORASTEVE is offline   Reply With Quote
Old 05-11-2016, 06:11 PM   #16
1Z1A3E070300405761
Sent from my SM-G900V using Tapatalk
Riverdude is offline   Reply With Quote
Old 05-11-2016, 06:23 PM   #17
Herk7769's Avatar
Originally Posted by Riverdude View Post
1Z1A3E070300405761
Your package was delivered on Tuesday.
They left it by your side door...
HAM CALLSIGN - KC3FFW
Old 05-11-2016, 06:36 PM   #18
Davis_Family's Avatar
I had a problem very similar to this! Turns out the brake controller I had installed wasn't strong enough to pick up the LED signals from my truck and trailer to the controller. We ordered a different brake controller that was for LED trucks and trailers and problem solved!
Cody
2016 Cherokee 264L
2015 Ram 1500 Lonestar 4x4
Cody
2016 Cherokee 264L
2015 F-250 6.7L Diesel
Davis_Family is offline   Reply With Quote
Old 05-11-2016, 07:13 PM   #19
Had brakes, no problem. Then out of the blue I had no brakes on the tt. Got the message on my dash stating "Wiring Fault In Trailer". Tested brake pin on truck and had 12v. Activated brake pin on tt and brakes worked. Long story short, the truck brake pin and the tt brake pin were not making contact when plugged together. Realigned the pins and now have brakes. Also no more wiring fault messages. Hope this helps.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
trailer, wiring, brakes
