Old 07-21-2016, 11:28 PM   #11
f5moab's Avatar
Originally Posted by Big Red and 30WR View Post
Mine will charge the battery without using tow haul mode
Your what?
On late model GM vehicles, the energy management system will drop the output voltage of the generator to around 12.9V after certain parameters are met such as set speed, battery fully charged, headlamps off, wipers off, etc. And while that can charge the trailer's battery it is not ideal.
The GM's computer does not monitor the trailers battery or voltage, so if traveling with 12V fridge running, you could discharge the battery while driving; I know I did it. That is when I called a GM engineer in MI and asked why my 2013 Silverado did not keep my batteries in the trailer charge. He noted to me to keep the headlamps on, or go into tow/haul mode. (And he also stated it is in the darn owner's manual so read the book.)
In tow/haul mode or when you turn on the headlamps, the computer regulates the voltage output to around 13.5 (something like that, I can always get the exact spec, just not this late at night-especially when a two-hour time difference between here and MI). Whatever the voltage is, it is enough to send higher voltage to the trailer batteries, and after that info was received, I have always run with the headlamps On (which also helps other vehicles to see the trailer since the lights are all on), and I have never had a dead set of trailer batteries after 8-16 hours driving with the fridge running on 12V.
I'll see if I can get him at work tomorrow and get him to email me some of the specs for how the system works.
f5moab is online now   Reply With Quote
Old 07-21-2016, 11:39 PM   #12
Phenom's Avatar
Originally Posted by f5moab View Post
Your what?
This is interesting as I've been thinking about whether or not I could run my fridge on electric only while on the road. I've been running the propane, but electric would be better. Have a long day on the road coming up this week and was considering it.
Sean
'16 28DBUD
'16 2500HD Dmax
Phenom is offline   Reply With Quote
Old 07-22-2016, 12:28 PM   #13
Didn`t realize this thread was for GM only.
Big Red and 30WR is offline   Reply With Quote
Old 07-22-2016, 12:51 PM   #14
jeff
jeff64's Avatar
Hard to believe you have 3 way power on the refer in a TT. Mine's 120vac or propane only. The 12 vdc is for the control circuits to switch it to propane
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 07-22-2016, 01:12 PM   #15
Witch Doctor's Avatar
One thing to remember is that your alternator could supply 13.5 volts , but you are more concerned about the amps. Your amperage is still going to drop because of the wire size going to your trailer plug on the TV. I don't care if your in toe mode or drive with your headlights on, that wire can only supply so much amperage. Volts yes, amperage no. Unless your TV charge wire is larger, other then that it's only a trickle charge....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 07-22-2016, 01:52 PM   #16
Phenom's Avatar
Good point. Disregard.
Sean
'16 28DBUD
'16 2500HD Dmax
brakes, trailer
